This is a stable system for at least 12 months. In the past 4 weeks I seem to have Proftpd locking up every other day (I remove the lock with rm -f /var/lock/subsys/proftpd), but if I don’t fix the lock, then this eventually causes apache to stop and I need to reboot the server. When I reboot, the second and third IPs that are assigned to the eth0:1 eth0:2 do not start and I have to add them back into the configuration. Both are listed as Active at Boot.
Also, there is a package update 1.3.3g-4.el6 showing in the CP, but if I try to install the update I get the error
Error: Package: proftpd-1.3.3g-4.el6.x86_64 (epel)
Requires: libcrypto.so.10(libcrypto.so.10)(64bit)
Requires: libcrypto.so.10(OPENSSL_1.0.1)(64bit)
Requires: libssl.so.10(libssl.so.10)(64bit)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
… install failed!
Current version of ProFtpd is proftpd-1.3.3g-3.el6.x86_64
One thing I noticed under ProFTPd settings page in Webmin is that there are two servers:
Virtual Servers
Default server Handles any FTP connections not handled by virtual servers.
Address Any Server name Default
Virtual Server Handles all connections to 68.178.130.21
Address 68.178.130.21 Server name
This seems wrong as the second server has no name. Not sure why there are two.
The only thing I can find in any logs is the following from miniserver log:
Error: Starting httpd: [Mon Jan 27 10:04:40 2014] [error] VirtualHost default:443 – mixing * ports and non-* ports with a NameVirtualHost address is not supported, proceeding with undefined results
(98)Address already in use: make_sock: could not bind to address [::]:80
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
[FAILED]
