Pv-Grub not installed?
Hi there,
I created a new xen instance and selected to have Pv-Grub load the kernel on the VM. I created the VM and all seemed fine.
However, now I look in the /etc/ folder of the server and I do not see a grub/ folder.
I am confused. Did Pv-Grub not get installed? Or am I suppose to take additional steps to completely configure it?
If it did not get installed, can it be installed post-installation?
Thank you.
An update:
The grub configuration files are under /boot/grub.
Thanks.
ln -s /usr/lib/xen-4.0/bin/pygrub /usr/bin/
First verify where you have pygrub:
updatedb
locate pygrub
or
find / -name "pygrub"
And then
ln command from frist raw
