problem login in virtualmin
hi guys;
I have problem after install virtualmin .
I’m first install webmin and after install it , try to install virtualmin . after install virtualmin I can’t login with my domain and 10000 port . receive " server not found in browser" . I set right hostname and check in with hostname -f .
I’m new usr for virtualmin and webmin , I need help for start working with great opensource cp.
excuse me for bad english :slight_smile:
thanks my friends.
You may want to try accessing Virtualmin using the server’s IP address, rather than the hostname.
Are you able to access port 10000 if you try using the IP address?
thanks my friends , it’s work . but virtualmin needs domain for config . thanks again
