Hi. Just updated my certificate on my webserver (“https://server.domain.com:1000”), but I’m not able to update the ceritificates for postfix, dovecot, usermin and webmin, “system wide”, as earlier. Before there was buttons, that did this process so I didnt have to copy/paste anything manually.
The buttons are exchanged with the text: This SSL certificate is already being used by : Postfix, Usermin, Webmin, Dovecot, but I know for sure that the new certificate isn’t the same as in either of the four mentioned. Have opened them and compared the contents.
How can I solve this? Is there a .cgi-script that I can run, or a command, through SSH.
Tried to activate SSL on another domain, and create a self-signed certificate. But the same happens; Virutalmin tells me that all four modules is using this certificate as well. How’s that possible?
See attached screenshot. (https://www.virtualmin.com/files/Virtualmin.png)
