SYSTEM INFORMATION | |
OS type and version | REQUIRED |
Webmin version | REQUIRED |
This is the second times, I come back to try winmin + virtualmin, both time I have paid, however, it is not smooth on my testing.
Actually, I have another server which is directadmin, I rent it from another hosting server, whatever I need, they can do it for me, although, the layout is old, but it can do what i want.
My second time to try virtual admin,
the first time i stopped as i am busy. but it is worst than last time.
My process is :
I have created a virtual server, sucms.mydomain1.com ( choose auto create user )
and i create another virtual server . sucms.mydomain2.com ( do th same, but error, said like :“no existing unix user exists” , Oh my god, i completely don’t know what happen)
whatever, the first virtual server create sucms user, then i put second server to sucms user, success
then i access the subserver, i see there are option(s), then i just tick some,
save
then the connection is broken .: chrome : refused to connect
I just want to play simple, i have not try any difficult setting, such as : auto binding subdomain base on the folder ( i know directadmin can do this).
it is my first day paid on second time testing, i drop into testing mode…god ! I am not server professional, but i am well in writing web program only…
I am really sad, the bug happen so soon. i don’t know how many will coming. if it is not bug, must be my operation mistake?
could you tell me what i can do …
i don’t know if i can continue for just using a another free web control panel ?
More details:
[root@server ~]# service webmin status
Redirecting to /bin/systemctl status webmin.service
● webmin.service - Webmin server daemon
Loaded: loaded (/usr/lib/systemd/system/webmin.service; enabled; vendor preset: disabled)
Active: inactive (dead) since Fri 2022-06-03 14:18:38 UTC; 4min 40s ago
Process: 6235 ExecStop=/etc/webmin/.stop-init (code=exited, status=0/SUCCESS)
Main PID: 13668 (code=exited, status=0/SUCCESS)
CGroup: /system.slice/webmin.service
└─2433 /usr/libexec/webmin/virtual-server/lookup-domain-daemon.pl
Jun 03 14:18:30 server.mydomain.com su[5938]: (to sucms) root on none
Jun 03 14:18:30 server.mydomain.com su[5943]: (to sucms) root on none
Jun 03 14:18:30 server.mydomain.com su[5956]: (to sucms) root on none
Jun 03 14:18:30 server.mydomain.com su[5962]: (to sucms) root on none
Jun 03 14:18:30 server.mydomain.com su[5974]: (to sucms) root on none
Jun 03 14:18:30 server.mydomain.com su[5979]: (to sucms) root on none
Jun 03 14:18:30 server.mydomain.com su[5987]: (to sucms) root on none
Jun 03 14:18:30 server.mydomain.com su[5994]: (to sucms) root on none
Jun 03 14:18:38 server.mydomain.com webmin[13668]: Webmin starting
Jun 03 14:18:38 server.mydomain.com .stop-init[6235]: Stopping Webmin server in /usr/libexec/webmin
