i’ve tried to install postgrey via virtualmi, i go this log…
what have i to do to fix it? however under postgrey i see a buttun with: “enable postgrey” and try to configure it… will it work?
Installing package(s) with command apt-get -y --force-yes -f install postgrey ..
Reading package lists...
Building dependency tree...
Reading state information...
The following extra packages will be installed:
libberkeleydb-perl libio-multiplex-perl libnet-cidr-perl libnet-server-perl
Suggested packages:
libio-socket-ssl-perl
Recommended packages:
libnet-rblclient-perl libparse-syslog-perl
The following NEW packages will be installed:
postgrey
0 upgraded, 5 newly installed, 0 to remove and 10 not upgraded.
Need to get 370kB of archives.
After this operation, 1384kB of additional disk space will be used.
Get:1 ftp://mir1.ovh.net hardy/main libberkeleydb-perl 0.32-0ubuntu1 [140kB]
Get:2 ftp://mir1.ovh.net hardy/main libio-multiplex-perl 1.09-1 [22.6kB]
Get:3 ftp://mir1.ovh.net hardy/main libnet-cidr-perl 0.11-2 [14.3kB]
Get:4 ftp://mir1.ovh.net hardy/main libnet-server-perl 0.97-1ubuntu1 [141kB]
Get:5 ftp://mir1.ovh.net hardy/universe postgrey 1.31-2 [52.0kB]
Fetched 370kB in 0s (944kB/s)
Selecting previously deselected package libberkeleydb-perl.
(Reading database ... 70388 files and directories currently installed.)
Unpacking libberkeleydb-perl (from .../libberkeleydb-perl_0.32-0ubuntu1_i386.deb) ...
Selecting previously deselected package libio-multiplex-perl.
Unpacking libio-multiplex-perl (from .../libio-multiplex-perl_1.09-1_all.deb) ...
Selecting previously deselected package libnet-cidr-perl.
Unpacking libnet-cidr-perl (from .../libnet-cidr-perl_0.11-2_all.deb) ...
Selecting previously deselected package libnet-server-perl.
Unpacking libnet-server-perl (from .../libnet-server-perl_0.97-1ubuntu1_all.deb) ...
Selecting previously deselected package postgrey.
Unpacking postgrey (from .../postgrey_1.31-2_all.deb) ...
Setting up libberkeleydb-perl (0.32-0ubuntu1) ...
Setting up libio-multiplex-perl (1.09-1) ...
Setting up libnet-cidr-perl (0.11-2) ...
Setting up libnet-server-perl (0.97-1ubuntu1) ...
Setting up postgrey (1.31-2) ...
Warning: The home dir /var/lib/postgrey you specified can't be accessed: No such file or directory
Adding system user `postgrey' (UID 114) ...
Adding new group `postgrey' (GID 120) ...
Adding new user `postgrey' (UID 114) with group `postgrey' ...
Not creating home directory `/var/lib/postgrey'.
Creating config file /etc/postgrey/whitelist_clients with new version
Creating config file /etc/postgrey/whitelist_recipients with new version
Creating config file /etc/default/postgrey with new version
Starting postfix greylisting daemon: postgrey.
.. install complete.
… installation failed!
