I have a scheduled backup on several servers and they should be done at 00:00 every night.
As I can read on the log, the server did the backup and sent it to the backup server using SSH.
However at the end of the log, I can read that the directory “Tue” has been deleted because it was 7 days old (The backup is set to delete backup after 7 days).
In conclusion, virtualmin delete the recently done backup…
What did I wrong?
What exactly is the name of the backup folder? Just “Tue”?
The documentation for the “delete old backup function” says that a certain directory naming scheme is required so that it can determine which backups are too old:
Delete old backups […] However, this is only usable when the backup destination directory is named like /backup/%d-%m-%Y, or the filename is named like /backup/virtualmin-%d-%m-%Y.tar.gz. This is required for Virtualmin to be able to work out which files and directories were created by the backup process.
Well, that might well be the problem, since with just the weekday, VMin cannot determine how old the directory is. At least that’s how I understand the documentation entry. Maybe try creating a backup with the naming scheme given in my quote.
