problem with postgres
hi
suddenly I cant make postgres sql databases for user.
is keeps adding \\ into the username (dont replace the . with underscore
so username will be someone\\.com, instead of someone_com
this username cant de deleted either
That could be a bug in how it’s escaping some characters.
My recommendation would be to file a bug report, using the “Support” link above – and Jamie will be able to work with you to resolve that.
Thanks!
