Regarding Roundcube installation issue
OS type and version REQUIRED
Virtualmin version REQUIRED
Failed to run database setup script : ERROR 1071 (42000) at line 51 in file: ‘/home/vm202/public_html/roundcube/SQL/mysql.initial.sql’: Specified key was too long; max key length is 767 bytes.
How can I solve this issue?
not enough information here
you need to give
os type and version
virtualmin version
mysql version
and did you use the virtualmin script installer to attempt to install roundcube ?
OS Type-Centos 7
Virtual MIN-7.5
Mysql-5.5.68
yes I am using virtualmin script
make sure you have set mysql like this and try again. You may consider changing your OS to a more modern one that has better support (rocky or alma or a total change ubuntu or debian) and will support higher versions of mysql
