Protected Web Directories
Is it possible to change the name of the users file created by the Protected Web Directories module?
There doesn’t seem to be a config screen for this module. By default it creates a file called “htusers” which isn’t secured by the the default apache config. I’d like it to be called “.htusers”, which I have always thought was the conventional name for this file.
Cheers, Chris
This has been in webmin for ages, about time this was fixed.
Perhaps submit a bug report by clicking “support” at the top of the screen?
Hi, I just noticed, Virtualmin 3.94.gpl (Webmin 1.590) still does this:
  • creates “htusers” instead of “.htusers”
Also, I imported some Plesk domains, and the .htusers file was put into $DOM/etc, which I loved.
But when I create a new protected directory, this htusers file is in the same folder as .htaccess.
Is there a way to have it ALWAYS in the $DOM/etc folder??
