Remote API and Mail forwarding settings
Hi, am I right that the Remote API call create-user.pl does not support the setting of forwarding email addresses?
Background: I want to create an user and add an email address to the "Mail forwarding settings". The option "Deliver to this user normally" should be checked too.
Thanks,
Bernhard
Yeah, I don’t see a way to programatically do that. I see a command for creating a user, and another for creating an alias (which includes forwards), but not one for setting the forward settings on an existing user.
I might pop a messaeg in the Bug tracker – it’s either there and we’re missing it, or it’s not there and Jamie may be able to add that feature :slight_smile:
BTW: The "Batch create users" format allows adding "forwards" to an email account. If set the "Deliver to this user normally" will be unset though.
