This seems to happen with every logon I try, even root. I just recently moved a bunch of servers from anothe vmin install to this one, if this helps… Any ideas?
Okay, I turned off “alias logon only”, but I still cant log in, there aren’t any log messages now other than session opened then closed…
Just to make sure this is not considered a troubleshooting technique…root should never work for an FTP login in a default ProFTPd (or vsftpd, or whatever FTP server). root logins are disabled by default in every FTP server I know of, and with very good reason.
So, are you sure you are using the right username and password? In a Virtualmin system, the default username format would probably make the username seanieb.domainname
You can always know the real username by looking at the “IMAP/FTP Login” field of the Edit Mail and FTP Users page.
I think I figured it out, if I override the password manually in the authentication config then it works. All these users have shell logins that work, and etc, I guess I can go with that for now
Just for clarification; not that I want to re-open an old thread; but I struggled with this problem for about 2 weeks, before noticing 1 little setting that made it all better.
Authentication > Only allow aliased users to login?
Change that to No and it will allow regular users to log in; provided they are allowed ftp access.
