Problem upgrading to pro from virtualmin gpl
Got this error when trying to upgrade to virtualmin pro from the gpl interface:
Loading "installonlyn" plugin
Error: Need to pass a list of pkgs to install
usage: yum [options] < grouplist, localinstall, groupinfo, localupdate, resolvedep, erase, deplist, groupremove, makecache, upgrade, provides, shell, install, whatprovides, groupinstall, update, groupupdate, info, search, check-update, list, remove, clean, grouperase >
options:
-h, --help show this help message and exit
-t, --tolerant be tolerant of errors
-C run entirely from cache, don’t update cache
-c [config file] config file location
-R [minutes] maximum command wait time
-d [debug level] debugging output level
-e [error level] error output level
-y answer yes for all questions
–version show Yum version and exit
–installroot=[path] set install root
–enablerepo=[repo] enable one or more repositories (wildcards allowed)
–disablerepo=[repo] disable one or more repositories (wildcards allowed)
-x [package], --exclude=[package]
exclude package(s) by name or glob
–obsoletes enable obsoletes processing during updates
–noplugins disable Yum plugins
None
… done
