i didn’t change any of the default settings and everything works fine but when i type doesnotexist.domain1.tld i’m refered to user1.domain1.tld which isn’t perfect but when i type doesnotexist.domain2.tld i’m also refered to user1.domain1.tld which is absolutely horrible.
any ideas how to change the behavour to something like,…
when i type doesnotexist.domain1.tld it should refer to domain1.tld and doesnotexist.domain2.tld should refer to domain2.tld.
I have the same problem.
I have created a virtualserver (domain.tld->1.2.3.4) and a sub-server (sub.domain.tld->1.2.3.4) with the according default settings. Each server has it’s own directory (/var/www/domain/public_html and /var/www/domain/domains/sub.domain/public_html)
The subdomain has a DNS A-Record which redirects to 1.2.3.4 as the domain itself.
(Im using the DNS-server from my provider, and didn’t set up any DNS on my server.)
But when I now enter “domain.tld” or “sub.domain.tld” it always shows the content of “sub.domain.tld”…
Im just new to Virtualmin so please give me a hint where could be the problem…
If you need further information, to identify the problem just let me know.
I did’t had the module “vhost_alias” of the apache activated. Now after activating it via Webmin (Server->Apache Webserver->Global configuration->Configure Apache Modules) the right content is shown.
There is another problem which might occur.
If one of the virtualservers IP-Address (Webmin->Server->Apache Webserver->Exisiting Virt.Hosts [2nd column]) contains “*” or “Any”, then change it to the real IP like “1.2.3.4” because otherwise the document-root e.g. will be ignored…
