My server already had Webmin 1.780 installed on a RedHat Enterprise 6.5 server. I tried installing Virtualmin but ran into an error.
\Error: Package: virtualmin-base-5.0-1.rh.noarch (virtualmin)
Requires: cyrus-sasl-md5
I tried installing cyrus-sasl-md5-2.1.23-15.el6_6.2.i686.rpm manually but I got the following error:
cyrus-sasl-lib = 2.1.23-15.el6_6.2 is needed by cyrus-sasl-md5-2.1.23-15.el6_6.2.i686
libcrypto.so.10 is needed by cyrus-sasl-md5-2.1.23-15.el6_6.2.i686
libcrypto.so.10(libcrypto.so.10) is needed by cyrus-sasl-md5-2.1.23-15.el6_6.2.i686
libcrypto.so.10 is present at /usr/lib64/ but it is not being detected.
I have the following version of OpenSSL installed.
rpm -qi openssl
Name : openssl Relocations: (not relocatable)
Version : 1.0.1e Vendor: CentOS
Release : 42.el6 Build Date: Thu 23 Jul 2015 03:10:32 PM EDT
Install Date: Tue 01 Mar 2016 10:03:23 AM EST Build Host: c6b9.bsys.dev.centos.org
Group : System Environment/Libraries Source RPM: openssl-1.0.1e-42.el6.src.rpm
Size : 4227731 License: OpenSSL
Signature : RSA/SHA1, Fri 24 Jul 2015 04:38:27 PM EDT, Key ID 0946fca2c105b9de
Packager : CentOS BuildSystem http://bugs.centos.org
URL : http://www.openssl.org/
Summary : A general purpose cryptography library with TLS implementation
Description :
The OpenSSL toolkit provides support for secure communications between
machines. OpenSSL includes a certificate management tool and shared
libraries which provide various cryptographic algorithms and
protocols.
Below is the complete log file:
INFO - 2016-02-28 14:01:59 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-02-28 14:01:59 - Install mode: full
DEBUG - 2016-02-28 14:01:59 - Product: Virtualmin GPL
DEBUG - 2016-02-28 14:01:59 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-02-28 14:01:59 - install.sh version: 1.1.2
INFO - 2016-02-28 14:01:59 - Checking for fully qualified hostname…
INFO - 2016-02-28 14:01:59 - Hostname OK: fully qualified as ns.myhost.com
INFO - 2016-02-28 14:01:59 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-02-28 14:01:59 - Loading OS selection library…
INFO - 2016-02-28 14:01:59 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-02-28 14:01:59 - Loading OS list…
INFO - 2016-02-28 14:01:59 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-02-28 14:01:59 - Operating system name: Red Hat Enterprise Linux
INFO - 2016-02-28 14:01:59 - Operating system version: 6
INFO - 2016-02-28 14:01:59 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2016-02-28 14:01:59 - Disabling SELinux during installation…
DEBUG - 2016-02-28 14:02:00 - setenforce 0 succeeded
INFO - 2016-02-28 14:02:00 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2016-02-28 14:02:59 - Succeeded.
INFO - 2016-02-28 14:02:59 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Loaded plugins: product-id, rhnplugin, security, subscription-manager
Setting up Install Process
No package bind available.
No package caching-nameserver available.
No package perl-DBD-Pg available.
No package mailman available.
No package subversion available.
No package mysql-devel available.
No package mariadb available.
No package mariadb-server available.
No package postgresql-server available.
No package rh-postgresql available.
No package rh-postgresql-server available.
No package php-imap available.
No package php-odbc available.
No package php-pgsql available.
No package php-snmp available.
No package php-xmlrpc available.
No package php-mbstring available.
No package mod_python available.
No package dovecot available.
No package mod_dav_svn available.
No package ruby available.
No package ruby-devel available.
No package rubygems available.
No package perl-XML-Simple available.
No package perl-LWP-Protocol-https available.
Resolving Dependencies
–> Running transaction check
—> Package httpd.x86_64 0:2.2.15-29.el6_4 will be updated
–> Processing Dependency: httpd = 2.2.15-29.el6_4 for package: httpd-manual-2.2.15-29.el6_4.noarch
—> Package httpd.x86_64 1:2.2.15-47.el6.vm will be an update
–> Processing Dependency: httpd-tools = 1:2.2.15-47.el6.vm for package: 1:httpd-2.2.15-47.el6.vm.x86_64
—> Package mod_ssl.x86_64 1:2.2.15-29.el6_4 will be updated
—> Package mod_ssl.x86_64 2:2.2.15-47.el6.vm will be an update
—> Package httpd-manual.noarch 0:2.2.15-29.el6_4 will be updated
—> Package httpd-manual.noarch 1:2.2.15-47.el6.vm will be an update
—> Package httpd-tools.x86_64 0:2.2.15-29.el6_4 will be updated
—> Package httpd-tools.x86_64 1:2.2.15-47.el6.vm will be an update
–> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Updating:
httpd x86_64 1:2.2.15-47.el6.vm virtualmin 828 k
mod_ssl x86_64 2:2.2.15-47.el6.vm virtualmin 94 k
Updating for dependencies:
httpd-manual noarch 1:2.2.15-47.el6.vm virtualmin 786 k
httpd-tools x86_64 1:2.2.15-47.el6.vm virtualmin 76 k
Transaction Summary
Upgrade 4 Package(s)
Total download size: 1.7 M
Downloading Packages:
Total 1.2 MB/s | 1.7 MB 00:01
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Updating : 1:httpd-tools-2.2.15-47.el6.vm.x86_64 1/8
Updating : 1:httpd-2.2.15-47.el6.vm.x86_64 2/8
warning: /etc/httpd/conf/httpd.conf created as /etc/httpd/conf/httpd.conf.rpmnew
Updating : 2:mod_ssl-2.2.15-47.el6.vm.x86_64 3/8
warning: /etc/httpd/conf.d/ssl.conf created as /etc/httpd/conf.d/ssl.conf.rpmnew
Updating : 1:httpd-manual-2.2.15-47.el6.vm.noarch 4/8
Cleanup : httpd-manual-2.2.15-29.el6_4.noarch 5/8
Cleanup : 1:mod_ssl-2.2.15-29.el6_4.x86_64 6/8
Cleanup : httpd-2.2.15-29.el6_4.x86_64 7/8
Cleanup : httpd-tools-2.2.15-29.el6_4.x86_64 8/8
Verifying : 2:mod_ssl-2.2.15-47.el6.vm.x86_64 1/8
Verifying : 1:httpd-manual-2.2.15-47.el6.vm.noarch 2/8
Verifying : 1:httpd-2.2.15-47.el6.vm.x86_64 3/8
Verifying : 1:httpd-tools-2.2.15-47.el6.vm.x86_64 4/8
Verifying : httpd-2.2.15-29.el6_4.x86_64 5/8
Verifying : httpd-manual-2.2.15-29.el6_4.noarch 6/8
Verifying : 1:mod_ssl-2.2.15-29.el6_4.x86_64 7/8
Verifying : httpd-tools-2.2.15-29.el6_4.x86_64 8/8
Updated:
httpd.x86_64 1:2.2.15-47.el6.vm mod_ssl.x86_64 2:2.2.15-47.el6.vm
Dependency Updated:
httpd-manual.noarch 1:2.2.15-47.el6.vm httpd-tools.x86_64 1:2.2.15-47.el6.vm
Complete!
INFO - 2016-02-28 14:06:20 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https: Succeeded.
INFO - 2016-02-28 14:06:20 - Succeeded.
INFO - 2016-02-28 14:06:20 - Installing Virtualmin and all related packages now using the command:
INFO - 2016-02-28 14:06:20 - yum clean all
INFO - 2016-02-28 14:10:21 - yum -y -d 2 install virtualmin-base
Could not retrieve mirrorlist http://apt.sw.be/redhat/el6/en/mirrors-rpmforge error was
12: Timeout on http://apt.sw.be/redhat/el6/en/mirrors-rpmforge: (28, ‘connect() timed out!’)
FATAL - 2016-02-28 14:15:17 - Fatal Error Occurred: Installation failed: 0
FATAL - 2016-02-28 14:15:17 - Cannot continue installation.
FATAL - 2016-02-28 14:15:17 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-02-28 14:15:17 - re-attempted after any problems have been resolved.
FATAL - 2016-02-28 14:15:18 - Removing temporary directory and files.
FATAL - 2016-02-28 14:15:18 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-02-28 14:15:18 - in /root/virtualmin-install.log
INFO - 2016-02-28 14:26:06 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-02-28 14:26:06 - Install mode: full
DEBUG - 2016-02-28 14:26:06 - Product: Virtualmin GPL
DEBUG - 2016-02-28 14:26:06 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-02-28 14:26:06 - install.sh version: 1.1.2
INFO - 2016-02-28 14:26:06 - Checking for fully qualified hostname…
INFO - 2016-02-28 14:26:07 - Hostname OK: fully qualified as ns.myhost.com
INFO - 2016-02-28 14:26:07 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-02-28 14:26:07 - Loading OS selection library…
INFO - 2016-02-28 14:26:07 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-02-28 14:26:07 - Loading OS list…
INFO - 2016-02-28 14:26:07 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-02-28 14:26:07 - Operating system name: Red Hat Enterprise Linux
INFO - 2016-02-28 14:26:07 - Operating system version: 6
INFO - 2016-02-28 14:26:07 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2016-02-28 14:26:07 - Disabling SELinux during installation…
DEBUG - 2016-02-28 14:26:07 - setenforce 0 succeeded
INFO - 2016-02-28 14:26:07 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2016-02-28 14:26:10 - Succeeded.
INFO - 2016-02-28 14:26:10 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
FATAL - 2016-02-28 14:27:12 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2016-02-28 14:27:12 - Cannot continue installation.
FATAL - 2016-02-28 14:27:13 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-02-28 14:27:13 - re-attempted after any problems have been resolved.
FATAL - 2016-02-28 14:27:14 - Removing temporary directory and files.
FATAL - 2016-02-28 14:27:14 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-02-28 14:27:14 - in /root/virtualmin-install.log
INFO - 2016-02-28 14:34:06 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-02-28 14:34:06 - Install mode: full
DEBUG - 2016-02-28 14:34:06 - Product: Virtualmin GPL
DEBUG - 2016-02-28 14:34:06 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-02-28 14:34:06 - install.sh version: 1.1.2
INFO - 2016-02-28 14:34:06 - Checking for fully qualified hostname…
INFO - 2016-02-28 14:34:06 - Hostname OK: fully qualified as ns.myhost.com
INFO - 2016-02-28 14:34:06 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-02-28 14:34:06 - Loading OS selection library…
INFO - 2016-02-28 14:34:06 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-02-28 14:34:06 - Loading OS list…
INFO - 2016-02-28 14:34:06 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-02-28 14:34:06 - Operating system name: Red Hat Enterprise Linux
INFO - 2016-02-28 14:34:06 - Operating system version: 6
INFO - 2016-02-28 14:34:06 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2016-02-28 14:34:06 - Disabling SELinux during installation…
DEBUG - 2016-02-28 14:34:06 - setenforce 0 succeeded
INFO - 2016-02-28 14:34:06 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2016-02-28 14:34:09 - Succeeded.
INFO - 2016-02-28 14:34:09 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Package 1:httpd-2.2.15-47.el6.vm.x86_64 already installed and latest version
Package 2:mod_ssl-2.2.15-47.el6.vm.x86_64 already installed and latest version
Nothing to do
INFO - 2016-02-28 14:35:26 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https: Succeeded.
INFO - 2016-02-28 14:35:26 - Succeeded.
INFO - 2016-02-28 14:35:26 - Installing Virtualmin and all related packages now using the command:
INFO - 2016-02-28 14:35:26 - yum clean all
INFO - 2016-02-28 14:35:27 - yum -y -d 2 install virtualmin-base
—> Package virtualmin-base.noarch 0:5.0-1.rh will be installed
–> Processing Dependency: usermin >= 1.600 for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbt-virtual-server-theme for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbt-virtual-server-mobile for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-virtualmin-svn for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-virtualmin-sqlite for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-virtualmin-registrar for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-virtualmin-mailman for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-virtualmin-init for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-virtualmin-htpasswd for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-virtualmin-git for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-virtualmin-dav for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-virtualmin-awstats for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-virtual-server for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-security-updates for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-ruby-gems for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: wbm-php-pear for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: ust-virtual-server-theme for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: scponly for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: proftpd for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: procmail-wrapper for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: perl(IO::Tty) for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: mod_fcgid for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: mod_dav_svn for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: cyrus-sasl-md5 for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: clamav for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: awstats for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: /usr/sbin/clamd for package: virtualmin-base-5.0-1.rh.noarch
–> Processing Dependency: /usr/bin/freshclam for package: virtualmin-base-5.0-1.rh.noarch
—> Package awstats.noarch 0:7.1-1.el6.rf will be installed
–> Processing Dependency: perl(Geo::IP) for package: awstats-7.1-1.el6.rf.noarch
—> Package clamav.x86_64 0:0.98.5-1.el6 will be installed
–> Processing Dependency: clamav-db = 0.98.5-1.el6 for package: clamav-0.98.5-1.el6.x86_64
—> Package clamd.x86_64 0:0.98.5-1.el6 will be installed
—> Package mod_fcgid.x86_64 0:2.3.7-1.el6 will be installed
—> Package perl-IO-Tty.x86_64 0:1.08-3.el6 will be installed
—> Package procmail-wrapper.x86_64 0:1.0-1.vm will be installed
—> Package proftpd.x86_64 0:1.3.4a-1.el6.rf will be installed
–> Processing Dependency: perl(Mail::Sendmail) for package: proftpd-1.3.4a-1.el6.rf.x86_64
—> Package scponly.x86_64 0:4.8-6.el6 will be installed
—> Package usermin.noarch 0:1.690-1 will be installed
—> Package ust-virtual-server-theme.noarch 2:6.9-1 will be installed
—> Package wbm-php-pear.noarch 2:1.5-1 will be installed
—> Package wbm-ruby-gems.noarch 2:1.4-1 will be installed
—> Package wbm-security-updates.noarch 2:4.5-1 will be installed
—> Package wbm-virtual-server.noarch 0:5.0.gpl-1 will be installed
—> Package wbm-virtualmin-awstats.noarch 2:5.1-1 will be installed
—> Package wbm-virtualmin-dav.noarch 2:3.8-1 will be installed
—> Package wbm-virtualmin-git.noarch 0:1.6-1 will be installed
—> Package wbm-virtualmin-htpasswd.noarch 2:2.6-1 will be installed
—> Package wbm-virtualmin-init.noarch 2:2.5-1 will be installed
—> Package wbm-virtualmin-mailman.noarch 2:6.3-1 will be installed
—> Package wbm-virtualmin-registrar.noarch 2:2.2-1 will be installed
—> Package wbm-virtualmin-sqlite.noarch 0:1.4-1 will be installed
—> Package wbm-virtualmin-svn.noarch 2:5.1-1 will be installed
—> Package wbt-virtual-server-mobile.noarch 2:2.5-1 will be installed
—> Package wbt-virtual-server-theme.noarch 2:9.0-2 will be installed
—> Package clamav-db.x86_64 0:0.98.5-1.el6 will be installed
—> Package perl-Geo-IP.x86_64 0:1.38-1.el6.rf will be installed
–> Processing Dependency: libGeoIP.so.1()(64bit) for package: perl-Geo-IP-1.38-1.el6.rf.x86_64
—> Package perl-Mail-Sendmail.noarch 0:0.79-1.2.el6.rf will be installed
—> Package GeoIP.x86_64 0:1.4.7-0.1.20090931cvs.el6 will be installed
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
FATAL - 2016-02-28 14:37:05 - Fatal Error Occurred: Installation failed: 0
FATAL - 2016-02-28 14:37:05 - Cannot continue installation.
FATAL - 2016-02-28 14:37:05 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-02-28 14:37:05 - re-attempted after any problems have been resolved.
FATAL - 2016-02-28 14:37:05 - Removing temporary directory and files.
FATAL - 2016-02-28 14:37:05 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-02-28 14:37:05 - in /root/virtualmin-install.log
INFO - 2016-02-28 14:41:23 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-02-28 14:41:23 - Install mode: full
DEBUG - 2016-02-28 14:41:23 - Product: Virtualmin GPL
DEBUG - 2016-02-28 14:41:23 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-02-28 14:41:23 - install.sh version: 1.1.2
INFO - 2016-02-28 14:41:23 - Checking for fully qualified hostname…
INFO - 2016-02-28 14:41:23 - Hostname OK: fully qualified as ns.myhost.com
INFO - 2016-02-28 14:41:23 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-02-28 14:41:23 - Loading OS selection library…
INFO - 2016-02-28 14:41:23 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-02-28 14:41:23 - Loading OS list…
INFO - 2016-02-28 14:41:24 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-02-28 14:41:24 - Operating system name: Red Hat Enterprise Linux
INFO - 2016-02-28 14:41:24 - Operating system version: 6
INFO - 2016-02-28 14:41:24 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2016-02-28 14:41:24 - Disabling SELinux during installation…
DEBUG - 2016-02-28 14:41:24 - setenforce 0 succeeded
INFO - 2016-02-28 14:41:24 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2016-02-28 14:41:26 - Succeeded.
INFO - 2016-02-28 14:41:27 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Nothing to do
INFO - 2016-02-28 14:41:38 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https: Succeeded.
INFO - 2016-02-28 14:41:38 - Succeeded.
INFO - 2016-02-28 14:41:38 - Installing Virtualmin and all related packages now using the command:
INFO - 2016-02-28 14:41:38 - yum clean all
INFO - 2016-02-28 14:41:39 - yum -y -d 2 install virtualmin-base
FATAL - 2016-02-28 14:43:20 - Fatal Error Occurred: Installation failed: 0
FATAL - 2016-02-28 14:43:20 - Cannot continue installation.
FATAL - 2016-02-28 14:43:20 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-02-28 14:43:20 - re-attempted after any problems have been resolved.
FATAL - 2016-02-28 14:43:20 - Removing temporary directory and files.
FATAL - 2016-02-28 14:43:20 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-02-28 14:43:20 - in /root/virtualmin-install.log
INFO - 2016-02-28 14:46:09 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-02-28 14:46:09 - Install mode: full
DEBUG - 2016-02-28 14:46:09 - Product: Virtualmin GPL
DEBUG - 2016-02-28 14:46:09 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-02-28 14:46:09 - install.sh version: 1.1.2
INFO - 2016-02-28 14:46:09 - Checking for fully qualified hostname…
INFO - 2016-02-28 14:46:09 - Hostname OK: fully qualified as ns.myhost.com
INFO - 2016-02-28 14:46:09 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-02-28 14:46:09 - Loading OS selection library…
INFO - 2016-02-28 14:46:09 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-02-28 14:46:09 - Loading OS list…
INFO - 2016-02-28 14:46:09 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-02-28 14:46:09 - Operating system name: Red Hat Enterprise Linux
INFO - 2016-02-28 14:46:09 - Operating system version: 6
INFO - 2016-02-28 14:46:10 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2016-02-28 14:46:10 - Disabling SELinux during installation…
DEBUG - 2016-02-28 14:46:10 - setenforce 0 succeeded
INFO - 2016-02-28 14:46:10 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2016-02-28 14:46:13 - Succeeded.
INFO - 2016-02-28 14:46:13 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Nothing to do
INFO - 2016-02-28 14:46:18 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https: Succeeded.
INFO - 2016-02-28 14:46:18 - Succeeded.
INFO - 2016-02-28 14:46:18 - Installing Virtualmin and all related packages now using the command:
INFO - 2016-02-28 14:46:18 - yum clean all
INFO - 2016-02-28 14:46:18 - yum -y -d 2 install virtualmin-base
FATAL - 2016-02-28 14:47:55 - Fatal Error Occurred: Installation failed: 0
FATAL - 2016-02-28 14:47:55 - Cannot continue installation.
FATAL - 2016-02-28 14:47:55 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-02-28 14:47:55 - re-attempted after any problems have been resolved.
FATAL - 2016-02-28 14:47:56 - Removing temporary directory and files.
FATAL - 2016-02-28 14:47:56 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-02-28 14:47:56 - in /root/virtualmin-install.log
INFO - 2016-02-28 15:39:21 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-02-28 15:39:21 - Install mode: full
DEBUG - 2016-02-28 15:39:21 - Product: Virtualmin GPL
DEBUG - 2016-02-28 15:39:21 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-02-28 15:39:21 - install.sh version: 1.1.2
INFO - 2016-02-28 15:39:21 - Checking for fully qualified hostname…
INFO - 2016-02-28 15:39:21 - Hostname OK: fully qualified as ns.myhost.com
INFO - 2016-02-28 15:39:21 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-02-28 15:39:21 - Loading OS selection library…
INFO - 2016-02-28 15:39:21 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-02-28 15:39:21 - Loading OS list…
INFO - 2016-02-28 15:39:21 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-02-28 15:39:21 - Operating system name: Red Hat Enterprise Linux
INFO - 2016-02-28 15:39:22 - Operating system version: 6
INFO - 2016-02-28 15:39:22 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2016-02-28 15:39:22 - Disabling SELinux during installation…
DEBUG - 2016-02-28 15:39:22 - setenforce 0 succeeded
INFO - 2016-02-28 15:39:22 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2016-02-28 15:39:25 - Succeeded.
INFO - 2016-02-28 15:39:25 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Nothing to do
INFO - 2016-02-28 15:39:30 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https: Succeeded.
INFO - 2016-02-28 15:39:30 - Succeeded.
INFO - 2016-02-28 15:39:30 - Installing Virtualmin and all related packages now using the command:
INFO - 2016-02-28 15:39:30 - yum clean all
INFO - 2016-02-28 15:39:30 - yum -y -d 2 install virtualmin-base
FATAL - 2016-02-28 15:41:10 - Fatal Error Occurred: Installation failed: 0
FATAL - 2016-02-28 15:41:10 - Cannot continue installation.
FATAL - 2016-02-28 15:41:10 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-02-28 15:41:10 - re-attempted after any problems have been resolved.
FATAL - 2016-02-28 15:41:10 - Removing temporary directory and files.
FATAL - 2016-02-28 15:41:10 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-02-28 15:41:10 - in /root/virtualmin-install.log
INFO - 2016-02-28 15:52:14 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-02-28 15:52:14 - Install mode: full
DEBUG - 2016-02-28 15:52:14 - Product: Virtualmin GPL
DEBUG - 2016-02-28 15:52:14 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-02-28 15:52:14 - install.sh version: 1.1.2
INFO - 2016-02-28 15:52:14 - Checking for fully qualified hostname…
INFO - 2016-02-28 15:52:14 - Hostname OK: fully qualified as ns.myhost.com
INFO - 2016-02-28 15:52:14 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-02-28 15:52:14 - Loading OS selection library…
INFO - 2016-02-28 15:52:15 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-02-28 15:52:15 - Loading OS list…
INFO - 2016-02-28 15:52:15 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-02-28 15:52:15 - Operating system name: Red Hat Enterprise Linux
INFO - 2016-02-28 15:52:15 - Operating system version: 6
INFO - 2016-02-28 15:52:15 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2016-02-28 15:52:15 - Disabling SELinux during installation…
DEBUG - 2016-02-28 15:52:15 - setenforce 0 succeeded
INFO - 2016-02-28 15:52:15 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2016-02-28 15:52:18 - Succeeded.
INFO - 2016-02-28 15:52:18 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Nothing to do
INFO - 2016-02-28 15:52:29 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https: Succeeded.
INFO - 2016-02-28 15:52:29 - Succeeded.
INFO - 2016-02-28 15:52:29 - Installing Virtualmin and all related packages now using the command:
INFO - 2016-02-28 15:52:29 - yum clean all
INFO - 2016-02-28 15:52:29 - yum -y -d 2 install virtualmin-base
FATAL - 2016-02-28 15:54:07 - Fatal Error Occurred: Installation failed: 0
FATAL - 2016-02-28 15:54:07 - Cannot continue installation.
FATAL - 2016-02-28 15:54:07 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-02-28 15:54:07 - re-attempted after any problems have been resolved.
FATAL - 2016-02-28 15:54:07 - Removing temporary directory and files.
FATAL - 2016-02-28 15:54:07 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-02-28 15:54:07 - in /root/virtualmin-install.log
INFO - 2016-02-28 15:54:47 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-02-28 15:54:47 - Install mode: full
DEBUG - 2016-02-28 15:54:47 - Product: Virtualmin GPL
DEBUG - 2016-02-28 15:54:47 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-02-28 15:54:47 - install.sh version: 1.1.2
INFO - 2016-02-28 15:54:47 - Checking for fully qualified hostname…
INFO - 2016-02-28 15:54:47 - Hostname OK: fully qualified as ns.myhost.com
INFO - 2016-02-28 15:54:47 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-02-28 15:54:47 - Loading OS selection library…
INFO - 2016-02-28 15:54:47 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-02-28 15:54:47 - Loading OS list…
INFO - 2016-02-28 15:54:47 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-02-28 15:54:47 - Operating system name: Red Hat Enterprise Linux
INFO - 2016-02-28 15:54:47 - Operating system version: 6
INFO - 2016-02-28 15:54:47 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2016-02-28 15:54:47 - Disabling SELinux during installation…
DEBUG - 2016-02-28 15:54:47 - setenforce 0 succeeded
INFO - 2016-02-28 15:54:48 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2016-02-28 15:54:50 - Succeeded.
INFO - 2016-02-28 15:54:50 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Nothing to do
INFO - 2016-02-28 15:55:01 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https: Succeeded.
INFO - 2016-02-28 15:55:01 - Succeeded.
INFO - 2016-02-28 15:55:01 - Installing Virtualmin and all related packages now using the command:
INFO - 2016-02-28 15:55:01 - yum clean all
INFO - 2016-02-28 15:55:02 - yum -y -d 2 install virtualmin-base
FATAL - 2016-02-28 15:56:40 - Fatal Error Occurred: Installation failed: 0
FATAL - 2016-02-28 15:56:40 - Cannot continue installation.
FATAL - 2016-02-28 15:56:40 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-02-28 15:56:40 - re-attempted after any problems have been resolved.
FATAL - 2016-02-28 15:56:40 - Removing temporary directory and files.
FATAL - 2016-02-28 15:56:40 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-02-28 15:56:41 - in /root/virtualmin-install.log
INFO - 2016-03-01 08:54:31 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-03-01 08:54:31 - Install mode: full
DEBUG - 2016-03-01 08:54:31 - Product: Virtualmin GPL
DEBUG - 2016-03-01 08:54:31 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-03-01 08:54:31 - install.sh version: 1.1.2
INFO - 2016-03-01 08:54:31 - Checking for fully qualified hostname…
INFO - 2016-03-01 08:54:31 - Hostname OK: fully qualified as ns.myhost.com
INFO - 2016-03-01 08:54:31 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-03-01 08:54:31 - Loading OS selection library…
INFO - 2016-03-01 08:54:31 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-03-01 08:54:31 - Loading OS list…
INFO - 2016-03-01 08:54:31 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-03-01 08:54:31 - Operating system name: Red Hat Enterprise Linux
INFO - 2016-03-01 08:54:31 - Operating system version: 6
INFO - 2016-03-01 08:54:31 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2016-03-01 08:54:31 - Disabling SELinux during installation…
DEBUG - 2016-03-01 08:54:31 - setenforce 0 succeeded
INFO - 2016-03-01 08:54:32 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2016-03-01 08:54:38 - Succeeded.
INFO - 2016-03-01 08:54:38 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Nothing to do
INFO - 2016-03-01 08:54:49 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https: Succeeded.
INFO - 2016-03-01 08:54:49 - Succeeded.
INFO - 2016-03-01 08:54:49 - Installing Virtualmin and all related packages now using the command:
INFO - 2016-03-01 08:54:49 - yum clean all
INFO - 2016-03-01 08:54:49 - yum -y -d 2 install virtualmin-base
FATAL - 2016-03-01 08:56:34 - Fatal Error Occurred: Installation failed: 0
FATAL - 2016-03-01 08:56:34 - Cannot continue installation.
FATAL - 2016-03-01 08:56:34 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-03-01 08:56:34 - re-attempted after any problems have been resolved.
FATAL - 2016-03-01 08:56:34 - Removing temporary directory and files.
FATAL - 2016-03-01 08:56:34 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-03-01 08:56:34 - in /root/virtualmin-install.log
INFO - 2016-03-01 10:26:33 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-03-01 10:26:33 - Install mode: full
DEBUG - 2016-03-01 10:26:33 - Product: Virtualmin GPL
DEBUG - 2016-03-01 10:26:33 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-03-01 10:26:33 - install.sh version: 1.1.2
INFO - 2016-03-01 10:26:33 - Checking for fully qualified hostname…
INFO - 2016-03-01 10:26:33 - Hostname OK: fully qualified as ns.myhost.com
INFO - 2016-03-01 10:26:33 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-03-01 10:26:33 - Loading OS selection library…
INFO - 2016-03-01 10:26:34 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-03-01 10:26:34 - Loading OS list…
INFO - 2016-03-01 10:26:34 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-03-01 10:26:34 - Operating system name: Red Hat Enterprise Linux
INFO - 2016-03-01 10:26:34 - Operating system version: 6
INFO - 2016-03-01 10:26:34 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2016-03-01 10:26:34 - Disabling SELinux during installation…
DEBUG - 2016-03-01 10:26:34 - setenforce 0 succeeded
INFO - 2016-03-01 10:26:34 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2016-03-01 10:26:37 - Succeeded.
INFO - 2016-03-01 10:26:37 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Nothing to do
INFO - 2016-03-01 10:26:48 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https: Succeeded.
INFO - 2016-03-01 10:26:48 - Succeeded.
INFO - 2016-03-01 10:26:48 - Installing Virtualmin and all related packages now using the command:
INFO - 2016-03-01 10:26:48 - yum clean all
INFO - 2016-03-01 10:26:48 - yum -y -d 2 install virtualmin-base
FATAL - 2016-03-01 10:28:27 - Fatal Error Occurred: Installation failed: 0
FATAL - 2016-03-01 10:28:27 - Cannot continue installation.
FATAL - 2016-03-01 10:28:27 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-03-01 10:28:27 - re-attempted after any problems have been resolved.
FATAL - 2016-03-01 10:28:28 - Removing temporary directory and files.
FATAL - 2016-03-01 10:28:28 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-03-01 10:28:28 - in /root/virtualmin-install.log
Can someone please help me with completing the Virtualmin installation? Is there a RHEL repo from where I can get all the dependencies which will install cyrus-sasl-md5 just like Virtualmin needs it?
Thanks.
