I used the normal install.sh installer but have a raft of issues:
INFO - Installing Virtualmin and all related packages now using the command:
INFO - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base
...in progress, please wait...
.E: Unable to locate package virtualmin-base
/usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
Need to get 1484 B of archives.
After this operation, 29.7 kB of additional disk space will be used.
Get:1 http://de.archive.ubuntu.com/ubuntu/ precise/main apache2 amd64 2.2.22-1ubuntu1 [1484 B]
Fetched 1484 B in 0s (25.0 kB/s)
Selecting previously unselected package apache2.
(Reading database … 83379 files and directories currently installed.)
Unpacking apache2 (from …/apache2_2.2.22-1ubuntu1_amd64.deb) …
Setting up apache2 (2.2.22-1ubuntu1) …
INFO - 2012-07-30 15:32:58 - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip libfcgi-dev bind9 spamassassin spamc procmail libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common postgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-custom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libgd2-xpm libapache2-mod-php5 php5-mysql: Succeeded.
INFO - 2012-07-30 15:32:58 - Succeeded.
INFO - 2012-07-30 15:32:58 - Installing Virtualmin and all related packages now using the command:
INFO - 2012-07-30 15:32:58 - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base
Reading package lists…
Building dependency tree…
Reading state information…
WARN - apt-get seems to have failed. Are you sure your OS and version is supported?
WARN - http://www.virtualmin.com/os-support
FATAL - Fatal Error Occurred: Installation failed: 0
