On webmin, we put an old site A in the subdomain of a new domain name B, so B uses the same database as site A, so when we enter the 2 sites via the 2 domain name A or B, it’s the same thing on the site.
The problem is that in site B, when we send emails, some emails received are still received as sent from the old domain name: internal links of the email come from old site A, I think that c is a redirect problem.
I already looked in service / configure / website / aliases and redirects and immediately:
Document directory aliases:
from: / dav - to: (to the directory of the new site B)
did you check website’s database for old links before moving it? eg. if its a wordpress, a search-replace plugin could help, just keep backups before messing around…
Thank you for your reply,
so I’m on joomla
in fact nothing has changed on the database, it’s just the new domain name B which points to the old database,
nothing has changed, no new site.
I tested the permanent redirect and it seems the redirect works on a link that I kept but it is the site that no longer works there:
for my test: www.A.com/test/page3.html -> www.B.com/test/page3.html
error: “The page is not redirected correctly”
I will see on the database side if I find something.
Do you have an idea please?
