Hi
I had a problem with DNS and Bind which I think resolved.
however, when i try and replicate from old server to new server I get the following errors.
I have tried this on more than two domains
Finding source and destination systems …
… found source abc.biz and destination xyz.com
Refreshing domains on source system …
… done
Creating temporary directories …
… done
Backing up 2 virtual servers on source system …
… backup failed : Starting backup… Creating backup for virtual server mydomaincom … Copying virtual server configuration … … done Backing up Cron jobs … … none defined. Copying records in DNS domain … … domain not found! Backup failed!
trying to get an idea where to start looking
this was working until I did the CLoudmin install on the new server. (still trying to move Clodumin to new server - getting some version error so trying to resolve that)
(I have 3 servers, two original and one new I am moving everything to)
(I tried to install Cloudmin on Server 3)
the above problem I had was on server 2 trying to get Cloudmin moved to Server 3
anyway, I have just noticed that Server 1 has a screwed up BIND:
[code]The primary configuration file for BIND /etc/named.conf does not exist, or is not valid. Create it?
Setup nameserver for internal non-internet use only
Setup as an internet name server, and download root server information
Setup as an internet name server, but use Webmin’s older root server information[/code]
