after my mistake to install Cloudmin on an working Virtualmin installation i removed Cloudmin. I uninstalled it like @Joe wrote it in an other Thread.
Now Virtualmin works not correct. Is it possible to repair Virtualmin, or must i reinstall it?
Virtualmin / System Settings / Check Configuration.
That will run a test on your Virtualmin configuration and tell you if there’s a problem with it. If you have to, right below that is the Re-Run Install Wizard.
Best to just check configuration first and see what errors it list if any.
Thanks for reply and sorry for the bad information.
i think i fixed it myself. Spamassassin was uninstalled. That was the reason that i got no emails. Thats fixed. Docker and all other Websites works again. Now i made an Backup and won´t touch the server again.
