I’m having a slight problem with proftpd, and was hoping that someone might be able to help.
First of all I have two servers ubuntu 8.04 installed, and all using the same domain name. I have two separate virtualmin gpl installed on both machines.
I installed a game server script called swift panel on the first machine and was able to setup the second machine with game files. I can ftp the first server just fine with external ftp client, but when I try to ftp the second server I can’t connect. I set the port on the second server to 22 because the first server ftp runs on port 21, not to mention that I can’t have the same port open through the linkksys router on two different machines.
Through swift panel, and using there built in webftp I can connect to both servers, but unable to connect to ftp with external ftp client to second machine.
I hope this makes sense to someone because I even had a hard time explaining it. Any help would be greatly appreciated. Thanks.
