problem with domain alias in virtualmin
hi to all, i installed virtual min on my centos vps. i add domain with 4 alias domain.
example my master domain is a.com
my alias domains is a.org ,a .net ,a.info
my problem is when i open website with a.org, site load with a.org name in browser ,but all link in website points to a.com .
but i dont have this porblem in cpanel or directadmin.
how can fix this problem??
cant any one help me ?
You can use domainless hyperlinks. For example, instead of having the hyperlinks as http://a.com/page2.html you could do /page2.html or page2.html (if in the same level on the domain).
Are the links in your code already domainless hyperlinks or do they have the a.com in them?
Justin
hi justin, thank for you answer.
i use wordpress cms.
when i add page to menu in wordpress,only show the page name in settings,after load the website you see the full hyprlink with a.com in links.
for example you see page2 in the settings.after load in website ,you see http://a.com/page2.html
I would recommend reading this: http://wordpress.org/support/topic/domain-alias and considering the pros and cons with SEO, etc and use that code if you feel you would want to.
Justin
tnx my firend,i saw that wordpress link, but it does not working , when i use this code , only my master domain loading the website. and other domain said problem in loading website.
why we dont have this problem in domain parking in cpanel?
plz help me.
