qmail+ldap configuration problems
I am trying to get qmail+ldap to work with virtualmin.
I patched qmail and installed it. I created objects in ldap and was able to create a email user from an .ldif file. If I go to “Read User Mail” It sees that user I created from the ldif. so it appears that I have LDAP configured properly and accepting users.
However, I am NOT able to create mail boxes from within virtualmin. Doing so gives me this error…
Failed to save mailbox : object class ‘organizationalUnit’ requires attribute ‘ou’
Anyone got any ideas why?
Please remember when giving advice, I am new to LDAP so don’t assume I know anything :slight_smile:
Hopefully someone can chime in and toss out some ideas as to why it’s not working!
However, not many folks here are using Qmail, and fewer yet are using it alongside LDAP :slight_smile:
Just in case it helps, here is a document on setting up LDAP using Postfix for use with Virtualmin:
http://www.virtualmin.com/documentation/id,combining_virtualmin_and_ldap/
