neorf
June 3, 2009, 9:55am
#1
All ok with proftp when i upload files, but when i try to overwrite e file i get:
"550 Overwrite permission denied".
what can i do?
thanks
neorf
Eric
June 3, 2009, 10:02am
#2
I hadn’t run into that before, but in poking around on Google a bit, some folks make reference to tweaking the /etc/proftpd.conf file, and making sure this is set:
AllowOverwrite On
Do you see that in there?
If that doesn’t help, you may wish to post the contents your proftpd.conf file.
Thanks,
neorf
June 3, 2009, 10:36am
#3
SOLVED: just added:
[code:1]<Global>
AllowOverwrite on
</Global>[/code:1]
neorf
June 7, 2009, 12:57pm
#4
AllowOverwrite is ON, however this is my /etc/proftpd/proftpd.conf file.
if i log in using sftp connection via filezilla, i can upload, but i’d like to upload via normal ftp
[code:1]
/etc/proftpd/proftpd.conf – This is a basic ProFTPD configuration file.
To really apply changes reload proftpd after modifications.
Includes DSO modules
Include /etc/proftpd/modules.conf
Set off to disable IPv6 support which is annoying on IPv4 only boxes.
UseIPv6 on
ServerName "Debian"
ServerType standalone
DeferWelcome off
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
DisplayLogin welcome.msg
DisplayChdir .message true
ListOptions "-l"
DenyFilter *.*/
Use this to jail all users in their homes
DefaultRoot ~
Users require a valid shell listed in /etc/shells to login.
Use this directive to release that constrain.
RequireValidShell off
Port 21 is the standard FTP port.
Port 21
In some cases you have to specify passive ports range to by-pass
firewall limitations. Ephemeral ports can be used for that, but
feel free to use a more narrow range.
PassivePorts 49152 65534
If your host was NATted, this option is useful in order to
allow passive tranfers to work. You have to use your public
address and opening the passive ports used on your firewall as well.
MasqueradeAddress 1.2.3.4
To prevent DoS attacks, set the maximum number of child processes
to 30. If you need to allow more than 30 concurrent connections
at once, simply increase this value. Note that this ONLY works
in standalone mode, in inetd mode you should use an inetd server
that allows you to limit maximum number of processes per service
(such as xinetd)
MaxInstances 30
Set the user and group that the server normally runs at.
User proftpd
Group nogroup
Umask 022 is a good standard umask to prevent new files and dirs
(second parm) from being group and world writable.
Umask 022 022
Normally, we want files to be overwriteable.
AllowOverwrite on
Uncomment this if you are using NIS or LDAP via NSS to retrieve passwords:
PersistentPasswd off
This is required to use both PAM-based authentication and local passwords
AuthOrder *mod_auth_pam.c mod_auth_unix.c
Be warned: use of this directive impacts CPU average load!
Uncomment this if you like to see progress and transfer rate with ftpwho
in downloads. That is not needed for uploads rates.
UseSendFile off
Choose a SQL backend among MySQL or PostgreSQL.
Both modules are loaded in default configuration, so you have to specify the backend
or comment out the unused module in /etc/proftpd/modules.conf.
Use ‘mysql’ or ‘postgres’ as possible values.
#<IfModule mod_sql.c>
SQLBackend mysql
#</IfModule>
TransferLog /var/log/proftpd/xferlog
SystemLog /var/log/proftpd/proftpd.log
<IfModule mod_quotatab.c>
QuotaEngine off
</IfModule>
<IfModule mod_ratio.c>
Ratios off
</IfModule>
Delay engine reduces impact of the so-called Timing Attack described in
It is on by default.
<IfModule mod_delay.c>
DelayEngine on
</IfModule>
<IfModule mod_ctrls.c>
ControlsEngine off
ControlsMaxClients 2
ControlsLog /var/log/proftpd/controls.log
ControlsInterval 5
ControlsSocket /var/run/proftpd/proftpd.sock
</IfModule>
<IfModule mod_ctrls_admin.c>
AdminControlsEngine off
</IfModule>
Alternative authentication frameworks
#Include /etc/proftpd/ldap.conf
#Include /etc/proftpd/sql.conf
This is used for FTPS connections
#Include /etc/proftpd/tls.conf
A basic anonymous configuration, no upload directories.
<Anonymous ~ftp>
User ftp
Group nogroup
# We want clients to be able to login with "anonymous" as well as "ftp"
UserAlias anonymous ftp
# Cosmetic changes, all files belongs to ftp user
DirFakeUser on ftp
DirFakeGroup on ftp
# Limit the maximum number of anonymous logins
MaxClients 10
# We want ‘welcome.msg’ displayed at login, and ‘.message’ displayed
# in each newly chdired directory.
DisplayFirstChdir .message
# Limit WRITE everywhere in the anonymous chroot
<Directory *>
<Limit WRITE>
DenyAll
</Limit>
</Directory>
# Uncomment this if you’re brave.
# <Directory incoming>
# # Umask 022 is a good standard umask to prevent new files and dirs
# # (second parm) from being group and world writable.
# Umask 022 022
# <Limit READ WRITE>
# DenyAll
# </Limit>
# <Limit STOR>
# AllowAll
# </Limit>
# </Directory>
</Anonymous>
<Global>
</Global>
[/code:1]
neorf
#5
[code:1]
UseIPv6 on
ServerName "Debian"
DeferWelcome off
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutStalled 600
TimeoutIdle 1200
ListOptions "-l"
DenyFilter *.*/
DefaultRoot ~
Port 21
(such as xinetd)
MaxInstances 30
User proftpd
Group nogroup
Umask 022 022
AllowOverwrite on
UseSendFile off
SQLBackend mysql
#</IfModule>
QuotaEngine off
</IfModule>
Ratios off
</IfModule>
DelayEngine on
</IfModule>
ControlsEngine off
ControlsInterval 5
</IfModule>
</IfModule>
<Anonymous ~ftp>
User ftp
Group nogroup
DirFakeUser on ftp
DirFakeGroup on ftp
MaxClients 10
<Directory *>
<Limit WRITE>
DenyAll
</Limit>
</Directory>
# Umask 022 022
# DenyAll
# </Limit>
# <Limit STOR>
# AllowAll
# </Limit>
# </Directory>
</Anonymous>
<Global>
</Global>
[/code:1]
kjertil
October 19, 2012, 1:12pm
#6
Hello!
Does virtualmin have support for this directive, cause i can’t seem to find it anywhere?
[code:1] AllowOverwrite on [/code:1]
Adding it to the conf file manually works fine, though!
dan74mm
August 17, 2014, 10:45pm
#7
