I am trying to install on a fresh Cent OS installation using the install script. So far it has gone like this:
Welcome to the Virtualmin GPL installer, version 1.0.3
WARNING:
The installation is quite stable and functional when run on a freshly
installed supported Operating System, but upgrades from existing .wbm-
based systems, or systems that already have Apache VirtualHost
directives or mail users, will very likely run into numerous problems.
Please read the Virtualmin Administrators Guide before proceeding if
your system is not a freshly installed and supported OS.
This script is not intended to update your system! It should only be
used to install Virtualmin Professional, on a supported OS. If you have
previously installed Virtualmin via this script or the GPL version of
this script, upgrades and updates should be handled within Virtualmin
itself. Once Virtualmin is installed, you never need to run this script
again.
The systems currently supported by install.sh are:
CentOS 4 and 5 on i386 and x86_64
Debian 4.0 and 5.0 on i386 and amd64
Ubuntu 8.04 LTS on i386 and amd64
If your OS is not listed above, this script will fail. More details
about the systems supported by the script can be found here:
http://www.virtualmin.com/os-support.html
Continue? (y/n) y
Checking for HTTP client…found /usr/bin/curl -s -O
Checking for perl…found /usr/bin/perl
Loading log4sh logging library…
INFO - Started installation log in /root/virtualmin-install.log
INFO - Checking for fully qualified hostname…
INFO - Hostname ourwayoflife is not fully qualified.
Please enter a fully qualified hostname (for example, example.com): vm1.wol2000.co.uk
INFO - Hostname OK: fully qualified as vm1.wol2000.co.uk
eth0: error fetching interface information: Device not found
INFO - Unable to determine IP address of primary interface.
Please enter the name of your primary network interface:
I take where the warning says the script should only be for installing Virtualmin Professional, it doesn’t mean that and the script is for installing the GPL version as per the “welcome Message”? I got the script thus: wget http://software.virtualmin.com/gpl/scripts/install.sh
The OS install was done by my ISP and apache seems to be running (& installed as part of the CentOS install. Is this an issue?
Finally, what is my primary network interface? I am running through a terminal session to the server, logged in as root on a Mac.
