Hello. well i was doing a new install in a new server with new ip but after all of this now i cant send mail. i get this
Jan 25 09:42:11 sp5010b postfix/smtp[27293]: connect to ALT1.ASPMX.L.GOOGLE.com[173.194.65.27]:25: Connection timed out
Jan 25 09:42:11 sp5010b postfix/smtp[27296]: connect to ALT2.aspmx.l.google.com[173.194.70.27]:25: Connection timed out
Jan 25 09:42:11 sp5010b postfix/smtp[27300]: connect to mail.messaging.microsoft.com[207.46.163.30]:25: Connection timed out
Jan 25 09:42:11 sp5010b postfix/smtp[27300]: 066E32691AD: to=Carl.Ratigan2@kraftfoods.com, relay=none, delay=455, delays=395/0.05/60/0, dsn=4.4.1, status=deferred (connect to mail.messaging.microsoft.com[207.46.163.30]:25: Connection timed out)
Jan 25 09:42:32 sp5010b postfix/smtp[27297]: connect to inmobiliaria.co.cr.s10b1.psmtp.com[74.125.244.13]:25: Connection timed out
Jan 25 09:42:41 sp5010b postfix/smtp[27287]: connect to mx2.supremebox.com[209.25.170.16]:25: Connection timed out
Jan 25 09:42:41 sp5010b postfix/smtp[27289]: connect to mx1.supremebox.com[209.25.170.16]:25: Connection timed out
Jan 25 09:42:41 sp5010b postfix/smtp[27299]: connect to mx1.supremebox.com[66.40.66.242]:25: Connection timed out
Jan 25 09:42:41 sp5010b postfix/smtp[27303]: connect to mx.grupovigocr.com[66.96.142.51]:25: Connection timed out
Jan 25 09:42:41 sp5010b postfix/smtp[27303]: D5DE92691A9: to=carlos.soto@grupovigocr.com, relay=none, delay=490, delays=400/0.05/90/0, dsn=4.4.1, status=deferred (connect to mx.grupovigocr.com[66.96.142.51]:25: Connection timed out)
Jan 25 09:42:41 sp5010b postfix/smtp[27301]: connect to alt1.aspmx.l.google.com[173.194.65.27]:25: Connection timed out
Jan 25 09:42:41 sp5010b postfix/smtp[27293]: connect to ALT2.ASPMX.L.GOOGLE.com[173.194.70.27]:25: Connection timed out
Jan 25 09:42:41 sp5010b postfix/smtp[27296]: connect to ALT1.aspmx.l.google.com[173.194.65.27]:25: Connection timed out
Jan 25 09:43:02 sp5010b postfix/smtp[27297]: connect to inmobiliaria.co.cr.s10b2.psmtp.com[74.125.244.14]:25: Connection timed out
Jan 25 09:43:02 sp5010b postfix/smtp[27297]: 6BEC926919E: to=mercadeo@inmobiliaria.co.cr, relay=none, delay=525, delays=414/0.04/111/0, dsn=4.4.1, status=deferred (connect to inmobiliaria.co.cr.s10b2.psmtp.com[74.125.244.14]:25: Connection timed out)
Jan 25 09:43:11 sp5010b postfix/smtp[27287]: connect to mx2.supremebox.com[66.40.66.242]:25: Connection timed out
Jan 25 09:43:11 sp5010b postfix/smtp[27287]: 35218269188: to=acerdas@performiacr.com, relay=none, delay=560, delays=440/0/120/0, dsn=4.4.1, status=deferred (connect to mx2.supremebox.com[66.40.66.242]:25: Connection timed out)
Jan 25 09:43:11 sp5010b postfix/smtp[27289]: connect to mx1.supremebox.com[66.40.66.242]:25: Connection timed out
Jan 25 09:43:11 sp5010b postfix/smtp[27289]: 3EE79269189: to=iramirez@performiacr.com, relay=none, delay=559, delays=439/0.01/120/0, dsn=4.4.1, status=deferred (connect to mx1.supremebox.com[66.40.66.242]:25: Connection timed out)
Jan 25 09:43:11 sp5010b postfix/smtp[27299]: connect to mx1.supremebox.com[209.25.170.16]:25: Connection timed out
Jan 25 09:43:11 sp5010b postfix/smtp[27299]: 5B22526918C: to=evecubero@performiacr.com, relay=none, delay=556, delays=436/0.04/120/0, dsn=4.4.1, status=deferred (connect to mx1.supremebox.com[209.25.170.16]:25: Connection timed out)
Jan 25 09:43:11 sp5010b postfix/smtp[27301]: connect to aspmx2.googlemail.com[173.194.65.27]:25: Connection timed out
Jan 25 09:43:11 sp5010b postfix/smtp[27301]: 7FD52269190: to=info@mimercadeoeficaz.com, relay=none, delay=551, delays=431/0.05/120/0, dsn=4.4.1, status=deferred (connect to aspmx2.googlemail.com[173.194.65.27]:25: Connection timed out)
Jan 25 09:43:11 sp5010b postfix/smtp[27293]: connect to ASPMX2.GOOGLEMAIL.com[173.194.65.27]:25: Connection timed out
Jan 25 09:43:11 sp5010b postfix/smtp[27296]: connect to ASPMX3.GOOGLEMAIL.com[173.194.70.27]:25: Connection timed out
Jan 25 09:43:41 sp5010b postfix/smtp[27293]: connect to ASPMX3.GOOGLEMAIL.com[173.194.70.27]:25: Connection timed out
Jan 25 09:43:41 sp5010b postfix/smtp[27296]: connect to ASPMX4.GOOGLEMAIL.com[173.194.69.27]:25: Connection timed out
Jan 25 09:43:41 sp5010b postfix/smtp[27296]: 6D36426918E: to=allan@enviosmasivoscostarica.com, relay=none, delay=583, delays=433/0.03/150/0, dsn=4.4.1, status=deferred (connect to ASPMX4.GOOGLEMAIL.com[173.194.69.27]:25: Connection timed out)
Jan 25 09:43:41 sp5010b postfix/smtp[27293]: B1D34269184: to=info@mercadeodbm.com, relay=none, delay=614, delays=463/0.02/150/0, dsn=4.4.1, status=deferred (connect to ASPMX3.GOOGLEMAIL.com[173.194.70.27]:25: Connection timed out)
every one in queue is listed as deferred. im not im a nat or blacklisted (i already check it). and this is the far that my knoledge let me to see errors.
ah also i can ping to all those ips from putty, and linux firewall is setup to let smtp pass. sorry for my bad english im in a hurry and cant verify every word
