hello together,
I tried to install a higher version of proftpd than the old-stable 1.30 from the etch-backports and got the message that the package virtualmin-base will be removed…(not a good idea???)
is there a way to get proftp 1.30 working with encryption?
problem is the known issue with the directory-listing of the server and the current filezilla versions:
Command: LIST
Response: 150 Opening ASCII mode data connection for file list
Status: Server did not properly shut down TLS connection
Error: Could not read from transfer socket: ECONNABORTED - Connection aborted
Response: 226 Transfer complete.
Error: Failed to retrieve directory listing
thanks for any hint!
Kai
----> discussed in “Issues”
