Clean server (Ubuntu 16.04)…
Installation failure with :
Missing file to read at dovecot::/usr/share/webmin/dovecot/dovecot-lib.pl line 265
/bin/sh install.sh
Welcome to the Virtualmin GPL installer, version 6.0.3
This script must be run on a freshly installed supported OS. It does not
perform updates or upgrades (use your system package manager) or license
changes (use the “virtualmin change-license” command).
The systems currently supported by install.sh are:
CentOS/RHEL Linux 6 and 7 on x86_64
Debian 7, 8, and 9, on i386 and amd64
Ubuntu 14.04 LTS and 16.04 LTS, on i386 and amd64
If your OS/version/arch is not listed, installation will fail. More
details about the systems supported by the script can be found here:
http://www.virtualmin.com/os-support
The selected package bundle is LAMP and the size of install is
full. It will require up to 650 MB of disk space.
Exit and re-run this script with --help flag to see available options.
Continue? (y/n) y
[INFO] Started installation log in /root/virtualmin-install.log
▣□□ Phase 1 of 3: Setup
Downloading repository metadata [ ]
Enabling universe repositories, if not already available [ ]
Disabling cdrom: repositories [ ]
Cleaning out old metadata [ ]
Downloading RPM-GPG-KEY-virtualmin-6 [ ]
Downloading RPM-GPG-KEY-webmin [ ]
Installing Virtualmin 6 key [ ]
Installing Webmin key [ ]
Updating apt metadata [ ]
Removing non-standard Webmin package, if installed [ ]
▣▣□ Phase 2 of 3: Installation
Installing Webmin [ ]
Installing Usermin [ ]
Installing fail2ban [ ]
Removing nginx (if installed) before LAMP installation. [ ]
Removing unneeded packages that could confict with LAMP stack. [ ]
Installing postfix [ ]
Installing virtualmin-lamp-stack [ ]
Installing Virtualmin and plugins [ ]
15 Aug 08:30:58 ntpdate[24048]: the NTP socket is in use, exiting
Installing updates to Virtualmin-related packages [ ]
▣▣▣ Phase 3 of 3: Configuration
[1/23] Configuring AWStats [
[2/23] Configuring Apache [
[3/23] Configuring Bind [
[4/23] Configuring ClamAV [
[5/23] Configuring Dovecot ▒▒▒▒▒▒▒Error: Missing file to read at dovecot::/usr/share/webmin/dovecot/dovecot-lib.pl line 265
Error
▣▣▣ Cleaning up
[SUCCESS] Installation Complete!
[SUCCESS] If there were no errors above, Virtualmin should be ready
[SUCCESS] to configure at https://{hostname}:10000.
Anyone have suggestions, or a fix?
Thanks.
