As mentioned here : https://www.virtualmin.com/node/48121
Just installed fresh Ubuntu 14.04 + latest virtualmin
Tried issue letsencrypt cert from virtualmin panel and getting “request failed : Domain has no website, and DNS-based validation is not possible”
Im usung apache, and mentioned fixes in my link dosent works really, cant find them lines in file.
How to fix it please?
Letsencrypt on virtualmin will require a domain name as it writes a files to that domain and if it cannot do so will throw up an error and the cert will not be granted.
Open up an SSL client.
You can install letsencrypt separately … on ubuntu its sudo apt-get install letsencrypt.
Stop apache so port 80 is free.
Then in the command line type sudo letsencrypt certonly --standalone --agree-tos --email name@domain.tld -d domain.tld -d www.domain.tld
change domain to the domain you want the cert for and also the name in the email part.
Letsencrypt will create the cert. If it doesn’t then I suspect there is an issue with your server. You will find the cert in etc/letsencrypt/live
Start apache
