Problems with ssl
OS type and version ubuntu 20.04
Virtualmin version 7.7 pro
can anyone help me im trying to setup letsencypt but i keep getting this error
The server/domain needs a real world IP, not a 192.168.xxx.xxx IP.
expanding on this, maybe just change your hosts file to reflect your real world IP using webmin->Network Configuration->Host Addresses
could you guide me on how to change that or tell me what i need to do please
Just curious, if you use change IP, does the public IP show in the dropdown?
where do i need to look for it on the screenshot on mine
That why I use screensot, the menu on the left shows where to find, and the yellow is the dropdown.
no its not showing any other ip addresses just the one im using
Have you rechecked configuration just to see if it find the public IP (not very hopeful) Else you will need to add the IP in Webmin -->Network Configuration. I haven’t done that for many years (like at least 5).
click on the current interface (ip), see what options you have
Add virtual interface, this is “maybe” where you can add the public IP
this what showing in my host inter face
You could try changing the private to public ip on last line.
ok i will try that firist and see what happens
this is what is showing up in my ssl
worked by the looks
so i dont need to do anything to change anything
Screenshot_6
ok, please see if you can now change ip on the virtualserver
cert not from lets encrypt
shared address please change, use the letsencrpt if you can. don’t buy certificate unless you need to.
