Hi I was trying to restore my wordpress website (which I backed up with the duplicator plugin), but I had to update php and mysql, everything worked just fine, I was trying to create a database and a user to this backup and I got this error:
Failed to save user : SQL insert into user (host, user, Select_priv, Insert_priv, Update_priv, Delete_priv, Create_priv, Drop_priv, Reload_priv, Shutdown_priv, Process_priv, File_priv, Grant_priv, References_priv, Index_priv, Alter_priv, Show_db_priv, Super_priv, Create_tmp_table_priv, Lock_tables_priv, Execute_priv, Repl_slave_priv, Repl_client_priv, Create_view_priv, Show_view_priv, Create_routine_priv, Alter_routine_priv, Create_user_priv, Event_priv, Trigger_priv, Create_tablespace_priv, ssl_type, ssl_cipher, x509_issuer, x509_subject, authentication_string) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) failed : Duplicate entry ‘%-zephw’ for key ‘PRIMARY’
Anytime I try any kind of option, I run into this problem.
Could you help me out?
Thanks!
