I tried looking around these forums and Google for the answer, and I believe the answer is likely obvious which is why it isn’t found. I did want to verify this before wiping my current installation though. If I already set up my server manually, can I replace it with Virtualmin? I followed the guides available on Linode.com to get everything up and running.
I also wanted to ask if there’s a billing system software that would plugin to the store’s front-end/usermin end to process payments while I was here, but if that’s a bit out of scope for this forum I understand.
Thanks for any help, I really look forward to streamlining my domain creation process with Virtualmin!
