Problem with port 443
Hi guys, i got letsencrypt ssl cert for my host domain.com, so im able to access as https://domain.com:10000 and https://domain.com:20000 and HTTP://domain.com, but when i try to access httpS://domain.com i got the error err_connection_refused and no site is visible. I did open the port 443 in my router and in firewallD and through ufw as tcp and udp. I did read thousand of documentation and i found nothing useless. Please, help me
Im running virtualmin in Debian 9 stretch
Ok,so just toensure we are onthe same pathway,
When you install webmin/Virtualmin, you wou,d normally access the webmin/virtualmin administrative interface using https://host.domain.com:10000
(In your case you have setup this access via https://domain.com:10000 (which isnt how i do it)
So the fact you can login to webmin is ok.
Now in order to access a website, i would now need to create a virtualmin/virtual server (this is where virtualhost website directories…ie domain.com public_html would be then automatically created for me.
So do you have any virtual servers created yet?
I suspect your ssl is linked directly to yourserver…that is different from websites on said server…they usually use their own. In your naming your webserver (host) the same as your website url, you are on a pathway potentially with problems. As i said, your server webmin/virtualmin interface should be via url https://host.domain.com:10000 (not https://domain.com.:10000).
Perhaps i misunderstand your problem, however, this is where i think your problems start.i havent explained this as well as i should have…but im using mobile device to reply.
