Problems with domain name in postfix configuration
I made a typo in the Internet domain name (baleoproducciones.ar, where it should say baleroproducciones.ar) in the general settings/other general settings of Postfix. When I correct it, my emails stop coming in, even though I can send.
Main.cf
meta_directory = /etc/postfix
shlib_directory = /usr/lib64/postfix
sender_dependent_default_transport_maps = hash:/etc/postfix/dependent
home_mailbox = Maildir/
smtpd_sasl_auth_enable = yes
broken_sasl_auth_clients = no
smtpd_recipient_restrictions =
permit_mynetworks,
permit_sasl_authenticated,
reject_non_fqdn_recipient,
reject_unknown_recipient_domain,
reject_unlisted_recipient,
reject_unauth_destination,
check_sender_access hash:/etc/postfix/sender_access
#reject_rbl_client zen.spamhaus.org,
#reject_rbl_client bl.spamcop.net,
smtpd_sender_restrictions =
permit_mynetworks,
reject_non_fqdn_sender,
reject_unknown_sender_domain,
reject_authenticated_sender_login_mismatch,
smtp_dns_support_level = dnssec
smtp_host_lookup = dns
mailbox_size_limit = 0
allow_percent_hack = No
resolve_dequoted_address = no
milter_default_action = accept
smtpd_milters = inet:127.0.0.1:8891
non_smtpd_milters = inet:127.0.0.1:8891
tls_server_sni_maps = hash:/etc/postfix/sni_map
mynetworks_style = subnet
mydomain = baleoproducciones.ar
mydestination = $mydomain
myorigin = $mydomain
message_size_limit = 50240000
smtpd_banner = vps.baleroproducciones.ar
Avoid Backscatter by rejecting non-existent users instead of bouncing
smtpd_reject_unlisted_recipient = yes
smtpd_reject_unlisted_sender = yes
unknown_local_recipient_reject_code = 550
These are the corresponding entries in the virtual file
baleroar@baleroproducciones.ar baleroar
baleroproducciones.ar baleroproducciones.ar
info@baleroproducciones.ar info@baleroproducciones.ar
You don’t need to set mydomain explicitly, and most people definitely should not.
While we’re on the subject, most people should not set myorigin, either.
Oh, but your problem is this:
That’s very wrong, and it’s why mail is being rejected.
That should be something like this:
mydestination = $myhostname, localhost.$mydomain, localhost
Your domain doesn’t need to be specified in main.cf because it’s specified in virtual maps. You’re going to break things by trying to have two things with the same name. It’s either virtual or in main.cf, it’s not supposed to be in both.
From the comments in main.cf:
# Do not specify the names of virtual domains - those domains are
# specified elsewhere (see VIRTUAL_README).
Hi Joe!. Thanks for your help. So as I understand y should let mydomain empty? And of course puti in virtual
Thanks again.
