Replicating Virtual Domains
After setting up Replication for Virtual Domains, is it possible to trigger the replication process via the API or some other scripts?
Eg: Server A is the source and Server B is the replicated system. A Virtual Domain is created on Server A via the remote API, after that is it possible to replicate this domain on Server B immediately?
Bump! anyone?
We have a Cloudmin license how do we make use of the support?
Sorry, I unfortunately don’t know the answer to your question – but you’re welcome to file a support request using the Support link above… and Jamie should be able to go over the details of all that with you.
Thank you Eric :slight_smile:
