Problem installing virtualmin on Debian 6.0
Hi, I recently try to install Virtualmin on my VPS running Debian Squeeze but always failed.
Btw i post my virtualmin-install.log down below:
INFO - 2011-03-17 15:53:22 - Started installation log in /root/virtualmin-install.log
DEBUG - 2011-03-17 15:53:22 - Install mode: full
DEBUG - 2011-03-17 15:53:22 - Product: Virtualmin GPL
DEBUG - 2011-03-17 15:53:22 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2011-03-17 15:53:22 - install.sh version: 1.0.5
INFO - 2011-03-17 15:53:22 - Checking for fully qualified hostname…
INFO - 2011-03-17 15:53:22 - Hostname OK: fully qualified as fivespace.net
INFO - 2011-03-17 15:53:22 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2011-03-17 15:53:22 - Loading OS selection library…
INFO - 2011-03-17 15:53:22 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2011-03-17 15:53:22 - Loading OS list…
INFO - 2011-03-17 15:53:22 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2011-03-17 15:53:22 - Operating system name: Debian Linux
INFO - 2011-03-17 15:53:22 - Operating system version: 6.0
INFO - 2011-03-17 15:53:22 - Configuring package manager for Debian Linux 6.0…
INFO - 2011-03-17 15:53:22 - Enabling universe repositories, if not already available…
INFO - 2011-03-17 15:53:22 - Disabling cdrom repositories…
INFO - 2011-03-17 15:56:30 - Cleaning up apt headers and packages, so we can start fresh…
INFO - 2011-03-17 15:56:32 - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - 2011-03-17 15:56:32 - Installing Webmin and Virtualmin package signing keys…
INFO - 2011-03-17 15:56:34 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
INFO - 2011-03-17 15:56:37 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - 2011-03-17 15:56:37 - OK
INFO - 2011-03-17 15:57:13 - Hit
INFO - 2011-03-17 15:57:13 - Removing Debian standard Webmin package, if they exist…
INFO - 2011-03-17 15:57:13 - Removing Debian apache packages…
DEBUG - 2011-03-17 15:57:14 - Reading
INFO - 2011-03-17 15:57:14 - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip libfcgi-dev bind9 spamassassin spamc procmail libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common postgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-custom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libgd2-xpm libapache2-mod-php5 php5-mysql
Reading package lists…
Building dependency tree…
Reading state information…
libsasl2-2 is already the newest version.
libsasl2-2 set to manually installed.
libsasl2-modules is already the newest version.
libsasl2-modules set to manually installed.
iptables is already the newest version.
quota is already the newest version.
The following extra packages will be installed:
apache2-mpm-prefork apache2-utils apache2.2-bin apache2.2-common
apt-show-versions bind9utils binutils ca-certificates cpp cpp-4.4 db4.8-util
file fontconfig-config gcc gcc-4.4 geoip-database heirloom-mailx
libapache-ruby1.8 libapr1 libaprutil1 libaprutil1-dbd-sqlite3
libaprutil1-ldap libapt-pkg-perl libauthen-pam-perl libbind9-60 libc-dev-bin
libc6-dev libcap2 libclamav6 libdb4.7 libdbi-perl libdigest-hmac-perl
libdigest-sha1-perl libdns69 liberror-perl libexpat1 libfcgi0ldbl
libfile-copy-recursive-perl libfont-afm-perl libfontconfig1 libfreetype6
libgeoip1 libgmp3c2 libgomp1 libhtml-format-perl libhtml-parser-perl
libhtml-tagset-perl libhtml-template-perl libhtml-tree-perl libio-pty-perl
libio-socket-inet6-perl libisc62 libisccc60 libisccfg62 libjpeg62 libltdl7
liblwres60 libmagic1 libmail-spf-perl libmailtools-perl libmpfr4
libmysqlclient16 libneon27-gnutls libnet-daemon-perl libnet-dns-perl
libnet-ip-perl libnet-xwhois-perl libnetaddr-ip-perl libonig2 libpcre3
libplrpc-perl libpng12-0 libpq5 libqdbm14 libreadline5 libruby1.8
libserf-0-0 libsocket6-perl libsvn1 libsys-hostname-long-perl
libtimedate-perl libtommath0 liburi-perl libwww-perl
libxml-namespacesupport-perl libxml-parser-perl libxml-sax-expat-perl
libxml-sax-perl libxml2 libxpm4 linux-libc-dev lsb-release make manpages-dev
mime-support mysql-client-5.1 mysql-server-5.1 mysql-server-core-5.1 perl
perl-modules php5-cli php5-common php5-suhosin postgresql-8.4
postgresql-client-8.4 postgresql-client-common postgresql-common
proftpd-basic psmisc pwgen python-minimal python-support python2.6
python2.6-minimal re2c ri1.8 ruby1.8 sgml-base ssl-cert ttf-dejavu-core ucf
update-inetd xml-core
Suggested packages:
www-browser libgeo-ipfree-perl dnsutils bind9-doc resolvconf ufw
binutils-doc daemon cpp-doc gcc-4.4-locales ntp gcc-multilib autoconf
automake1.9 libtool flex bison gdb gcc-doc gcc-4.4-multilib
libmudflap0-4.4-dev gcc-4.4-doc libgcc1-dbg libgomp1-dbg libmudflap0-dbg
libcloog-ppl0 libppl-c2 libppl7 exim4 mail-transport-agent liberuby
glibc-doc libclamunrar6 libgd-tools geoip-bin libdata-dump-perl
libipc-sharedcache-perl libmime-base64-perl libcompress-zlib-perl lsb lynx
listadmin make-doc libterm-readkey-perl tinyca perl-doc
libterm-readline-gnu-perl libterm-readline-perl-perl php5-dev postfix-mysql
postfix-pgsql postfix-ldap postfix-cdb mail-reader oidentd ident-server
postgresql-doc-8.4 proftpd-doc proftpd-mod-mysql proftpd-mod-pgsql
proftpd-mod-ldap proftpd-mod-odbc proftpd-mod-sqlite openbsd-inetd
inet-superserver python-doc python-tk python-profiler python2.6-doc
python2.6-profiler binfmt-support ruby-dev ruby1.8-examples sgml-base-doc
razor libnet-ident-perl libio-socket-ssl-perl pyzor libmail-dkim-perl
openssl-blacklist subversion-tools patch httpd debhelper
Recommended packages:
mailx libsys-syslog-perl
The following NEW packages will be installed:
apache2 apache2-doc apache2-mpm-prefork apache2-suexec-custom apache2-utils
apache2.2-bin apache2.2-common apt-show-versions awstats bind9 bind9utils
binutils ca-certificates clamav clamav-base clamav-daemon clamav-docs
clamav-freshclam clamav-testfiles cpp cpp-4.4 db4.8-util dovecot-common
dovecot-imapd dovecot-pop3d file fontconfig-config gcc gcc-4.4
geoip-database heirloom-mailx libapache-ruby1.8 libapache2-mod-fcgid
libapache2-mod-php5 libapache2-mod-ruby libapache2-svn libapr1 libaprutil1
libaprutil1-dbd-sqlite3 libaprutil1-ldap libapt-pkg-perl libauthen-pam-perl
libbind9-60 libc-dev-bin libc6-dev libcap2 libclamav6 libcrypt-ssleay-perl
libdb4.7 libdbd-mysql-perl libdbd-pg-perl libdbi-perl libdigest-hmac-perl
libdigest-sha1-perl libdns69 liberror-perl libexpat1 libfcgi-dev
libfcgi0ldbl libfile-copy-recursive-perl libfont-afm-perl libfontconfig1
libfreetype6 libgd2-xpm libgeoip1 libgmp3c2 libgomp1 libhtml-format-perl
libhtml-parser-perl libhtml-tagset-perl libhtml-template-perl
libhtml-tree-perl libio-pty-perl libio-socket-inet6-perl libisc62 libisccc60
libisccfg62 libjpeg62 libltdl7 liblwres60 libmagic1 libmail-spf-perl
libmailtools-perl libmpfr4 libmysqlclient16 libneon27-gnutls
libnet-daemon-perl libnet-dns-perl libnet-ip-perl libnet-ssleay-perl
libnet-xwhois-perl libnetaddr-ip-perl libonig2 libpcre3 libpg-perl
libxml-sax-perl libxml-simple-perl libxml2 libxpm4 linux-libc-dev
lsb-release mailman make manpages-dev mime-support mysql-client
mysql-client-5.1 mysql-common mysql-server mysql-server-5.1
mysql-server-core-5.1 openssl perl perl-modules php-pear php5 php5-cgi
php5-cli php5-common php5-mysql php5-suhosin postfix postfix-pcre postgresql
postgresql-8.4 postgresql-client postgresql-client-8.4
postgresql-client-common postgresql-common procmail proftpd-basic psmisc
pwgen python python-minimal python-support python2.6 python2.6-minimal re2c
ri ri1.8 ruby ruby1.8 sasl2-bin scponly sgml-base spamassassin spamc
ssl-cert subversion ttf-dejavu-core ucf unzip update-inetd usermin webalizer
webmin xml-core zip
0 upgraded, 176 newly installed, 0 to remove and 2 not upgraded.
Need to get 185 MB of archives.
After this operation, 592 MB of additional disk space will be used.
Get:1 http://ftp.de.debian.org/debian/ squeeze/main python2.6-minimal amd64 2.6.6-8+b1 [1520 kB]
Get:2 http://software.virtualmin.com/gpl/debian/ virtualmin-universal/main usermin all 1.450 [6011 kB]
Get:3 http://ftp.de.debian.org/debian/ squeeze/main mime-support all 3.48-1 [34.2 kB]
Get:4 http://ftp.de.debian.org/debian/ squeeze/main libexpat1 amd64 2.0.1-7 [137 kB]
Get:5 http://ftp.de.debian.org/debian/ squeeze/main python2.6 amd64 2.6.6-8+b1 [2455 kB]
Get:6 http://software.virtualmin.com/gpl/debian/ virtualmin-universal/main webmin all 1.534 [14.7 MB]
Get:7 http://ftp.de.debian.org/debian/ squeeze/main python-minimal all 2.6.6-3+squeeze5 [33.7 kB]
Get:8 http://ftp.de.debian.org/debian/ squeeze/main python all 2.6.6-3+squeeze5 [168 kB]
Get:9 http://ftp.de.debian.org/debian/ squeeze/main python-support all 1.0.10 [33.0 kB]
Get:10 http://ftp.de.debian.org/debian/ squeeze/main ucf all 3.0025+nmu1 [69.6 kB]
Get:11 http://ftp.de.debian.org/debian/ squeeze/main pwgen amd64 2.06-1+b1 [21.4 kB]
Get:12 http://ftp.de.debian.org/debian-security/ squeeze/updates/main openssl amd64 0.9.8o-4squeeze1 [1059 kB]
Get:13 http://ftp.de.debian.org/debian/ squeeze/main ssl-cert all 1.0.28 [14.8 kB]
Get:14 http://ftp.de.debian.org/debian/ squeeze/main postfix amd64 2.7.1-1 [1410 kB]
Get:15 http://ftp.de.debian.org/debian/ squeeze/main libapr1 amd64 1.4.2-6 [93.5 kB]
Get:16 http://ftp.de.debian.org/debian/ squeeze/main libaprutil1 amd64 1.3.9+dfsg-5 [92.3 kB]
Get:17 http://ftp.de.debian.org/debian/ squeeze/main libaprutil1-dbd-sqlite3 amd64 1.3.9+dfsg-5 [28.1 kB]
Get:18 http://ftp.de.debian.org/debian/ squeeze/main libaprutil1-ldap amd64 1.3.9+dfsg-5 [25.7 kB]
Get:19 http://ftp.de.debian.org/debian/ squeeze/main libcap2 amd64 1:2.19-3 [12.6 kB]
Get:20 http://ftp.de.debian.org/debian/ squeeze/main libpcre3 amd64 8.02-1.1 [234 kB]
Get:21 http://ftp.de.debian.org/debian/ squeeze/main apache2.2-bin amd64 2.2.16-6 [1428 kB]
Get:22 http://ftp.de.debian.org/debian/ squeeze/main apache2-utils amd64 2.2.16-6 [164 kB]
Get:23 http://ftp.de.debian.org/debian/ squeeze/main libmagic1 amd64 5.04-5 [234 kB]
Get:24 http://ftp.de.debian.org/debian/ squeeze/main perl-modules all 5.10.1-17 [3482 kB]
Get:25 http://ftp.de.debian.org/debian/ squeeze/main libdb4.7 amd64 4.7.25-9 [662 kB]
Get:26 http://ftp.de.debian.org/debian/ squeeze/main perl amd64 5.10.1-17 [4461 kB]
Get:27 http://ftp.de.debian.org/debian/ squeeze/main apache2.2-common amd64 2.2.16-6 [300 kB]
Get:28 http://ftp.de.debian.org/debian/ squeeze/main apache2-mpm-prefork amd64 2.2.16-6 [2268 B]
Get:29 http://ftp.de.debian.org/debian/ squeeze/main apache2 amd64 2.2.16-6 [1390 B]
Get:30 http://ftp.de.debian.org/debian-security/ squeeze/updates/main mailman amd64 1:2.1.13-5 [9642 kB]
Get:31 http://ftp.de.debian.org/debian/ squeeze/main mysql-common all 5.1.49-3 [70.9 kB]
Get:32 http://ftp.de.debian.org/debian/ squeeze/main libnet-daemon-perl all 0.43-1 [46.6 kB]
Get:33 http://ftp.de.debian.org/debian/ squeeze/main libplrpc-perl all 0.2020-2 [36.0 kB]
Get:34 http://ftp.de.debian.org/debian/ squeeze/main libdbi-perl amd64 1.612-1 [883 kB]
Get:35 http://ftp.de.debian.org/debian/ squeeze/main libmysqlclient16 amd64 5.1.49-3 [1985 kB]
Get:36 http://ftp.de.debian.org/debian/ squeeze/main libdbd-mysql-perl amd64 4.016-1 [140 kB]
Get:37 http://ftp.de.debian.org/debian/ squeeze/main mysql-client-5.1 amd64 5.1.49-3 [10.1 MB]
Get:38 http://ftp.de.debian.org/debian/ squeeze/main psmisc amd64 22.11-1 [119 kB]
Get:39 http://ftp.de.debian.org/debian/ squeeze/main mysql-server-core-5.1 amd64 5.1.49-3 [4124 kB]
Get:40 http://ftp.de.debian.org/debian/ squeeze/main mysql-server-5.1 amd64 5.1.49-3 [6598 kB]
Get:41 http://ftp.de.debian.org/debian/ squeeze/main libnet-ssleay-perl amd64 1.36-1 [213 kB]
Get:42 http://ftp.de.debian.org/debian/ squeeze/main libauthen-pam-perl amd64 0.16-2 [33.8 kB]
Get:43 http://ftp.de.debian.org/debian/ squeeze/main libio-pty-perl amd64 1:1.08-1 [42.5 kB]
Get:44 http://ftp.de.debian.org/debian/ squeeze/main libapt-pkg-perl amd64 0.1.24+b1 [91.5 kB]
Get:45 http://ftp.de.debian.org/debian/ squeeze/main apt-show-versions all 0.16 [33.6 kB]
Get:46 http://ftp.de.debian.org/debian/ squeeze/main libfreetype6 amd64 2.4.2-2.1 [378 kB]
Get:47 http://ftp.de.debian.org/debian/ squeeze/main ttf-dejavu-core all 2.31-1 [1451 kB]
Get:48 http://ftp.de.debian.org/debian/ squeeze/main fontconfig-config all 2.8.0-2.1 [217 kB]
Get:49 http://ftp.de.debian.org/debian/ squeeze/main libfontconfig1 amd64 2.8.0-2.1 [281 kB]
Get:50 http://ftp.de.debian.org/debian/ squeeze/main libjpeg62 amd64 6b1-1 [94.0 kB]
Get:51 http://ftp.de.debian.org/debian/ squeeze/main libpng12-0 amd64 1.2.44-1 [180 kB]
Get:52 http://ftp.de.debian.org/debian/ squeeze/main libxpm4 amd64 1:3.5.8-1 [44.2 kB]
Get:53 http://ftp.de.debian.org/debian/ squeeze/main libgd2-xpm amd64 2.0.36~rc1~dfsg-5 [231 kB]
Get:54 http://ftp.de.debian.org/debian/ squeeze/main libgeoip1 amd64 1.4.7~beta6+dfsg-1 [127 kB]
Get:55 http://ftp.de.debian.org/debian/ squeeze/main webalizer amd64 2.01.10-32.7 [352 kB]
Get:56 http://ftp.de.debian.org/debian/ squeeze/main file amd64 5.04-5 [49.7 kB]
Get:57 http://ftp.de.debian.org/debian/ squeeze/main libxml2 amd64 2.7.8.dfsg-2 [873 kB]
Get:58 http://ftp.de.debian.org/debian/ squeeze/main libisc62 amd64 1:9.7.2.dfsg.P3-1.1 [174 kB]
Get:59 http://ftp.de.debian.org/debian/ squeeze/main libdns69 amd64 1:9.7.2.dfsg.P3-1.1 [708 kB]
Get:60 http://ftp.de.debian.org/debian/ squeeze/main libisccc60 amd64 1:9.7.2.dfsg.P3-1.1 [32.5 kB]
Get:61 http://ftp.de.debian.org/debian/ squeeze/main libisccfg62 amd64 1:9.7.2.dfsg.P3-1.1 [56.6 kB]
Get:62 http://ftp.de.debian.org/debian/ squeeze/main libbind9-60 amd64 1:9.7.2.dfsg.P3-1.1 [37.9 kB]
Get:63 http://ftp.de.debian.org/debian/ squeeze/main liblwres60 amd64 1:9.7.2.dfsg.P3-1.1 [51.4 kB]
Get:64 http://ftp.de.debian.org/debian/ squeeze/main procmail amd64 3.22-19 [157 kB]
Get:65 http://ftp.de.debian.org/debian/ squeeze/main apache2-doc all 2.2.16-6 [2304 kB]
Get:66 http://ftp.de.debian.org/debian/ squeeze/main awstats all 6.9.5~dfsg-5 [989 kB]
Get:67 http://ftp.de.debian.org/debian/ squeeze/main bind9utils amd64 1:9.7.2.dfsg.P3-1.1 [122 kB]
Get:68 http://ftp.de.debian.org/debian/ squeeze/main bind9 amd64 1:9.7.2.dfsg.P3-1.1 [351 kB]
Get:69 http://ftp.de.debian.org/debian/ squeeze/main binutils amd64 2.20.1-16 [3993 kB]
Get:70 http://ftp.de.debian.org/debian/ squeeze/main ca-certificates all 20090814+nmu2 [153 kB]
Get:71 http://ftp.de.debian.org/debian/ squeeze/main libltdl7 amd64 2.2.6b-2 [296 kB]
Get:72 http://ftp.de.debian.org/debian/ squeeze/main libtommath0 amd64 0.39-4 [64.8 kB]
Get:73 http://ftp.de.debian.org/debian/ squeeze/main libclamav6 amd64 0.96.5+dfsg-1.1 [4179 kB]
Get:74 http://ftp.de.debian.org/debian/ squeeze/main clamav-base all 0.96.5+dfsg-1.1 [26.7 MB]
Get:75 http://ftp.de.debian.org/debian/ squeeze/main clamav-freshclam amd64 0.96.5+dfsg-1.1 [311 kB]
Get:76 http://ftp.de.debian.org/debian/ squeeze/main clamav amd64 0.96.5+dfsg-1.1 [332 kB]
Get:77 http://ftp.de.debian.org/debian/ squeeze/main clamav-daemon amd64 0.96.5+dfsg-1.1 [421 kB]
Get:78 http://ftp.de.debian.org/debian/ squeeze/main clamav-docs all 0.96.5+dfsg-1.1 [1292 kB]
Get:79 http://ftp.de.debian.org/debian/ squeeze/main clamav-testfiles all 0.96.5+dfsg-1.1 [5256 kB]
Get:80 http://ftp.de.debian.org/debian/ squeeze/main libgmp3c2 amd64 2:4.3.2+dfsg-1 [313 kB]
Get:81 http://ftp.de.debian.org/debian/ squeeze/main libmpfr4 amd64 3.0.0-2 [474 kB]
Get:82 http://ftp.de.debian.org/debian/ squeeze/main cpp-4.4 amd64 4.4.5-8 [3873 kB]
Get:83 http://ftp.de.debian.org/debian/ squeeze/main cpp amd64 4:4.4.5-1 [15.0 kB]
Get:84 http://ftp.de.debian.org/debian/ squeeze/main db4.8-util amd64 4.8.30-2 [134 kB]
Get:85 http://ftp.de.debian.org/debian-security/ squeeze/updates/main libpq5 amd64 8.4.7-0squeeze2 [151 kB]
Get:86 http://ftp.de.debian.org/debian/ squeeze/main dovecot-common amd64 1:1.2.15-4 [5512 kB]
Get:87 http://ftp.de.debian.org/debian/ squeeze/main dovecot-imapd amd64 1:1.2.15-4 [1177 kB]
Get:88 http://ftp.de.debian.org/debian/ squeeze/main dovecot-pop3d amd64 1:1.2.15-4 [1073 kB]
Get:89 http://ftp.de.debian.org/debian/ squeeze/main libgomp1 amd64 4.4.5-8 [25.3 kB]
Get:90 http://ftp.de.debian.org/debian/ squeeze/main gcc-4.4 amd64 4.4.5-8 [2688 kB]
Get:91 http://ftp.de.debian.org/debian/ squeeze/main gcc amd64 4:4.4.5-1 [4970 B]
Get:92 http://ftp.de.debian.org/debian/ squeeze/main geoip-database all 1.4.7~beta6+dfsg-1 [2846 kB]
Get:93 http://ftp.de.debian.org/debian/ squeeze/main heirloom-mailx amd64 12.4-2 [319 kB]
Get:94 http://ftp.de.debian.org/debian/ squeeze/main libreadline5 amd64 5.2-7 [146 kB]
Get:95 http://ftp.de.debian.org/debian/ squeeze/main libruby1.8 amd64 1.8.7.302-2 [2061 kB]
Get:96 http://ftp.de.debian.org/debian/ squeeze/main libapache-ruby1.8 all 1.2.6-2 [20.5 kB]
Get:97 http://ftp.de.debian.org/debian/ squeeze/main libapache2-mod-fcgid amd64 1:2.3.6-1 [73.9 kB]
Get:98 http://ftp.de.debian.org/debian/ squeeze/main libonig2 amd64 5.9.1-1 [145 kB]
Get:99 http://ftp.de.debian.org/debian/ squeeze/main libqdbm14 amd64 1.8.77-4 [157 kB]
Get:100 http://ftp.de.debian.org/debian/ squeeze/main php5-common amd64 5.3.3-7 [549 kB]
Get:101 http://ftp.de.debian.org/debian/ squeeze/main libapache2-mod-php5 amd64 5.3.3-7 [3037 kB]
Get:102 http://ftp.de.debian.org/debian/ squeeze/main libapache2-mod-ruby amd64 1.2.6-2 [65.6 kB]
Get:103 http://ftp.de.debian.org/debian/ squeeze/main libneon27-gnutls amd64 0.29.3-3 [139 kB]
Get:104 http://ftp.de.debian.org/debian/ squeeze/main libserf-0-0 amd64 0.3.1-1 [34.5 kB]
Get:105 http://ftp.de.debian.org/debian-security/ squeeze/updates/main libsvn1 amd64 1.6.12dfsg-5 [984 kB]
Get:106 http://ftp.de.debian.org/debian-security/ squeeze/updates/main libapache2-svn amd64 1.6.12dfsg-5 [169 kB]
Get:107 http://ftp.de.debian.org/debian/ squeeze/main libc-dev-bin amd64 2.11.2-10 [207 kB]
Get:108 http://ftp.de.debian.org/debian/ squeeze/main linux-libc-dev amd64 2.6.32-30 [839 kB]
Get:109 http://ftp.de.debian.org/debian/ squeeze/main libc6-dev amd64 2.11.2-10 [2587 kB]
Get:110 http://ftp.de.debian.org/debian/ squeeze/main liburi-perl all 1.54-2 [98.5 kB]
Get:111 http://ftp.de.debian.org/debian/ squeeze/main libcrypt-ssleay-perl amd64 0.57-2 [57.7 kB]
Get:112 http://ftp.de.debian.org/debian/ squeeze/main libdbd-pg-perl amd64 2.17.1-2 [226 kB]
Get:113 http://ftp.de.debian.org/debian/ squeeze/main libdigest-sha1-perl amd64 2.13-1 [26.5 kB]
Get:114 http://ftp.de.debian.org/debian/ squeeze/main libdigest-hmac-perl all 1.02+dfsg-1 [11.8 kB]
Get:115 http://ftp.de.debian.org/debian/ squeeze/main liberror-perl all 0.17-1 [23.6 kB]
Get:116 http://ftp.de.debian.org/debian/ squeeze/main libfcgi0ldbl amd64 2.4.0-8 [282 kB]
Get:117 http://ftp.de.debian.org/debian/ squeeze/main libfcgi-dev amd64 2.4.0-8 [36.9 kB]
Get:118 http://ftp.de.debian.org/debian/ squeeze/main libfile-copy-recursive-perl all 0.38-1 [20.6 kB]
Get:119 http://ftp.de.debian.org/debian/ squeeze/main libfont-afm-perl all 1.20-1 [14.4 kB]
Get:120 http://ftp.de.debian.org/debian/ squeeze/main libhtml-tagset-perl all 3.20-2 [13.5 kB]
Get:121 http://ftp.de.debian.org/debian/ squeeze/main libhtml-parser-perl amd64 3.66-1 [115 kB]
Get:122 http://ftp.de.debian.org/debian/ squeeze/main libhtml-tree-perl all 3.23-2 [209 kB]
Get:123 http://ftp.de.debian.org/debian/ squeeze/main libhtml-format-perl all 2.04-2 [39.5 kB]
Get:124 http://ftp.de.debian.org/debian/ squeeze/main libhtml-template-perl all 2.9-2 [65.9 kB]
Get:125 http://ftp.de.debian.org/debian/ squeeze/main libsocket6-perl amd64 0.23-1 [29.1 kB]
Get:126 http://ftp.de.debian.org/debian/ squeeze/main libio-socket-inet6-perl all 2.65-1.1 [16.1 kB]
Get:127 http://ftp.de.debian.org/debian/ squeeze/main libnetaddr-ip-perl amd64 4.028+dfsg-1 [100 kB]
Get:128 http://ftp.de.debian.org/debian/ squeeze/main libnet-ip-perl all 1.25-2 [30.2 kB]
Get:129 http://ftp.de.debian.org/debian/ squeeze/main libnet-dns-perl amd64 0.66-2 [298 kB]
Get:130 http://ftp.de.debian.org/debian/ squeeze/main libmail-spf-perl all 2.007-1 [125 kB]
Get:131 http://ftp.de.debian.org/debian/ squeeze/main libtimedate-perl all 1.2000-1 [41.2 kB]
Get:132 http://ftp.de.debian.org/debian/ squeeze/main libmailtools-perl all 2.06-1 [97.4 kB]
Get:133 http://ftp.de.debian.org/debian/ squeeze/main libnet-xwhois-perl all 0.90-3 [23.0 kB]
Get:134 http://ftp.de.debian.org/debian/ squeeze/main libpg-perl amd64 1:2.1.1-4 [64.0 kB]
Get:135 http://ftp.de.debian.org/debian/ squeeze/main libsys-hostname-long-perl all 1.4-2 [11.3 kB]
Get:136 http://ftp.de.debian.org/debian/ squeeze/main libwww-perl all 5.836-1 [401 kB]
Get:137 http://ftp.de.debian.org/debian/ squeeze/main libxml-namespacesupport-perl all 1.09-3 [15.3 kB]
Get:138 http://ftp.de.debian.org/debian/ squeeze/main libxml-parser-perl amd64 2.36-1.1+b1 [297 kB]
Get:139 http://ftp.de.debian.org/debian/ squeeze/main libxml-sax-perl all 0.96+dfsg-2 [86.0 kB]
Get:140 http://ftp.de.debian.org/debian/ squeeze/main libxml-sax-expat-perl all 0.40-1 [12.5 kB]
Get:141 http://ftp.de.debian.org/debian/ squeeze/main libxml-simple-perl all 2.18-3 [72.8 kB]
Get:142 http://ftp.de.debian.org/debian/ squeeze/main lsb-release all 3.2-23.2squeeze1 [21.5 kB]
Get:143 http://ftp.de.debian.org/debian/ squeeze/main make amd64 3.81-8 [398 kB]
Get:144 http://ftp.de.debian.org/debian/ squeeze/main manpages-dev all 3.27-1 [1639 kB]
Get:145 http://ftp.de.debian.org/debian/ squeeze/main mysql-client all 5.1.49-3 [65.2 kB]
Get:146 http://ftp.de.debian.org/debian/ squeeze/main mysql-server all 5.1.49-3 [65.4 kB]
Get:147 http://ftp.de.debian.org/debian/ squeeze/main php5-cli amd64 5.3.3-7 [2942 kB]
Get:148 http://ftp.de.debian.org/debian/ squeeze/main php-pear all 5.3.3-7 [365 kB]
Get:149 http://ftp.de.debian.org/debian/ squeeze/main php5-cgi amd64 5.3.3-7 [5885 kB]
Get:150 http://ftp.de.debian.org/debian/ squeeze/main php5 all 5.3.3-7 [1048 B]
Get:151 http://ftp.de.debian.org/debian/ squeeze/main php5-mysql amd64 5.3.3-7 [76.5 kB]
Get:152 http://ftp.de.debian.org/debian/ squeeze/main php5-suhosin amd64 0.9.32.1-1 [88.4 kB]
Get:153 http://ftp.de.debian.org/debian/ squeeze/main postgresql-client-common all 113 [56.9 kB]
Get:154 http://ftp.de.debian.org/debian-security/ squeeze/updates/main postgresql-client-8.4 amd64 8.4.7-0squeeze2 [1472 kB]
Get:155 http://ftp.de.debian.org/debian/ squeeze/main postgresql-common all 113 [127 kB]
Get:156 http://ftp.de.debian.org/debian-security/ squeeze/updates/main postgresql-8.4 amd64 8.4.7-0squeeze2 [5336 kB]
Get:157 http://ftp.de.debian.org/debian-security/ squeeze/updates/main postgresql all 8.4.7-0squeeze2 [20.0 kB]
Get:158 http://ftp.de.debian.org/debian-security/ squeeze/updates/main postgresql-client all 8.4.7-0squeeze2 [20.0 kB]
Get:159 http://ftp.de.debian.org/debian/ squeeze/main update-inetd all 4.38+nmu1 [20.6 kB]
Get:160 http://ftp.de.debian.org/debian-security/ squeeze/updates/main proftpd-basic amd64 1.3.3a-6squeeze1 [2404 kB]
Get:161 http://ftp.de.debian.org/debian/ squeeze/main re2c amd64 0.13.5-1 [221 kB]
Get:162 http://ftp.de.debian.org/debian/ squeeze/main ruby1.8 amd64 1.8.7.302-2 [310 kB]
Get:163 http://ftp.de.debian.org/debian/ squeeze/main ri1.8 all 1.8.7.302-2 [1425 kB]
Get:164 http://ftp.de.debian.org/debian/ squeeze/main ri all 4.5 [5526 B]
Get:165 http://ftp.de.debian.org/debian/ squeeze/main ruby all 4.5 [21.7 kB]
Get:166 http://ftp.de.debian.org/debian/ squeeze/main sasl2-bin amd64 2.1.23.dfsg1-7 [158 kB]
Get:167 http://ftp.de.debian.org/debian/ squeeze/main scponly amd64 4.8-4.1 [37.4 kB]
Get:168 http://ftp.de.debian.org/debian/ squeeze/main sgml-base all 1.26+nmu1 [11.9 kB]
Get:169 http://ftp.de.debian.org/debian/ squeeze/main spamassassin all 3.3.1-1 [1233 kB]
Get:170 http://ftp.de.debian.org/debian/ squeeze/main spamc amd64 3.3.1-1 [70.4 kB]
Get:171 http://ftp.de.debian.org/debian-security/ squeeze/updates/main subversion amd64 1.6.12dfsg-5 [1317 kB]
Get:172 http://ftp.de.debian.org/debian/ squeeze/main unzip amd64 6.0-4 [190 kB]
Get:173 http://ftp.de.debian.org/debian/ squeeze/main xml-core all 0.13 [23.4 kB]
Get:174 http://ftp.de.debian.org/debian/ squeeze/main zip amd64 3.0-3 [334 kB]
Get:175 http://ftp.de.debian.org/debian/ squeeze/main apache2-suexec-custom amd64 2.2.16-6 [100 kB]
Get:176 http://ftp.de.debian.org/debian/ squeeze/main postfix-pcre amd64 2.7.1-1 [44.5 kB]
Preconfiguring packages …
Fetched 185 MB in 11min 22s (270 kB/s)
Selecting previously deselected package python2.6-minimal.
(Reading database …
(Reading database … 5%
(Reading database … 10%
(Reading database … 15%
(Reading database … 20%
(Reading database … 25%
(Reading database … 30%
(Reading database … 35%
(Reading database … 40%
(Reading database … 45%
(Reading database … 50%
(Reading database … 55%
(Reading database … 60%
(Reading database … 65%
(Reading database … 70%
(Reading database … 75%
(Reading database … 80%
(Reading database … 85%
(Reading database … 90%
(Reading database … 95%
(Reading database … 100%
(Reading database … 9610 files and directories currently installed.)
Unpacking python2.6-minimal (from …/python2.6-minimal_2.6.6-8+b1_amd64.deb) …
Selecting previously deselected package mime-support.
Unpacking mime-support (from …/mime-support_3.48-1_all.deb) …
Selecting previously deselected package libexpat1.
Unpacking libexpat1 (from …/libexpat1_2.0.1-7_amd64.deb) …
Selecting previously deselected package python2.6.
Unpacking python2.6 (from …/python2.6_2.6.6-8+b1_amd64.deb) …
Selecting previously deselected package python-minimal.
Unpacking python-minimal (from …/python-minimal_2.6.6-3+squeeze5_all.deb) …
Selecting previously deselected package python.
Unpacking python (from …/python_2.6.6-3+squeeze5_all.deb) …
Selecting previously deselected package python-support.
Unpacking python-support (from …/python-support_1.0.10_all.deb) …
Selecting previously deselected package ucf.
Unpacking ucf (from …/ucf_3.0025+nmu1_all.deb) …
Moving old data out of the way
Selecting previously deselected package pwgen.
Unpacking pwgen (from …/pwgen_2.06-1+b1_amd64.deb) …
Selecting previously deselected package openssl.
Unpacking openssl (from …/openssl_0.9.8o-4squeeze1_amd64.deb) …
Selecting previously deselected package ssl-cert.
Unpacking ssl-cert (from …/ssl-cert_1.0.28_all.deb) …
Selecting previously deselected package postfix.
Unpacking postfix (from …/postfix_2.7.1-1_amd64.deb) …
Selecting previously deselected package libapr1.
Unpacking libapr1 (from …/libapr1_1.4.2-6_amd64.deb) …
Selecting previously deselected package libaprutil1.
Unpacking libaprutil1 (from …/libaprutil1_1.3.9+dfsg-5_amd64.deb) …
Selecting previously deselected package libaprutil1-dbd-sqlite3.
Unpacking libaprutil1-dbd-sqlite3 (from …/libaprutil1-dbd-sqlite3_1.3.9+dfsg-5_amd64.deb) …
Selecting previously deselected package libaprutil1-ldap.
Unpacking libaprutil1-ldap (from …/libaprutil1-ldap_1.3.9+dfsg-5_amd64.deb) …
Selecting previously deselected package libcap2.
Unpacking libcap2 (from …/libcap2_1%3a2.19-3_amd64.deb) …
Selecting previously deselected package libpcre3.
Unpacking libpcre3 (from …/libpcre3_8.02-1.1_amd64.deb) …
Selecting previously deselected package apache2.2-bin.
Unpacking apache2.2-bin (from …/apache2.2-bin_2.2.16-6_amd64.deb) …
Selecting previously deselected package apache2-utils.
Unpacking apache2-utils (from …/apache2-utils_2.2.16-6_amd64.deb) …
Selecting previously deselected package libmagic1.
Unpacking libmagic1 (from …/libmagic1_5.04-5_amd64.deb) …
Selecting previously deselected package perl-modules.
Unpacking perl-modules (from …/perl-modules_5.10.1-17_all.deb) …
Selecting previously deselected package libdb4.7.
Unpacking libdb4.7 (from …/libdb4.7_4.7.25-9_amd64.deb) …
Selecting previously deselected package perl.
Unpacking perl (from …/perl_5.10.1-17_amd64.deb) …
Selecting previously deselected package apache2.2-common.
Unpacking apache2.2-common (from …/apache2.2-common_2.2.16-6_amd64.deb) …
Selecting previously deselected package apache2-mpm-prefork.
Unpacking apache2-mpm-prefork (from …/apache2-mpm-prefork_2.2.16-6_amd64.deb) …
Unpacking apache2 (from …/apache2_2.2.16-6_amd64.deb) …
Selecting previously deselected package mailman.
Unpacking mailman (from …/mailman_1%3a2.1.13-5_amd64.deb) …
Selecting previously deselected package mysql-common.
Unpacking mysql-common (from …/mysql-common_5.1.49-3_all.deb) …
Selecting previously deselected package libnet-daemon-perl.
Unpacking libnet-daemon-perl (from …/libnet-daemon-perl_0.43-1_all.deb) …
Selecting previously deselected package libplrpc-perl.
Unpacking libplrpc-perl (from …/libplrpc-perl_0.2020-2_all.deb) …
Selecting previously deselected package libdbi-perl.
Unpacking libdbi-perl (from …/libdbi-perl_1.612-1_amd64.deb) …
Selecting previously deselected package libmysqlclient16.
Unpacking libmysqlclient16 (from …/libmysqlclient16_5.1.49-3_amd64.deb) …
Selecting previously deselected package libdbd-mysql-perl.
Unpacking libdbd-mysql-perl (from …/libdbd-mysql-perl_4.016-1_amd64.deb) …
Selecting previously deselected package mysql-client-5.1.
Unpacking mysql-client-5.1 (from …/mysql-client-5.1_5.1.49-3_amd64.deb) …
Selecting previously deselected package psmisc.
Unpacking psmisc (from …/psmisc_22.11-1_amd64.deb) …
Selecting previously deselected package mysql-server-core-5.1.
Unpacking mysql-server-core-5.1 (from …/mysql-server-core-5.1_5.1.49-3_amd64.deb) …
Processing triggers for man-db …
Setting up mysql-common (5.1.49-3) …
Configuration file `/etc/mysql/my.cnf’, does not exist on system.
Installing new config file as you requested.
Selecting previously deselected package mysql-server-5.1.
(Reading database …
(Reading database … 17293 files and directories currently installed.)
Unpacking mysql-server-5.1 (from …/mysql-server-5.1_5.1.49-3_amd64.deb) …
Selecting previously deselected package libnet-ssleay-perl.
Unpacking libnet-ssleay-perl (from …/libnet-ssleay-perl_1.36-1_amd64.deb) …
Selecting previously deselected package libauthen-pam-perl.
Unpacking libauthen-pam-perl (from …/libauthen-pam-perl_0.16-2_amd64.deb) …
Selecting previously deselected package libio-pty-perl.
Unpacking libio-pty-perl (from …/libio-pty-perl_1%3a1.08-1_amd64.deb) …
Selecting previously deselected package libapt-pkg-perl.
Unpacking libapt-pkg-perl (from …/libapt-pkg-perl_0.1.24+b1_amd64.deb) …
Selecting previously deselected package apt-show-versions.
Unpacking apt-show-versions (from …/apt-show-versions_0.16_all.deb) …
Setting up libdb4.7 (4.7.25-9) …
Setting up perl-modules (5.10.1-17) …
Configuration file `/etc/perl/Net/libnet.cfg’, does not exist on system.
Setting up perl (5.10.1-17) …
update-alternatives: using /usr/bin/prename to provide /usr/bin/rename (rename) in auto mode.
Selecting previously deselected package usermin.
(Reading database …
(Reading database … 17574 files and directories currently installed.)
Unpacking usermin (from …/archives/usermin_1.450_all.deb) …
Selecting previously deselected package libfreetype6.
Unpacking libfreetype6 (from …/libfreetype6_2.4.2-2.1_amd64.deb) …
Selecting previously deselected package ttf-dejavu-core.
Unpacking ttf-dejavu-core (from …/ttf-dejavu-core_2.31-1_all.deb) …
Selecting previously deselected package fontconfig-config.
Unpacking fontconfig-config (from …/fontconfig-config_2.8.0-2.1_all.deb) …
Selecting previously deselected package libfontconfig1.
Unpacking libfontconfig1 (from …/libfontconfig1_2.8.0-2.1_amd64.deb) …
Selecting previously deselected package libjpeg62.
Unpacking libjpeg62 (from …/libjpeg62_6b1-1_amd64.deb) …
Selecting previously deselected package libpng12-0.
Unpacking libpng12-0 (from …/libpng12-0_1.2.44-1_amd64.deb) …
Selecting previously deselected package libxpm4.
Unpacking libxpm4 (from …/libxpm4_1%3a3.5.8-1_amd64.deb) …
Selecting previously deselected package libgd2-xpm.
Unpacking libgd2-xpm (from …/libgd2-xpm_2.0.36~rc1~dfsg-5_amd64.deb) …
Selecting previously deselected package libgeoip1.
Unpacking libgeoip1 (from …/libgeoip1_1.4.7~beta6+dfsg-1_amd64.deb) …
Selecting previously deselected package webalizer.
Unpacking webalizer (from …/webalizer_2.01.10-32.7_amd64.deb) …
Selecting previously deselected package webmin.
Unpacking webmin (from …/archives/webmin_1.534_all.deb) …
Selecting previously deselected package file.
Unpacking file (from …/archives/file_5.04-5_amd64.deb) …
Selecting previously deselected package libxml2.
Unpacking libxml2 (from …/libxml2_2.7.8.dfsg-2_amd64.deb) …
Selecting previously deselected package libisc62.
Unpacking libisc62 (from …/libisc62_1%3a9.7.2.dfsg.P3-1.1_amd64.deb) …
Selecting previously deselected package libdns69.
Unpacking libdns69 (from …/libdns69_1%3a9.7.2.dfsg.P3-1.1_amd64.deb) …
Selecting previously deselected package libisccc60.
Unpacking libisccc60 (from …/libisccc60_1%3a9.7.2.dfsg.P3-1.1_amd64.deb) …
Selecting previously deselected package libisccfg62.
Unpacking libisccfg62 (from …/libisccfg62_1%3a9.7.2.dfsg.P3-1.1_amd64.deb) …
Selecting previously deselected package libbind9-60.
Unpacking libbind9-60 (from …/libbind9-60_1%3a9.7.2.dfsg.P3-1.1_amd64.deb) …
Selecting previously deselected package liblwres60.
Unpacking liblwres60 (from …/liblwres60_1%3a9.7.2.dfsg.P3-1.1_amd64.deb) …
Selecting previously deselected package procmail.
Unpacking procmail (from …/procmail_3.22-19_amd64.deb) …
Selecting previously deselected package apache2-doc.
Unpacking apache2-doc (from …/apache2-doc_2.2.16-6_all.deb) …
Selecting previously deselected package awstats.
Unpacking awstats (from …/awstats_6.9.5~dfsg-5_all.deb) …
Selecting previously deselected package bind9utils.
Unpacking bind9utils (from …/bind9utils_1%3a9.7.2.dfsg.P3-1.1_amd64.deb) …
Selecting previously deselected package bind9.
Unpacking bind9 (from …/bind9_1%3a9.7.2.dfsg.P3-1.1_amd64.deb) …
Selecting previously deselected package binutils.
Unpacking binutils (from …/binutils_2.20.1-16_amd64.deb) …
Selecting previously deselected package ca-certificates.
Unpacking ca-certificates (from …/ca-certificates_20090814+nmu2_all.deb) …
Selecting previously deselected package libltdl7.
Unpacking libltdl7 (from …/libltdl7_2.2.6b-2_amd64.deb) …
Selecting previously deselected package libtommath0.
Unpacking libtommath0 (from …/libtommath0_0.39-4_amd64.deb) …
Selecting previously deselected package libclamav6.
Unpacking libclamav6 (from …/libclamav6_0.96.5+dfsg-1.1_amd64.deb) …
Selecting previously deselected package clamav-base.
Unpacking clamav-base (from …/clamav-base_0.96.5+dfsg-1.1_all.deb) …
Selecting previously deselected package clamav-freshclam.
Unpacking clamav-freshclam (from …/clamav-freshclam_0.96.5+dfsg-1.1_amd64.deb) …
Selecting previously deselected package clamav.
Unpacking clamav (from …/clamav_0.96.5+dfsg-1.1_amd64.deb) …
Selecting previously deselected package clamav-daemon.
Unpacking clamav-daemon (from …/clamav-daemon_0.96.5+dfsg-1.1_amd64.deb) …
Selecting previously deselected package clamav-docs.
Unpacking clamav-docs (from …/clamav-docs_0.96.5+dfsg-1.1_all.deb) …
Selecting previously deselected package clamav-testfiles.
Unpacking clamav-testfiles (from …/clamav-testfiles_0.96.5+dfsg-1.1_all.deb) …
Selecting previously deselected package libgmp3c2.
Unpacking libgmp3c2 (from …/libgmp3c2_2%3a4.3.2+dfsg-1_amd64.deb) …
Selecting previously deselected package libmpfr4.
Unpacking libmpfr4 (from …/libmpfr4_3.0.0-2_amd64.deb) …
Selecting previously deselected package cpp-4.4.
Unpacking cpp-4.4 (from …/cpp-4.4_4.4.5-8_amd64.deb) …
Selecting previously deselected package cpp.
Unpacking cpp (from …/cpp_4%3a4.4.5-1_amd64.deb) …
Selecting previously deselected package db4.8-util.
Unpacking db4.8-util (from …/db4.8-util_4.8.30-2_amd64.deb) …
Selecting previously deselected package libpq5.
Unpacking libpq5 (from …/libpq5_8.4.7-0squeeze2_amd64.deb) …
Selecting previously deselected package dovecot-common.
Unpacking dovecot-common (from …/dovecot-common_1%3a1.2.15-4_amd64.deb) …
Selecting previously deselected package dovecot-imapd.
Unpacking dovecot-imapd (from …/dovecot-imapd_1%3a1.2.15-4_amd64.deb) …
Selecting previously deselected package dovecot-pop3d.
Unpacking dovecot-pop3d (from …/dovecot-pop3d_1%3a1.2.15-4_amd64.deb) …
Selecting previously deselected package libgomp1.
Unpacking libgomp1 (from …/libgomp1_4.4.5-8_amd64.deb) …
Selecting previously deselected package gcc-4.4.
Unpacking gcc-4.4 (from …/gcc-4.4_4.4.5-8_amd64.deb) …
Selecting previously deselected package gcc.
Unpacking gcc (from …/gcc_4%3a4.4.5-1_amd64.deb) …
Selecting previously deselected package geoip-database.
Unpacking geoip-database (from …/geoip-database_1.4.7~beta6+dfsg-1_all.deb) …
Selecting previously deselected package heirloom-mailx.
Unpacking heirloom-mailx (from …/heirloom-mailx_12.4-2_amd64.deb) …
Selecting previously deselected package libreadline5.
Unpacking libreadline5 (from …/libreadline5_5.2-7_amd64.deb) …
Selecting previously deselected package libruby1.8.
Unpacking libruby1.8 (from …/libruby1.8_1.8.7.302-2_amd64.deb) …
Selecting previously deselected package libapache-ruby1.8.
Unpacking libapache-ruby1.8 (from …/libapache-ruby1.8_1.2.6-2_all.deb) …
Selecting previously deselected package libapache2-mod-fcgid.
Unpacking libapache2-mod-fcgid (from …/libapache2-mod-fcgid_1%3a2.3.6-1_amd64.deb) …
Selecting previously deselected package libonig2.
Unpacking libonig2 (from …/libonig2_5.9.1-1_amd64.deb) …
Selecting previously deselected package libqdbm14.
Unpacking libqdbm14 (from …/libqdbm14_1.8.77-4_amd64.deb) …
Selecting previously deselected package php5-common.
Unpacking php5-common (from …/php5-common_5.3.3-7_amd64.deb) …
Selecting previously deselected package libapache2-mod-php5.
Unpacking libapache2-mod-php5 (from …/libapache2-mod-php5_5.3.3-7_amd64.deb) …
Selecting previously deselected package libapache2-mod-ruby.
Unpacking libapache2-mod-ruby (from …/libapache2-mod-ruby_1.2.6-2_amd64.deb) …
Selecting previously deselected package libneon27-gnutls.
Unpacking libneon27-gnutls (from …/libneon27-gnutls_0.29.3-3_amd64.deb) …
Selecting previously deselected package libserf-0-0.
Unpacking libserf-0-0 (from …/libserf-0-0_0.3.1-1_amd64.deb) …
Selecting previously deselected package libsvn1.
Unpacking libsvn1 (from …/libsvn1_1.6.12dfsg-5_amd64.deb) …
Selecting previously deselected package libapache2-svn.
Unpacking libapache2-svn (from …/libapache2-svn_1.6.12dfsg-5_amd64.deb) …
Selecting previously deselected package libc-dev-bin.
Unpacking libc-dev-bin (from …/libc-dev-bin_2.11.2-10_amd64.deb) …
Selecting previously deselected package linux-libc-dev.
Unpacking linux-libc-dev (from …/linux-libc-dev_2.6.32-30_amd64.deb) …
Selecting previously deselected package libc6-dev.
Unpacking libc6-dev (from …/libc6-dev_2.11.2-10_amd64.deb) …
Selecting previously deselected package liburi-perl.
Unpacking liburi-perl (from …/liburi-perl_1.54-2_all.deb) …
Selecting previously deselected package libcrypt-ssleay-perl.
Unpacking libcrypt-ssleay-perl (from …/libcrypt-ssleay-perl_0.57-2_amd64.deb) …
Selecting previously deselected package libdbd-pg-perl.
Unpacking libdbd-pg-perl (from …/libdbd-pg-perl_2.17.1-2_amd64.deb) …
Selecting previously deselected package libdigest-sha1-perl.
Unpacking libdigest-sha1-perl (from …/libdigest-sha1-perl_2.13-1_amd64.deb) …
Selecting previously deselected package libdigest-hmac-perl.
Unpacking libdigest-hmac-perl (from …/libdigest-hmac-perl_1.02+dfsg-1_all.deb) …
Selecting previously deselected package liberror-perl.
Unpacking liberror-perl (from …/liberror-perl_0.17-1_all.deb) …
Selecting previously deselected package libfcgi0ldbl.
Unpacking libfcgi0ldbl (from …/libfcgi0ldbl_2.4.0-8_amd64.deb) …
Selecting previously deselected package libfcgi-dev.
Unpacking libfcgi-dev (from …/libfcgi-dev_2.4.0-8_amd64.deb) …
Selecting previously deselected package libfile-copy-recursive-perl.
Unpacking libfile-copy-recursive-perl (from …/libfile-copy-recursive-perl_0.38-1_all.deb) …
Selecting previously deselected package libfont-afm-perl.
Unpacking libfont-afm-perl (from …/libfont-afm-perl_1.20-1_all.deb) …
Selecting previously deselected package libhtml-tagset-perl.
Unpacking libhtml-tagset-perl (from …/libhtml-tagset-perl_3.20-2_all.deb) …
Selecting previously deselected package libhtml-parser-perl.
Unpacking libhtml-parser-perl (from …/libhtml-parser-perl_3.66-1_amd64.deb) …
Selecting previously deselected package libhtml-tree-perl.
Unpacking libhtml-tree-perl (from …/libhtml-tree-perl_3.23-2_all.deb) …
Selecting previously deselected package libhtml-format-perl.
Unpacking libhtml-format-perl (from …/libhtml-format-perl_2.04-2_all.deb) …
Selecting previously deselected package libhtml-template-perl.
Unpacking libhtml-template-perl (from …/libhtml-template-perl_2.9-2_all.deb) …
Selecting previously deselected package libsocket6-perl.
Unpacking libsocket6-perl (from …/libsocket6-perl_0.23-1_amd64.deb) …
Selecting previously deselected package libio-socket-inet6-perl.
Unpacking libio-socket-inet6-perl (from …/libio-socket-inet6-perl_2.65-1.1_all.deb) …
Selecting previously deselected package libnetaddr-ip-perl.
Unpacking libnetaddr-ip-perl (from …/libnetaddr-ip-perl_4.028+dfsg-1_amd64.deb) …
Selecting previously deselected package libnet-ip-perl.
Unpacking libnet-ip-perl (from …/libnet-ip-perl_1.25-2_all.deb) …
Selecting previously deselected package libnet-dns-perl.
Unpacking libnet-dns-perl (from …/libnet-dns-perl_0.66-2_amd64.deb) …
Selecting previously deselected package libmail-spf-perl.
Unpacking libmail-spf-perl (from …/libmail-spf-perl_2.007-1_all.deb) …
Selecting previously deselected package libtimedate-perl.
Unpacking libtimedate-perl (from …/libtimedate-perl_1.2000-1_all.deb) …
Selecting previously deselected package libmailtools-perl.
Unpacking libmailtools-perl (from …/libmailtools-perl_2.06-1_all.deb) …
Selecting previously deselected package libnet-xwhois-perl.
Unpacking libnet-xwhois-perl (from …/libnet-xwhois-perl_0.90-3_all.deb) …
Selecting previously deselected package libpg-perl.
Unpacking libpg-perl (from …/libpg-perl_1%3a2.1.1-4_amd64.deb) …
Selecting previously deselected package libsys-hostname-long-perl.
Unpacking libsys-hostname-long-perl (from …/libsys-hostname-long-perl_1.4-2_all.deb) …
Selecting previously deselected package libwww-perl.
Unpacking libwww-perl (from …/libwww-perl_5.836-1_all.deb) …
Selecting previously deselected package libxml-namespacesupport-perl.
Unpacking libxml-namespacesupport-perl (from …/libxml-namespacesupport-perl_1.09-3_all.deb) …
Selecting previously deselected package libxml-parser-perl.
Unpacking libxml-parser-perl (from …/libxml-parser-perl_2.36-1.1+b1_amd64.deb) …
Selecting previously deselected package libxml-sax-perl.
Unpacking libxml-sax-perl (from …/libxml-sax-perl_0.96+dfsg-2_all.deb) …
Selecting previously deselected package libxml-sax-expat-perl.
Unpacking libxml-sax-expat-perl (from …/libxml-sax-expat-perl_0.40-1_all.deb) …
Selecting previously deselected package libxml-simple-perl.
Unpacking libxml-simple-perl (from …/libxml-simple-perl_2.18-3_all.deb) …
Selecting previously deselected package lsb-release.
Unpacking lsb-release (from …/lsb-release_3.2-23.2squeeze1_all.deb) …
Selecting previously deselected package make.
Unpacking make (from …/archives/make_3.81-8_amd64.deb) …
Selecting previously deselected package manpages-dev.
Unpacking manpages-dev (from …/manpages-dev_3.27-1_all.deb) …
Selecting previously deselected package mysql-client.
Unpacking mysql-client (from …/mysql-client_5.1.49-3_all.deb) …
Selecting previously deselected package mysql-server.
Unpacking mysql-server (from …/mysql-server_5.1.49-3_all.deb) …
Selecting previously deselected package php5-cli.
Unpacking php5-cli (from …/php5-cli_5.3.3-7_amd64.deb) …
Selecting previously deselected package php-pear.
Unpacking php-pear (from …/php-pear_5.3.3-7_all.deb) …
Selecting previously deselected package php5-cgi.
Unpacking php5-cgi (from …/php5-cgi_5.3.3-7_amd64.deb) …
Selecting previously deselected package php5.
Unpacking php5 (from …/archives/php5_5.3.3-7_all.deb) …
Selecting previously deselected package php5-mysql.
Unpacking php5-mysql (from …/php5-mysql_5.3.3-7_amd64.deb) …
Selecting previously deselected package php5-suhosin.
Unpacking php5-suhosin (from …/php5-suhosin_0.9.32.1-1_amd64.deb) …
Selecting previously deselected package postgresql-client-common.
Unpacking postgresql-client-common (from …/postgresql-client-common_113_all.deb) …
Selecting previously deselected package postgresql-client-8.4.
Unpacking postgresql-client-8.4 (from …/postgresql-client-8.4_8.4.7-0squeeze2_amd64.deb) …
Selecting previously deselected package postgresql-common.
Unpacking postgresql-common (from …/postgresql-common_113_all.deb) …
Selecting previously deselected package postgresql-8.4.
Unpacking postgresql-8.4 (from …/postgresql-8.4_8.4.7-0squeeze2_amd64.deb) …
Selecting previously deselected package postgresql.
Unpacking postgresql (from …/postgresql_8.4.7-0squeeze2_all.deb) …
Selecting previously deselected package postgresql-client.
Unpacking postgresql-client (from …/postgresql-client_8.4.7-0squeeze2_all.deb) …
Selecting previously deselected package update-inetd.
Unpacking update-inetd (from …/update-inetd_4.38+nmu1_all.deb) …
Selecting previously deselected package proftpd-basic.
Unpacking proftpd-basic (from …/proftpd-basic_1.3.3a-6squeeze1_amd64.deb) …
Selecting previously deselected package re2c.
Unpacking re2c (from …/re2c_0.13.5-1_amd64.deb) …
Selecting previously deselected package ruby1.8.
Unpacking ruby1.8 (from …/ruby1.8_1.8.7.302-2_amd64.deb) …
Selecting previously deselected package ri1.8.
Unpacking ri1.8 (from …/ri1.8_1.8.7.302-2_all.deb) …
Selecting previously deselected package ri.
Unpacking ri (from …/apt/archives/ri_4.5_all.deb) …
Selecting previously deselected package ruby.
Unpacking ruby (from …/apt/archives/ruby_4.5_all.deb) …
Selecting previously deselected package sasl2-bin.
Unpacking sasl2-bin (from …/sasl2-bin_2.1.23.dfsg1-7_amd64.deb) …
Selecting previously deselected package scponly.
Unpacking scponly (from …/scponly_4.8-4.1_amd64.deb) …
Selecting previously deselected package sgml-base.
Unpacking sgml-base (from …/sgml-base_1.26+nmu1_all.deb) …
Selecting previously deselected package spamassassin.
Unpacking spamassassin (from …/spamassassin_3.3.1-1_all.deb) …
Selecting previously deselected package spamc.
Unpacking spamc (from …/spamc_3.3.1-1_amd64.deb) …
Selecting previously deselected package subversion.
Unpacking subversion (from …/subversion_1.6.12dfsg-5_amd64.deb) …
Selecting previously deselected package unzip.
Unpacking unzip (from …/archives/unzip_6.0-4_amd64.deb) …
Selecting previously deselected package xml-core.
Unpacking xml-core (from …/archives/xml-core_0.13_all.deb) …
Selecting previously deselected package zip.
Unpacking zip (from …/archives/zip_3.0-3_amd64.deb) …
Selecting previously deselected package apache2-suexec-custom.
Unpacking apache2-suexec-custom (from …/apache2-suexec-custom_2.2.16-6_amd64.deb) …
Selecting previously deselected package postfix-pcre.
Unpacking postfix-pcre (from …/postfix-pcre_2.7.1-1_amd64.deb) …
Setting up python2.6-minimal (2.6.6-8+b1) …
Configuration file `/etc/python2.6/sitecustomize.py’, does not exist on system.
Setting up mime-support (3.48-1) …
Configuration file `/etc/mime.types’, does not exist on system.
Configuration file `/etc/mailcap.order’, does not exist on system.
Setting up libexpat1 (2.0.1-7) …
Setting up python2.6 (2.6.6-8+b1) …
Setting up python-minimal (2.6.6-3+squeeze5) …
Setting up python (2.6.6-3+squeeze5) …
Setting up python-support (1.0.10) …
Setting up ucf (3.0025+nmu1) …
Configuration file `/etc/ucf.conf’, does not exist on system.
Setting up pwgen (2.06-1+b1) …
Setting up openssl (0.9.8o-4squeeze1) …
Configuration file `/etc/ssl/openssl.cnf’, does not exist on system.
Setting up ssl-cert (1.0.28) …
Setting up postfix (2.7.1-1) …
Configuration file `/etc/init.d/postfix’, does not exist on system.
Configuration file `/etc/ppp/ip-up.d/postfix’, does not exist on system.
Configuration file `/etc/ppp/ip-down.d/postfix’, does not exist on system.
Configuration file `/etc/network/if-up.d/postfix’, does not exist on system.
Configuration file `/etc/network/if-down.d/postfix’, does not exist on system.
Configuration file `/etc/postfix/postfix-files’, does not exist on system.
Configuration file `/etc/postfix/postfix-script’, does not exist on system.
Configuration file `/etc/postfix/post-install’, does not exist on system.
Configuration file `/etc/rsyslog.d/postfix.conf’, does not exist on system.
Configuration file `/etc/ufw/applications.d/postfix’, does not exist on system.
Configuration file /etc/resolvconf/update-libc.d/postfix', does not exist on system. Installing new config file as you requested. insserv: warning: script 'S10vzquota' missing LSB tags and overrides insserv: warning: script 'vzquota' missing LSB tags and overrides insserv: There is a loop between service vzquota and rmnologin if started insserv: loop involving service rmnologin at depth 2 insserv: loop involving service vzquota at depth 1 insserv: loop involving service rsyslog at depth 1 insserv: Starting vzquota depends on rmnologin and therefore on system facility $all’ which can not be true!
insserv: Starting vzquota depends on rmnologin and therefore on system facility $all' which can not be true! insserv: Starting vzquota depends on rmnologin and therefore on system facility $all’ which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing postfix (–configure):
subprocess installed post-installation script returned error exit status 1
Setting up libapr1 (1.4.2-6) …
Setting up libaprutil1 (1.3.9+dfsg-5) …
Setting up libaprutil1-dbd-sqlite3 (1.3.9+dfsg-5) …
Setting up libaprutil1-ldap (1.3.9+dfsg-5) …
Setting up libcap2 (1:2.19-3) …
Setting up libpcre3 (8.02-1.1) …
Setting up apache2.2-bin (2.2.16-6) …
Setting up apache2-utils (2.2.16-6) …
Setting up libmagic1 (5.04-5) …
Configuration file `/etc/magic’, does not exist on system.
Configuration file `/etc/magic.mime’, does not exist on system.
Setting up apache2.2-common (2.2.16-6) …
Configuration file `/etc/apache2/conf.d/security’, does not exist on system.
Configuration file `/etc/apache2/conf.d/localized-error-pages’, does not exist on system.
Configuration file `/etc/apache2/conf.d/other-vhosts-access-log’, does not exist on system.
Configuration file `/etc/apache2/conf.d/charset’, does not exist on system.
Configuration file `/etc/apache2/apache2.conf’, does not exist on system.
Configuration file `/etc/apache2/envvars’, does not exist on system.
Configuration file `/etc/apache2/magic’, does not exist on system.
Configuration file `/etc/apache2/mods-available/speling.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/autoindex.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/include.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authn_dbm.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/reqtimeout.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/log_forensic.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/cgid.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/proxy.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/status.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/actions.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/disk_cache.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/info.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/dbd.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authn_default.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authnz_ldap.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/rewrite.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/proxy_scgi.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/userdir.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/usertrack.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/cgi.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/alias.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/proxy_ajp.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/ident.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/ldap.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/dav_fs.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/ldap.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/mime.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/filter.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/mime_magic.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/unique_id.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/autoindex.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authz_user.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/info.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authz_default.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/setenvif.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authn_file.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/mem_cache.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/mem_cache.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/disk_cache.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/version.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/deflate.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/dav.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/proxy_balancer.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/deflate.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/proxy_connect.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/cern_meta.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/dir.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/actions.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authz_owner.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/dump_io.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/setenvif.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/file_cache.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/env.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/ext_filter.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/mime.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/negotiation.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/ssl.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/dav_lock.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/dir.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/cache.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/ssl.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/auth_digest.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authz_groupfile.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authn_alias.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/substitute.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/imagemap.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/proxy_ftp.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/userdir.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/auth_basic.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/suexec.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/dav_fs.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/charset_lite.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/proxy_ftp.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/vhost_alias.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/headers.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/proxy_http.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authz_host.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authz_dbm.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/proxy.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/status.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/mime_magic.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/alias.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/proxy_balancer.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/negotiation.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/reqtimeout.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/expires.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authn_anon.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/cgid.conf’, does not exist on system.
Configuration file `/etc/apache2/mods-available/asis.load’, does not exist on system.
Configuration file `/etc/apache2/mods-available/authn_dbd.load’, does not exist on system.
Configuration file `/etc/apache2/ports.conf’, does not exist on system.
Configuration file `/etc/apache2/sites-available/default-ssl’, does not exist on system.
Configuration file `/etc/apache2/sites-available/default’, does not exist on system.
Configuration file `/etc/bash_completion.d/apache2.2-common’, does not exist on system.
Configuration file `/etc/logrotate.d/apache2’, does not exist on system.
Configuration file `/etc/default/apache2’, does not exist on system.
Configuration file `/etc/init.d/apache2’, does not exist on system.
Configuration file /etc/cron.daily/apache2', does not exist on system. Installing new config file as you requested. Enabling site default. Enabling module alias. Enabling module autoindex. Enabling module dir. Enabling module env. Enabling module mime. Enabling module negotiation. Enabling module setenvif. Enabling module status. Enabling module auth_basic. Enabling module deflate. Enabling module authz_default. Enabling module authz_user. Enabling module authz_groupfile. Enabling module authn_file. Enabling module authz_host. Enabling module reqtimeout. insserv: warning: script 'S10vzquota' missing LSB tags and overrides insserv: warning: script 'vzquota' missing LSB tags and overrides insserv: There is a loop between service vzquota and rmnologin if started insserv: loop involving service rmnologin at depth 2 insserv: loop involving service vzquota at depth 1 insserv: loop involving service rsyslog at depth 1 insserv: Starting vzquota depends on rmnologin and therefore on system facility $all’ which can not be true!
insserv: Starting vzquota depends on rmnologin and therefore on system facility `$all’ which can not be true!
dpkg: error processing apache2.2-common (–configure):
dpkg: dependency problems prevent configuration of apache2-mpm-prefork:
apache2-mpm-prefork depends on apache2.2-common (= 2.2.16-6); however:
Package apache2.2-common is not configured yet.
dpkg: error processing apache2-mpm-prefork (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of apache2:
apache2 depends on apache2-mpm-worker (= 2.2.16-6) | apache2-mpm-prefork (= 2.2.16-6) | apache2-mpm-event (= 2.2.16-6) | apache2-mpm-itk (= 2.2.16-6); however:
Package apache2-mpm-worker is not installed.
Package apache2-mpm-prefork is not configured yet.
Package apache2-mpm-event is not installed.
Package apache2-mpm-itk is not installed.
apache2 depends on apache2.2-common (= 2.2.16-6); however:
dpkg: error processing apache2 (–configure):
dpkg: dependency problems prevent configuration of mailman:
mailman depends on exim4 | mail-transport-agent; however:
Package exim4 is not installed.
Package mail-transport-agent is not installed.
Package postfix which provides mail-transport-agent is not configured yet.
mailman depends on apache2 | httpd; however:
Package apache2 is not configured yet.
Package apache2-mpm-prefork which provides apache2 is not configured yet.
Package httpd is not installed.
Package apache2-mpm-prefork which provides httpd is not configured yet.
dpkg: error processing mailman (–configure):
Setting up libnet-daemon-perl (0.43-1) …
Setting up libplrpc-perl (0.2020-2) …
Setting up libdbi-perl (1.612-1) …
Setting up libmysqlclient16 (5.1.49-3) …
Setting up libdbd-mysql-perl (4.016-1) …
Setting up mysql-client-5.1 (5.1.49-3) …
Setting up psmisc (22.11-1) …
Setting up mysql-server-core-5.1 (5.1.49-3) …
Setting up mysql-server-5.1 (5.1.49-3) …
Configuration file `/etc/init.d/mysql’, does not exist on system.
Configuration file `/etc/logrotate.d/mysql-server’, does not exist on system.
Configuration file `/etc/mysql/conf.d/mysqld_safe_syslog.cnf’, does not exist on system.
Configuration file `/etc/mysql/debian-start’, does not exist on system.
Configuration file `/etc/logcheck/ignore.d.workstation/mysql-server-5_1’, does not exist on system.
Configuration file `/etc/logcheck/ignore.d.server/mysql-server-5_1’, does not exist on system.
Configuration file /etc/logcheck/ignore.d.paranoid/mysql-server-5_1', does not exist on system. Installing new config file as you requested. Stopping MySQL database server: mysqld. insserv: warning: script 'S10vzquota' missing LSB tags and overrides insserv: warning: script 'vzquota' missing LSB tags and overrides insserv: There is a loop between service vzquota and rmnologin if started insserv: loop involving service rmnologin at depth 2 insserv: loop involving service vzquota at depth 1 insserv: loop involving service rsyslog at depth 1 insserv: Starting vzquota depends on rmnologin and therefore on system facility $all’ which can not be true!
dpkg: error processing mysql-server-5.1 (–configure):
Setting up libnet-ssleay-perl (1.36-1) …
Setting up libauthen-pam-perl (0.16-2) …
Setting up libio-pty-perl (1:1.08-1) …
Setting up libapt-pkg-perl (0.1.24+b1) …
Setting up apt-show-versions (0.16) …
Configuration file `/etc/bash_completion.d/apt-show-versions’, does not exist on system.
Configuration file `/etc/cron.daily/apt-show-versions’, does not exist on system.
** initializing cache. This may take a while **
Setting up usermin (1.450) …
Configuration file `/etc/pam.d/usermin’, does not exist on system.
Usermin install complete. You can now login to https://fivespace:20000/
as any user on the system.
Setting up libfreetype6 (2.4.2-2.1) …
Setting up ttf-dejavu-core (2.31-1) …
Setting up fontconfig-config (2.8.0-2.1) …
Configuration file `/etc/fonts/conf.avail/10-sub-pixel-bgr.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/10-no-sub-pixel.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/45-latin.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/70-yes-bitmaps.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/40-nonlatin.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/60-latin.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/30-urw-aliases.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/10-unhinted.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/90-synthetic.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/70-force-bitmaps.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/70-no-bitmaps.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/69-unifont.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/49-sansserif.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/65-khmer.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/65-nonlatin.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/10-sub-pixel-rgb.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/25-unhint-nonlatin.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/20-fix-globaladvance.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/10-sub-pixel-vrgb.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/65-fonts-persian.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/20-unhint-small-vera.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/10-sub-pixel-vbgr.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/50-user.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/51-local.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/80-delicious.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/10-autohint.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.avail/30-metric-aliases.conf’, does not exist on system.
Configuration file `/etc/fonts/fonts.conf’, does not exist on system.
Configuration file `/etc/fonts/conf.d/README’, does not exist on system.
Configuration file `/etc/fonts/fonts.dtd’, does not exist on system.
Setting up libfontconfig1 (2.8.0-2.1) …
Setting up libjpeg62 (6b1-1) …
Setting up libpng12-0 (1.2.44-1) …
Setting up libxpm4 (1:3.5.8-1) …
Setting up libgd2-xpm (2.0.36~rc1~dfsg-5) …
Setting up libgeoip1 (1.4.7~beta6+dfsg-1) …
Setting up webalizer (2.01.10-32.7) …
Configuration file `/etc/webalizer/webalizer.conf.sample’, does not exist on system.
Configuration file `/etc/cron.daily/webalizer’, does not exist on system.
/var/www/webalizer created
Setting up webmin (1.534) …
Configuration file `/etc/pam.d/webmin’, does not exist on system.
Webmin install complete. You can now login to https://fivespace:10000/
as root with your root password, or as any user who can use sudo
to run commands as root.
Setting up file (5.04-5) …
Setting up libxml2 (2.7.8.dfsg-2) …
Setting up libisc62 (1:9.7.2.dfsg.P3-1.1) …
Setting up libdns69 (1:9.7.2.dfsg.P3-1.1) …
Setting up libisccc60 (1:9.7.2.dfsg.P3-1.1) …
Setting up libisccfg62 (1:9.7.2.dfsg.P3-1.1) …
Setting up libbind9-60 (1:9.7.2.dfsg.P3-1.1) …
Setting up liblwres60 (1:9.7.2.dfsg.P3-1.1) …
Setting up procmail (3.22-19) …
Setting up apache2-doc (2.2.16-6) …
Configuration file `/etc/apache2/conf.d/apache2-doc’, does not exist on system.
Reloading web server config: apache2Setting up awstats (6.9.5~dfsg-5) …
Configuration file `/etc/cron.d/awstats’, does not exist on system.
Configuration file `/etc/default/awstats’, does not exist on system.
Configuration file `/etc/awstats/awstats.conf.local’, does not exist on system.
Configuration file `/etc/awstats/awstats.conf’, does not exist on system.
Setting up bind9utils (1:9.7.2.dfsg.P3-1.1) …
Setting up bind9 (1:9.7.2.dfsg.P3-1.1) …
Configuration file `/etc/ufw/applications.d/bind9’, does not exist on system.
Configuration file `/etc/apparmor.d/usr.sbin.named’, does not exist on system.
Configuration file `/etc/bind/bind.keys’, does not exist on system.
Configuration file `/etc/bind/db.0’, does not exist on system.
Configuration file `/etc/bind/db.255’, does not exist on system.
Configuration file `/etc/bind/db.empty’, does not exist on system.
Configuration file `/etc/bind/zones.rfc1918’, does not exist on system.
Configuration file `/etc/bind/db.127’, does not exist on system.
Configuration file `/etc/bind/db.local’, does not exist on system.
Configuration file `/etc/bind/db.root’, does not exist on system.
Configuration file `/etc/bind/named.conf’, does not exist on system.
Configuration file `/etc/bind/named.conf.local’, does not exist on system.
Configuration file `/etc/bind/named.conf.default-zones’, does not exist on system.
Configuration file `/etc/bind/named.conf.options’, does not exist on system.
Configuration file `/etc/ppp/ip-up.d/bind9’, does not exist on system.
Configuration file `/etc/ppp/ip-down.d/bind9’, does not exist on system.
Configuration file `/etc/network/if-up.d/bind9’, does not exist on system.
Configuration file `/etc/network/if-down.d/bind9’, does not exist on system.
Configuration file /etc/init.d/bind9', does not exist on system. Installing new config file as you requested. Adding group bind’ (GID 107) …
Done.
Adding system user bind' (UID 104) ... Adding new user bind’ (UID 104) with group bind' ... Not creating home directory /var/cache/bind’.
wrote key file “/etc/bind/rndc.key”
Starting domain name service…: bind9.
insserv: warning: script ‘S10vzquota’ missing LSB tags and overrides
insserv: warning: script ‘vzquota’ missing LSB tags and overrides
insserv: Starting vzquota depends on rmnologin and therefore on system facility $all' which can not be true! insserv: There is a loop between service vzquota and rmnologin if started insserv: Starting vzquota depends on rmnologin and therefore on system facility $all’ which can not be true!
dpkg: error processing bind9 (–configure):
Setting up binutils (2.20.1-16) …
Setting up ca-certificates (20090814+nmu2) …
Updating certificates in /etc/ssl/certs… WARNING: Skipping duplicate certificate brasil.gov.br.pem
141 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d…done.
Setting up libltdl7 (2.2.6b-2) …
Setting up libtommath0 (0.39-4) …
Setting up libclamav6 (0.96.5+dfsg-1.1) …
Setting up clamav-base (0.96.5+dfsg-1.1) …
Setting up clamav-freshclam (0.96.5+dfsg-1.1) …
Configuration file `/etc/network/if-up.d/clamav-freshclam-ifupdown’, does not exist on system.
Configuration file `/etc/network/if-down.d/clamav-freshclam-ifupdown’, does not exist on system.
Configuration file `/etc/ppp/ip-up.d/clamav-freshclam-ifupdown’, does not exist on system.
Configuration file `/etc/ppp/ip-down.d/clamav-freshclam-ifupdown’, does not exist on system.
Configuration file `/etc/logcheck/ignore.d.server/clamav-freshclam’, does not exist on system.
Configuration file /etc/init.d/clamav-freshclam', does not exist on system. Installing new config file as you requested. insserv: warning: script 'S10vzquota' missing LSB tags and overrides insserv: warning: script 'vzquota' missing LSB tags and overrides insserv: There is a loop between service vzquota and rmnologin if started insserv: loop involving service rmnologin at depth 2 insserv: loop involving service vzquota at depth 1 insserv: loop involving service rsyslog at depth 1 insserv: Starting vzquota depends on rmnologin and therefore on system facility $all’ which can not be true!
dpkg: error processing clamav-freshclam (–configure):
dpkg: dependency problems prevent configuration of clamav:
clamav depends on clamav-freshclam | clamav-data; however:
Package clamav-freshclam is not configured yet.
Package clamav-data is not installed.
Package clamav-freshclam which provides clamav-data is not configured yet.
dpkg: error processing clamav (–configure):
dpkg: dependency problems prevent configuration of clamav-daemon:
clamav-daemon depends on clamav-freshclam | clamav-data; however:
dpkg: error processing clamav-daemon (–configure):
Setting up clamav-docs (0.96.5+dfsg-1.1) …
Setting up clamav-testfiles (0.96.5+dfsg-1.1) …
Setting up libgmp3c2 (2:4.3.2+dfsg-1) …
Setting up libmpfr4 (3.0.0-2) …
Setting up cpp-4.4 (4.4.5-8) …
Setting up cpp (4:4.4.5-1) …
Setting up db4.8-util (4.8.30-2) …
Setting up libpq5 (8.4.7-0squeeze2) …
Setting up dovecot-common (1:1.2.15-4) …
Configuration file `/etc/dovecot/dovecot-db-example.conf’, does not exist on system.
Configuration file `/etc/dovecot/dovecot-dict-sql-example.conf’, does not exist on system.
Configuration file `/etc/pam.d/dovecot’, does not exist on system.
Configuration file `/etc/default/dovecot’, does not exist on system.
Configuration file `/etc/init.d/dovecot’, does not exist on system.
Configuration file `/etc/cron.daily/dovecot’, does not exist on system.
Creating config file /etc/dovecot/dovecot.conf with new version
Creating config file /etc/dovecot/dovecot-ldap.conf with new version
Creating config file /etc/dovecot/dovecot-sql.conf with new version
Creating generic self-signed certificate: /etc/ssl/certs/dovecot.pem
This certificate will expire in 10 years.
(replace with hand-crafted or authorized one if needed).
dpkg: error processing dovecot-common (–configure):
dpkg: dependency problems prevent configuration of dovecot-imapd:
dovecot-imapd depends on dovecot-common (= 1:1.2.15-4); however:
Package dovecot-common is not configured yet.
dpkg: error processing dovecot-imapd (–configure):
dpkg: dependency problems prevent configuration of dovecot-pop3d:
dovecot-pop3d depends on dovecot-common (= 1:1.2.15-4); however:
dpkg: error processing dovecot-pop3d (–configure):
Setting up libgomp1 (4.4.5-8) …
Setting up gcc-4.4 (4.4.5-8) …
Setting up gcc (4:4.4.5-1) …
Setting up geoip-database (1.4.7~beta6+dfsg-1) …
Setting up heirloom-mailx (12.4-2) …
Configuration file `/etc/nail.rc’, does not exist on system.
update-alternatives: using /usr/bin/heirloom-mailx to provide /usr/bin/mailx (mailx) in auto mode.
Setting up libreadline5 (5.2-7) …
Setting up libruby1.8 (1.8.7.302-2) …
Setting up libapache-ruby1.8 (1.2.6-2) …
dpkg: dependency problems prevent configuration of libapache2-mod-fcgid:
libapache2-mod-fcgid depends on apache2.2-common; however:
dpkg: error processing libapache2-mod-fcgid (–configure):
Setting up libonig2 (5.9.1-1) …
Setting up libqdbm14 (1.8.77-4) …
Setting up php5-common (5.3.3-7) …
Configuration file `/etc/cron.d/php5’, does not exist on system.
Configuration file `/etc/php5/conf.d/pdo.ini’, does not exist on system.
dpkg: dependency problems prevent configuration of libapache2-mod-php5:
libapache2-mod-php5 depends on apache2-mpm-prefork (>> 2.0.52) | apache2-mpm-itk; however:
libapache2-mod-php5 depends on apache2.2-common; however:
dpkg: error processing libapache2-mod-php5 (–configure):
dpkg: dependency problems prevent configuration of libapache2-mod-ruby:
libapache2-mod-ruby depends on apache2.2-common; however:
dpkg: error processing libapache2-mod-ruby (–configure):
Setting up libneon27-gnutls (0.29.3-3) …
Setting up libserf-0-0 (0.3.1-1) …
Setting up libsvn1 (1.6.12dfsg-5) …
dpkg: dependency problems prevent configuration of libapache2-svn:
libapache2-svn depends on apache2.2-common; however:
dpkg: error processing libapache2-svn (–configure):
Setting up libc-dev-bin (2.11.2-10) …
Setting up linux-libc-dev (2.6.32-30) …
Setting up libc6-dev (2.11.2-10) …
Setting up liburi-perl (1.54-2) …
Setting up libcrypt-ssleay-perl (0.57-2) …
Setting up libdbd-pg-perl (2.17.1-2) …
Setting up libdigest-sha1-perl (2.13-1) …
Setting up libdigest-hmac-perl (1.02+dfsg-1) …
Setting up liberror-perl (0.17-1) …
Setting up libfcgi0ldbl (2.4.0-8) …
Setting up libfcgi-dev (2.4.0-8) …
Setting up libfile-copy-recursive-perl (0.38-1) …
Setting up libfont-afm-perl (1.20-1) …
Setting up libhtml-tagset-perl (3.20-2) …
Setting up libhtml-parser-perl (3.66-1) …
Setting up libhtml-tree-perl (3.23-2) …
Setting up libhtml-format-perl (2.04-2) …
Setting up libhtml-template-perl (2.9-2) …
Setting up libsocket6-perl (0.23-1) …
Setting up libio-socket-inet6-perl (2.65-1.1) …
Setting up libnetaddr-ip-perl (4.028+dfsg-1) …
Setting up libnet-ip-perl (1.25-2) …
Setting up libnet-dns-perl (0.66-2) …
Setting up libmail-spf-perl (2.007-1) …
Setting up libtimedate-perl (1.2000-1) …
Setting up libmailtools-perl (2.06-1) …
Setting up libnet-xwhois-perl (0.90-3) …
Setting up libpg-perl (1:2.1.1-4) …
Setting up libsys-hostname-long-perl (1.4-2) …
Setting up libwww-perl (5.836-1) …
Setting up libxml-namespacesupport-perl (1.09-3) …
Setting up libxml-parser-perl (2.36-1.1+b1) …
Setting up libxml-sax-perl (0.96+dfsg-2) …
update-perl-sax-parsers: Registering Perl SAX parser XML::SAX::PurePerl with priority 10…
update-perl-sax-parsers: Updating overall Perl SAX parser modules info file…
Creating config file /etc/perl/XML/SAX/ParserDetails.ini with new version
Setting up libxml-sax-expat-perl (0.40-1) …
update-perl-sax-parsers: Registering Perl SAX parser XML::SAX::Expat with priority 50…
Replacing config file /etc/perl/XML/SAX/ParserDetails.ini with new version
Setting up libxml-simple-perl (2.18-3) …
Setting up lsb-release (3.2-23.2squeeze1) …
Setting up make (3.81-8) …
Setting up manpages-dev (3.27-1) …
Setting up mysql-client (5.1.49-3) …
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.1; however:
Package mysql-server-5.1 is not configured yet.
dpkg: error processing mysql-server (–configure):
Setting up php5-cli (5.3.3-7) …
Creating config file /etc/php5/cli/php.ini with new version
update-alternatives: using /usr/bin/php5 to provide /usr/bin/php (php) in auto mode.
Setting up php-pear (5.3.3-7) …
Configuration file `/etc/pear/pear.conf’, does not exist on system.
Setting up php5-cgi (5.3.3-7) …
Creating config file /etc/php5/cgi/php.ini with new version
update-alternatives: using /usr/bin/php5-cgi to provide /usr/bin/php-cgi (php-cgi) in auto mode.
update-alternatives: using /usr/lib/cgi-bin/php5 to provide /usr/lib/cgi-bin/php (php-cgi-bin) in auto mode.
Setting up php5 (5.3.3-7) …
Setting up php5-mysql (5.3.3-7) …
Configuration file `/etc/php5/conf.d/pdo_mysql.ini’, does not exist on system.
Configuration file `/etc/php5/conf.d/mysqli.ini’, does not exist on system.
Configuration file `/etc/php5/conf.d/mysql.ini’, does not exist on system.
Setting up php5-suhosin (0.9.32.1-1) …
Configuration file `/etc/php5/conf.d/suhosin.ini’, does not exist on system.
Setting up postgresql-client-common (113) …
Configuration file `/etc/postgresql-common/user_clusters’, does not exist on system.
Setting up postgresql-client-8.4 (8.4.7-0squeeze2) …
update-alternatives: using /usr/share/postgresql/8.4/man/man1/psql.1.gz to provide /usr/share/man/man1/psql.1.gz (psql.1.gz) in auto mode.
Setting up postgresql-common (113) …
Configuration file `/etc/init.d/postgresql’, does not exist on system.
Configuration file /etc/logrotate.d/postgresql-common', does not exist on system. Installing new config file as you requested. Adding user postgres to group ssl-cert Building PostgreSQL dictionaries from installed myspell/hunspell packages... insserv: warning: script 'S10vzquota' missing LSB tags and overrides insserv: warning: script 'vzquota' missing LSB tags and overrides insserv: There is a loop between service vzquota and rmnologin if started insserv: loop involving service rmnologin at depth 2 insserv: loop involving service vzquota at depth 1 insserv: loop involving service rsyslog at depth 1 insserv: Starting vzquota depends on rmnologin and therefore on system facility $all’ which can not be true!
dpkg: error processing postgresql-common (–configure):
dpkg: dependency problems prevent configuration of postgresql-8.4:
postgresql-8.4 depends on postgresql-common (>= 109~); however:
Package postgresql-common is not configured yet.
dpkg: error processing postgresql-8.4 (–configure):
dpkg: dependency problems prevent configuration of postgresql:
postgresql depends on postgresql-8.4; however:
Package postgresql-8.4 is not configured yet.
dpkg: error processing postgresql (–configure):
Setting up postgresql-client (8.4.7-0squeeze2) …
Setting up update-inetd (4.38+nmu1) …
Setting up proftpd-basic (1.3.3a-6squeeze1) …
Configuration file `/etc/init.d/proftpd’, does not exist on system.
Configuration file `/etc/default/proftpd’, does not exist on system.
Configuration file `/etc/pam.d/proftpd’, does not exist on system.
Configuration file `/etc/proftpd/dhparams.pem’, does not exist on system.
Configuration file `/etc/proftpd/blacklist.dat’, does not exist on system.
Configuration file `/etc/logrotate.d/proftpd-basic’, does not exist on system.
Configuration file /etc/ftpusers', does not exist on system. Installing new config file as you requested. grep: /etc/inetd.conf: No such file or directory Warning: The home dir /var/run/proftpd you specified can't be accessed: No such file or directory Adding system user proftpd’ (UID 108) …
Adding new user proftpd' (UID 108) with group nogroup’ …
Not creating home directory /var/run/proftpd'. Adding system user ftp’ (UID 109) …
Adding new user ftp' (UID 109) with group nogroup’ …
Creating home directory /home/ftp' ... /usr/share/proftpd/templates/welcome.msg’ -> /home/ftp/welcome.msg.proftpd-new' insserv: warning: script 'S10vzquota' missing LSB tags and overrides insserv: warning: script 'vzquota' missing LSB tags and overrides insserv: There is a loop between service vzquota and rmnologin if started insserv: loop involving service rmnologin at depth 2 insserv: loop involving service vzquota at depth 1 insserv: loop involving service rsyslog at depth 1 insserv: Starting vzquota depends on rmnologin and therefore on system facility $all’ which can not be true!
dpkg: error processing proftpd-basic (–configure):
Setting up re2c (0.13.5-1) …
Setting up ruby1.8 (1.8.7.302-2) …
Setting up ri1.8 (1.8.7.302-2) …
Setting up ri (4.5) …
Setting up ruby (4.5) …
Setting up sasl2-bin (2.1.23.dfsg1-7) …
Configuration file `/etc/default/saslauthd’, does not exist on system.
Configuration file /etc/init.d/saslauthd', does not exist on system. Installing new config file as you requested. update-rc.d: warning: saslauthd stop runlevel arguments (0 1 6) do not match LSB Default-Stop values (1) insserv: warning: script 'S10vzquota' missing LSB tags and overrides insserv: warning: script 'vzquota' missing LSB tags and overrides insserv: There is a loop between service vzquota and rmnologin if started insserv: loop involving service rmnologin at depth 2 insserv: loop involving service vzquota at depth 1 insserv: loop involving service rsyslog at depth 1 insserv: Starting vzquota depends on rmnologin and therefore on system facility $all’ which can not be true!
dpkg: error processing sasl2-bin (–configure):
Setting up scponly (4.8-4.1) …
Configuration file `/etc/scponly/debuglevel’, does not exist on system.
Setting up sgml-base (1.26+nmu1) …
Setting up spamassassin (3.3.1-1) …
Configuration file `/etc/default/spamassassin’, does not exist on system.
Configuration file `/etc/spamassassin/v330.pre’, does not exist on system.
Configuration file `/etc/spamassassin/local.cf’, does not exist on system.
Configuration file `/etc/spamassassin/v320.pre’, does not exist on system.
Configuration file `/etc/spamassassin/v310.pre’, does not exist on system.
Configuration file `/etc/spamassassin/v312.pre’, does not exist on system.
Configuration file `/etc/spamassassin/init.pre’, does not exist on system.
Configuration file `/etc/spamassassin/65_debian.cf’, does not exist on system.
Configuration file `/etc/cron.daily/spamassassin’, does not exist on system.
Configuration file /etc/init.d/spamassassin', does not exist on system. Installing new config file as you requested. insserv: warning: script 'S10vzquota' missing LSB tags and overrides insserv: warning: script 'vzquota' missing LSB tags and overrides insserv: There is a loop between service vzquota and rmnologin if started insserv: loop involving service rmnologin at depth 2 insserv: loop involving service vzquota at depth 1 insserv: loop involving service rsyslog at depth 1 insserv: Starting vzquota depends on rmnologin and therefore on system facility $all’ which can not be true!
dpkg: error processing spamassassin (–configure):
Setting up spamc (3.3.1-1) …
Setting up subversion (1.6.12dfsg-5) …
Configuration file `/etc/emacs/site-start.d/50psvn.el’, does not exist on system.
Configuration file `/etc/subversion/config’, does not exist on system.
Configuration file `/etc/subversion/servers’, does not exist on system.
Configuration file `/etc/bash_completion.d/subversion’, does not exist on system.
Setting up unzip (6.0-4) …
Setting up xml-core (0.13) …
Setting up zip (3.0-3) …
dpkg: dependency problems prevent configuration of apache2-suexec-custom:
apache2-suexec-custom depends on apache2.2-common; however:
dpkg: error processing apache2-suexec-custom (–configure):
dpkg: dependency problems prevent configuration of postfix-pcre:
postfix-pcre depends on postfix (= 2.7.1-1); however:
Package postfix is not configured yet.
dpkg: error processing postfix-pcre (–configure):
Processing triggers for python-support …
postfix
apache2.2-common
apache2-mpm-prefork
apache2
mailman
mysql-server-5.1
bind9
clamav-freshclam
clamav
clamav-daemon
dovecot-common
dovecot-imapd
dovecot-pop3d
libapache2-mod-php5
libapache2-mod-ruby
libapache2-svn
mysql-server
postgresql-common
postgresql-8.4
postgresql
proftpd-basic
sasl2-bin
spamassassin
postfix-pcre
FATAL - 2011-03-17 16:10:19 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2011-03-17 16:10:19 - Cannot continue installation.
FATAL - 2011-03-17 16:10:19 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2011-03-17 16:10:19 - re-attempted after any problems have been resolved.
FATAL - 2011-03-17 16:10:19 - Removing temporary directory and files.
FATAL - 2011-03-17 16:10:19 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2011-03-17 16:10:19 - in /root/virtualmin-install.log
So, it looks as if you’re using OpenVZ there. We’ve run into some of the strangest problems on that platform :slight_smile:
Let’s start here though – what does the RAM on your system look like? You can determine that by running this command:
free -m
My Ram are like this:
total used free shared buffers cached Mem: 1536 106 1429 0 0 0 -/+ buffers/cache: 106 1429 Swap: 0 0 0
Looks like the /etc/init.d/vzquota script isn’t complaint with Debain 6’s new boot script system.
Could you paste the contents of that script here?
Sure. It down below :slight_smile:
#!/bin/sh start() { [ -e "/dev/simfs" ] || mknod /dev/simfs b 0 162 rm -f /etc/mtab >/dev/null 2>&1 echo "/dev/simfs / reiserfs rw,usrquota,grpquota 0 0" > /etc/mtab mnt=`grep -v " / " /proc/mounts` if [ $? == 0 ]; then echo "$mnt" >> /etc/mtab fi chmod 644 /etc/mtab quotaon -aug } case "$1" in start) start ;; *) exit esac
Ok, that looks incomplete - Debian requires that init scripts have a header at the top like :
#!/bin/sh ### BEGIN INIT INFO # Provides: vzquota # Required-Start: $local_fs $remote_fs $network $syslog # Required-Stop: $local_fs $remote_fs $network $syslog # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: Create /etc/fstab file ### END INIT INFO
What should i do now?
Well, the next step would be to take the information Jamie posted in his comment above, and use that to correct your “/etc/init.d/vzquota” file.
Once you’ve done that, try running the installation again, and see if that runs cleanly now.
I made the changes to vzquota and the install went further…but got fatal error further “downstream”…here’s the error -
"…hp5 php5-cgi libgd2-xpm libapache2-mod-php5 php5-mysql: Succeeded.
INFO - Succeeded.
INFO - Installing Virtualmin and all related packages now using the command :
INFO - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-ye s install virtualmin-base
…in progress, please wait…
… … …configured to not write apport reports
.E: Sub-process /usr/bin/dpkg returned an error code (1)
/usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes insta ll virtualmin-base failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubl eshoot this problem:
Allowing traffic on TCP port: ftp-data
Allowing traffic on TCP port: pop3
Allowing traffic on TCP port: pop3s
Allowing traffic on TCP port: imap
Allowing traffic on TCP port: imaps
Allowing traffic on TCP port: http
Allowing traffic on TCP port: https
Allowing traffic on TCP port: 10000
Allowing traffic on TCP port: 20000
Allowing traffic on UDP port: domain
Re-checking supported Webmin modules
dpkg: error processing virtualmin-base (–configure):
subprocess installed post-installation script returned error exit status 2 55
virtualmin-base
WARN - apt-get seems to have failed. Are you sure your OS and version is su pported?
WARN - http://www.virtualmin.com/os-support
FATAL - Fatal Error Occurred: Installation failed: 0
FATAL - Attempting to remove virtualmin repository configuration, so the in stallation can be
FATAL - If you are unsure of what went wrong, you may wish to review the lo g
FATAL - in /root/virtualmin-install.log "
Help?
There’s a few different sources for installation issues on OpenVZ-based VPS’s, one of which is not having enough dedicated RAM (as opposed to burst RAM).
What is the output of this command:
cat /proc/user_beancounters
That should show the various kinds of RAM available, as well as if it’s been seeing problems allocating RAM on your server.
Just curious…how much memory is needed to run Vitualmin again?
Well, RAM works differently on OpenVZ than on other VPS’s. Processes using OpenVZ’s burst RAM can be killed off at any point to make room for processes running on other VPS’s on your host.
So the Linux kernel thinks RAM is available and uses it, where that RAM may not actually be guaranteed.
On systems with dedicated RAM, the full Virtualmin stack can run with, say, 512MB of RAM (though that’s still considered a low-memory situation).
However, I’ve seen OpenVZ systems with far more RAM than that fail just because the Linux kernel thinks it’s safe to use the RAM, when it actually isn’t.
My VPS is 256mb and 512m burst…so…I guess I’ll have issues with installation, eh?
Yeah, chances are that’s not enough.
