SYSTEM INFORMATION | |
OS type and version | Ubuntu Linux 20.04.6 |
Virtualmin version | 7.7 Pro |
im having problems with setting up dns records as my dns server is with namecheap dns servers and im getting this error im using nginx and not apache
yes i did that
Thats not a error, thats the suggested dns records, mine looks the same.
yeah, some work to do. create a A record for mail like in the suggest DNS. Using the DNS Record dropdown I see 127.0.0.1, please remove that A record, the rest of the world don’t need to know that, even though there is one in the suggested.
ok how do i remove them on namecheap as well as virtualmin too
you don’t need to touch Virtualmin, they just suggested dns records and you can’t edit it. Thats Virtualmin just suggesting what records you should add to the working DNS server.
You can add other records you want. As if you want to send mail, you will also need to add SPF, DKIM and DMARC records.
oh right ok i understand now sorry im a bit slow at learning things as i have a learning disabilaty
but im still willing to learn new things and not letting it stop me too no matter how hard things are
select add record and add all the missing records from the suggested records. don’t bother with the 127.0.01 record though.
ok thank you
