Yeah, but somehow i have only 96 MB left on a machine with 512MB of RAM :(. So thats kind of ticking me off. What the heck is eating up so much memory.
That’s normal. In fact, I’d expect less free on a working machine with 512MB. I’ll tell you why: buffer/cache.
The Linux kernel is very aggressive about caching disk data in RAM in order to improve performance, so it only keeps a few MB free, while devoting any extra memory to the buffer/cache. You can see this in top, by looking at the buffers and cached fields. "buffers" is disk I/O buffers, while "cached" is swap data that is also in memory. The former speeds disk limited tasks, while the latter tells you want is in swap and also cached in memory (also a performance thing).
Both buffers and cache are generally safe to consider "available" memory, and can be freed instantly by the kernel when needed.
In other words, your total available memory is free+buffers+cached.
Now, if this totals up to only 96MB, then we might have a problem, and you should post the output of a "ps -auxc" so we can see where memory is going.
You can see it in a nicely formatted table with "top". Hit "M" (not that it is uppercase) to sort by memory usage.
I was surprised by this when i first started running linux, my servers typically only have 5-10% of the available ram listed as “free”, but i’ve never had performance problems.
“Incredible amount of memory” is in the eye of the beholder…that doesn’t look like a lot of memory to me. It totals up to 410048 or about 410 kilobytes…not even 1 MB. That’s probably one httpd child process (maybe not even that many…my eight httpd processes are consuming 11MB right now, so that seems to indicate that each one is greater than 1MB). 410K is nothing to worry overly much about. But…
Removing them is easy. It’s a two-parter, but I think this will stop all sound modules from being loaded.
First up, if the system is a kernel 2.6 based system or another system equipped with ALSA, configure alsasound not to start on boot:
chkconfig --level 345 alsasound off
And stop it now:
service alsasound stop
Next up, to prevent auto-loading of the modules (I don’t know if this is needed if the above is done, but it won’t hurt to do it anyway). Edit /etc/modprobe.conf, and comment out or all of the snd-related entries. Mine looks like this:
alias sound-service-0-1 snd-seq-oss
alias sound-service-0-8 snd-seq-oss #alias sound-slot-1 snd-card-1 #alias snd-card-1 snd-virmidi
alias snd-card-1 snd-usb-audio
options snd-usb-audio snd_index=1
I have a complicated sound setup on my home machine, for my long-neglected music and audio hobby, so yours will probably only be three or four lines compared to my dozen or so.
And, of course you can use modprobe to remove them right now (though I don’t know if unloaded kernel modules actually return memory to user space–I seem to recall they don’t):
modprobe -r snd_intel8x0
But you’ll have to remove them in their order of dependency, which can be tricky.
