i’m having some trouble getting virtualmin configured to use quotas.
quotas are enabled on my system, and virtualmin is aware of it, as you can see here:
Disk quotas Active for users and groups on home directories and email filesystem /.
but when I add a new virtual server, the “quotas and limits” feature is missing.
I know, I don’t have a seperate /home partition on that server, but that can’t be the cause of this problem, or can it?
am I missing something in the module config of virtualmin?
i’m using virtualmin 3.63gpl on ubuntu server edition 8.10
thanks in advance :-)<br><br>Post edited by: j0lle, at: 2008/11/11 10:49
I don’t have a /home partition either (and quotas work), so that’s definitely not your problem.
After a Virtual Server is created, and you choose that domain from the select list on the top-left, and hit "Edit Virtual Server" – that should be the only time you see Quotas and Limits.
It wouldn’t show up before you create it (such as in the “Create Virtual Server” option).
Yeah, the forum likes to eat attachments. It gets hungry.
Joe’s working on all that though
In regards to the "limits and quotas" – I believe the ability to do that was removed from a recent theme update, in favor of setting that information using a template (you can of course still edit it afterward creating the Virtual Server).
I suspect you’re seeing it on your other box because it’s not using the default Virtualmin theme – so at that point, anything is possible
