Got a question about creating FTP users well 2 questions. I’ve created a virtual server added a domain and stuff like that the website works like a charm. But got the following “problems”
First
I want to give FTP users access to a folder in the root of the website. This works when i use dir’s without spaces like
Files/something/here
but when i try Files/something/here something
It gives an error that the folder does not excist. I know with htaccess you have to use \ for spaces and that works. But how can i make sure the server knows the folder is there with spaces
Second
When i create a new user it adds a .domain behind the name is there anyway to remove this and make it so that they can login by username only (for the FTP) they won’t be getting an email adres or anything like that
First: Okay tried putting it with quotes that does not work. Tried it with %20 but that also does not work. i’m getting a bit clueless I need to create 85 accounts because of a migration from a windows server to linux with virtualmin but the old content contains lot’s of root folders for users with a space it in.
Second:
Found the option and it has always and only avoid a clash. Choose the last one because that will never happen
You shouldn’t need to use quotes or backslash to have a path with a space in it - however, due to an over-zealous check in Virtualmin this isn’t allowed when creating a website FTP access user
