The following are some of the errors encountered when trying to install virualmin
Error: Package: php-gd-5.3.3-14.el6_3.x86_64 (updates)
Requires: php-common = 5.3.3-14.el6_3
Installed: php-common-5.3.19-1.el6.remi.x86_64 (@remi)
php-common = 5.3.19-1.el6.remi
Available: php-common-5.3.3-3.el6_2.8.x86_64 (base)
php-common = 5.3.3-3.el6_2.8
Available: php-common-5.3.3-14.el6_3.x86_64 (updates)
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
—> Package php-gd.x86_64 0:5.3.3-14.el6_3 will be installed
–> Processing Dependency: php-common = 5.3.3-14.el6_3 for package: php-gd-5.3.3-14.el6_3.x86_64
—> Package php-imap.x86_64 0:5.3.3-14.el6_3 will be installed
–> Processing Dependency: php-common = 5.3.3-14.el6_3 for package: php-imap-5.3.3-14.el6_3.x86_64
—> Package php-mbstring.x86_64 0:5.3.3-14.el6_3 will be installed
–> Processing Dependency: php-common = 5.3.3-14.el6_3 for package: php-mbstring-5.3.3-14.el6_3.x86_64
—> Package php-pgsql.x86_64 0:5.3.3-14.el6_3 will be installed
–> Processing Dependency: php-common = 5.3.3-14.el6_3 for package: php-pgsql-5.3.3-14.el6_3.x86_64
—> Package php-snmp.x86_64 0:5.3.3-14.el6_3 will be installed
–> Processing Dependency: php-common = 5.3.3-14.el6_3 for package: php-snmp-5.3.3-14.el6_3.x86_64
—> Package php-xmlrpc.x86_64 0:5.3.3-14.el6_3 will be installed
–> Processing Dependency: php-common = 5.3.3-14.el6_3 for package: php-xmlrpc-5.3.3-14.el6_3.x86_64
–> Finished Dependency Resolution
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Then eventually going FATAL
FATAL - Fatal Error Occurred: Something went wrong during installation: 0
My php version is PHP 5.3.19 and apparently, from the error log, the script expects a different version of php. is there a way to get around this problem please? Thanks
