we are trying to deploy some installations of virtualmin GPL on machine without postfix installed.
But when try to "rechek" virtualmin configuration we get this log:
Checking Configuration
Apache is installed.
Webalizer is installed.
MySQL is installed and running.
Logrotate is installed.
Using network interface eth0 for virtual IPs.
Default IP address for virtual servers is x.x.x.x
Failed to query Postfix config command to get the current value of parameter virtual_alias_maps:
<- Return to previous page
This happens also if virtual-server/config has mail=0.
Can u pls help?
Specs of machine running virtualmin:
OS Gentoo
Virtualmin 3.49
Webmin 1.350
Is postfix still running though? I know nothing about Gentoo so VM might still be lulled into looking for a place to setup virtmapping if an MTA is still running.
The process worked fine on CentOS, THough setting it back up is a pain because of the ClamAV problem.
Having another MTA installed shouldn’t cause any trouble. I suspect there’s still something mail-related enabled in your configuration…but I can’t guess what.
I’ll ask Jamie to chime in on this thread. In the meantime, you might double check to be sure you have disabled all mail-related features in the Module Configuration.
