[code:1]Python module subversion is required …
Installing package python-subversion …
Installing package(s) with command yum -y install python-subversion ..
Loading "installonlyn" plugin
Setting up Install Process
Setting up repositories
Reading repository metadata in from local files
Parsing package install arguments
Nothing to do
.. install complete.
I’m under the impression that you shouldn’t need to go to a third party software repository in order to install any of the programs from the Script Installers. Things can go awry when you start using unsupported software.
While “python-subversion” is in fact provided by the “subversion” package in the DAG RPM repository, I highly recommend against using it – what I would do is file a Virtualmin bug report and see what they had in mind for how you’d get Trac installed on CentOS.
i just checked on my (default) centos system.
subversion is a default package from Centos base repository:
Package subversion - 1.4.2-2.el5.i386.
which can be installed with yum install subversion
what I think it may be is that the install script says::yum -y install python-subversion" and that is not in centos, so it wouldn’t know what to do with that command.
submitting a ticket is a good idea to get this corrected.
Oops. There is no need for a python-subversion package on CentOS (or any of the Red Hat based systems). It’s already installed as part of the subversion package. It’s a bug in detection, as the module is actually named “svn”. I’ll update the ticket and hand it over to Jamie for fixing.
