I have successfully installed Webmin with Virtualmin extension, I have also successfully added new virtual server (domain), but there is the problem… some ISP does not work correctly with subdomains of this domain…
For example:
ping www.xxx.info - does not work (is not responding and does not show webpage)
ping xxx.info - works fine (responds, and shows webpage).
I have already tried to reinstall OS, webmin and virtualmin, but still the same.
NS records for domain xxx.info are configured correctly.
under the webmin section you need to go to the networking module-Network Configuration, then go to Hostname and DNS Client to change the hostname of the server.
or ssh into the server and type: hostname something.domain.tld
It sounds like a DNS issue of some sort, but I’m not sure what.
If you put the “xxx.info” domain into the intodns.com site, does it check out okay? I think it was another domain you had tried in there.
Beyond that – I guess we’d need to see what the specific domain name is that’s not working to be able to help diagnose the problem you’re seeing.
