Hi all,
following problem:
i used and installed xen virtual machines on centos 5.6 manually with xm and virt-manager.
When creating virtual-machines a .spx configuration file was created at /var/lib/xend/domains/uid-number
The machines work as expected.
After installing cloudmin with the installer-script, yum updated xen, xen-libs… cloudmin starts with no virtual machine. No Error.
One of my old xen machines had also a standard config file. With thatone used i could add a cloudmin-hosted machine.
If i manually create a config file with vi, just changing the name, uid, macadress and path to the .img file, cloudmin complains: “Failed to add system : Xen configuration file does not appear to be for the selected instance” I took the uid, macadress… from the running virt-manager information panel.
Any hints what do check?
The config looks like this: (name and uid not copied
name = “foo”
uid = “xlxlxlxxx-bar”
maxmem = 1012
memory = 1012
vcpus = 1
builder = “hvm”
kernel = “/usr/lib/xen/boot/hvmloader”
boot = “c”
pae = 1
acpi = 1
apic = 1
localtime = 0
on_poweroff = “destroy”
on_reboot = “restart”
on_crash = “restart”
device_model = “/usr/lib64/xen/bin/qemu-dm”
sdl = 0
vnc = 1
vncunused = 1
disk = [ “file:/xen/terminalserver.img,hda,w”, “,hdc:cdrom,r” ]
vif = [ “mac=00:16:3e:5e:83:0d,bridge=xenbr0” ]
serial = “pty”
Any hints what to change, so cloudmin will accept this running machines?
Thanks for some tipps
Best regards
Andreas
