I’ve used Webmin for years, so bear with me here.
I’ve set up on FreeBSD 6.x, and it’s on me to configure this, which is fine. I can do things manually without a problem, ie I go into Network, create a virtual interface/IP, then go back, create a new site and use that IP. No sweat.
I also see that I can pick which network interface to use in the module configuration (good), and set a base number for virtual interface (good), then in templates and resellers, I can assign a range of IP’s.
Here’s where I’m getting stuck. If I go in as either an admin or reseller, go to create a new site, the only options that appear are the default shared IP, or enter a virtual IP address. That’s fine, but the point (I presume?) of being able to select an assignment range is that either via template or reseller account, the user is limited in which IP’s can be used here. Am I wrong about this? I would presume rather than a text box here, the UI element should be a drop-down of available IP’s that account could choose from.
The bigger gotcha however is upon attempting to create the new site. It complains that the IP address isn’t already on the system. Well of course it isn’t…it hasn’t been used yet. I thought that was the point of selecting a physical interface, so that Virtualmin would create virtual interfaces as-needed and bring them up, right? Or am I just confused on that point?
