Everything is done perfectly as said this manual. However, when i go to the Virtualmin > Server Configuration > Configure Mail Relay, it tells my that this features is noe enable for this domain. but i have enabled it in the Edit Virtual Server option.
Ok, i’ve went to the server template that is applied to this client account and configured the default mail server for relay, at the plugin configuration menu.
I now get, after enabling Relay Mail Feature for this domain, the following message:
Updating Webmin user …
… done
Setting up mail relaying …
… configured relay to mail.example.com
Saving server details …
… done
Re-loading Webmin …
… done
but i still get the same error when configuring the "Configure Mail Relaying". Meaning, this message "Relaying is not set up for this domain" still appears.
it is a matter of “if” . It was a question. And of course, nobody buy something just for a little thing, but if this thing happend to be in a package, the buyer just wanna see how it’s working. If it’s not working, it shouldn’t be in that package…dont you think?
Have a nice day !
Sorry for the slow reply. I’ve been sick for the past week. Stupid Northern California weather, with its “cold-warm-cold-warm and I never know how to dress” cycles!
Anyway, sounds like a bug. If you’ve configured the module as documented, and it doesn’t work…that’d be worth fixing.
So file a bug in the bug tracker and Jamie will get it fixed quick.
i am sorry , i don’t know how file a bug in bug tracker, i will let others to do that, because i am sure that not only two of us have problem with that module.
And adout that weather, in Romania it’s the same thing, i also catch a cold
