problem with filesystem backup
i’ve webmin under virtualmin. i scheduled filesystem backup 1 month ago. first time was ok, but today backup failed with these errors. what is wrong? thanks…
neorf
<code>
Backup of / on myserver.com
tar: Removing leading `/' from member names
tar: Removing leading `/' from hard link targets
tar: /home/log/auth.log: file changed as we read it
tar: /dev/log: socket ignored
tar: /tmp: file changed as we read it
tar: /var/lib/mysql/server1 /jos_bsq_hit.MYD: file changed as we read it
tar: /var/run/proftpd/proftpd.sock: socket ignored
tar: /var/run/dovecot/auth-worker.9903: socket ignored
tar: /var/run/dovecot/dict-server: socket ignored
tar: /var/run/dovecot/login/default: socket ignored
tar: /var/run/clamav/clamd.ctl: socket ignored
tar: /var/run/postgresql/.s.PGSQL.5432: socket ignored
tar: /var/run/mysqld/mysqld.sock: socket ignored
tar: /var/run/dbus/system_bus_socket: socket ignored
tar: /var/spool/postfix/private/tlsmgr: socket ignored
tar: /var/spool/postfix/private/rewrite: socket ignored
tar: /var/spool/postfix/private/bounce: socket ignored
tar: /var/spool/postfix/private/defer: socket ignored
tar: /var/spool/postfix/private/trace: socket ignored
tar: /var/spool/postfix/private/verify: socket ignored
tar: /var/spool/postfix/private/proxymap: socket ignored
tar: /var/spool/postfix/private/proxywrite: socket ignored
tar: /var/spool/postfix/private/smtp: socket ignored
tar: /var/spool/postfix/private/relay: socket ignored
tar: /var/spool/postfix/private/error: socket ignored
tar: /var/spool/postfix/private/retry: socket ignored
tar: /var/spool/postfix/private/discard: socket ignored
tar: /var/spool/postfix/private/local: socket ignored
tar: /var/spool/postfix/private/virtual: socket ignored
tar: /var/spool/postfix/private/lmtp: socket ignored
tar: /var/spool/postfix/private/anvil: socket ignored
tar: /var/spool/postfix/private/scache: socket ignored
tar: /var/spool/postfix/private/maildrop: socket ignored
tar: /var/spool/postfix/private/uucp: socket ignored
tar: /var/spool/postfix/private/ifmail: socket ignored
tar: /var/spool/postfix/private/bsmtp: socket ignored
tar: /var/spool/postfix/private/scalemail-backend: socket ignored
tar: /var/spool/postfix/private/mailman: socket ignored
tar: /var/spool/postfix/public/cleanup: socket ignored
tar: /var/spool/postfix/public/flush: socket ignored
tar: /var/spool/postfix/public/showq: socket ignored
tar: /var/spool/postfix/var/run/saslauthd/mux: socket ignored
Backup failed!
</code>
Hmm, my best guess is that it’s concerned about the “file changed as we read it” messages above. Which is to be expected when reading the access log of a web server :slight_smile:
The “socket ignored” lines shouldn’t be a problem.
However, nothing in the above indicates an incomplete or problematic backup.
I’d verify that your backups look complete on the backup server – and if so, I think you’re in good shape.
To get rid of those messages, you might consider:
  1. In the backup details, you might consider having it ignore directories such as /tmp. /var/spool/postfix/private/, and the like.
  2. You can rely on the Virtual Server backup (assuming you’ve set one up :wink: to get /home, as well as the MySQL databases. It’s not really possible to get a good backup of mysql through a filesystem backup.
Have a good one!
ok. so i’ve tried again, excluded postfix/private but the same error. now i’m going to exclude entire postfix dir, then what else could i exclude? i do regulary virtual server backup too.
But what does make backup crush? for example after 10 socket ignored?
Thanks…
neorf
Well, again, I think it’s concerned about the “file changed as we read it” messages.
So you’d want to tell it to stop backing up the MySQL databases in /var/lib/mysql (you can use the Virtualmin scheduled backups in “Backup and Restore” to get those).
You might also consider not using that to backup the log files (such as /home/log/auth.log), as log files change frequently.
But, if you want to make sure you have logs around, I’d verify that the Virtual Server backups store those.
i’ve one everything, backup started but this time, after 1 day and half, still doing it, is it possible? last time, 1 month ago, filesystem backup was 1.1Gb in 5 hours.
thanks
neorf
