Problem with FTP don't get server directory
Hi, i did intall Virtualmin and Webmin, I’d create a virtual server. But when i try to access using i get access, but don’t recover any directories frokm the server. Please somebody helpme.
If you can’t see the error pic can see it here http://i40.tinypic.com/6jhunl.png
You may want to try the suggestion at the end of this article titled “The FTP Service isn’t working”:
http://www.virtualmin.com/documentation/web/faq
I had a similar issue and the link solved it! Thanks!
that issue related to firewall rules and ftp server passive ftp port ranges.
you need add passive port range to ftp server and then add these ports range to firewall and that will fix your issue!
also you can try
modprobe ip_conntrack_ftp
