I just installed Virtualmin on a fresh server in order to migrate.
I am having the issue described below when I check the configuration:
Your system has 7.81 GB of memory, which is at or above the Virtualmin recommended minimum of 256 MB.
Apache is installed.
Webalizer is installed.
Apache is configured to host SSL websites.
MySQL is installed and running.
ProFTPd is installed.
Logrotate is installed.
The Procmail program needed for spam filtering does not appear to be installed on your system, or has not yet been set up properly in Webmin's Procmail Mail Filter module. If your system does not use spam filtering, it should be disabled in Virtualmin's module configuration page.
Please advise.
Thank you.
