im reading it, I try to help my self as much as possible and not bother fourm people but because I am using fedora 9 I cannot use a install script and am have a ‘fun time’ now… Weeeeeeeeeeeee …
Here is log:
Feb 22 04:17:48 seatechmarineproducts sendmail[3261]: n1MCHjSI003261: from=root, size=549, class=0, nrcpts=1, msgid=<200902221217.n1MCHjSI003261@seatechmarineproducts>, relay=root@localhost
Feb 22 04:17:48 seatechmarineproducts sendmail[3428]: n1MCHmFE003428: from=<root@seatechmarineproducts>, size=828, class=0, nrcpts=1, msgid=<200902221217.n1MCHjSI003261@seatechmarineproducts>, proto=ESMTP, daemon=MTA, relay=seatechlinux [127.0.0.1]
Feb 22 04:17:48 seatechmarineproducts sendmail[3428]: n1MCHmFE003428: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=30828, dsn=4.4.3, stat=queued
Feb 22 04:17:48 seatechmarineproducts sendmail[3261]: n1MCHjSI003261: to=root, ctladdr=root (0/0), delay=00:00:03, xdelay=00:00:00, mailer=relay, pri=30549, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n1MCHmFE003428 Message accepted for delivery)
Feb 22 09:03:34 seatechmarineproducts sendmail[459]: n1MCHmFE003428: n1MH3YFF000459: sender notify: Warning: could not send message for past 4 hours
Feb 22 09:03:34 seatechmarineproducts sendmail[459]: n1MH3YFF000459: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=32072, dsn=4.4.3, stat=queued
Feb 22 09:03:34 seatechmarineproducts sendmail[459]: n1MCHigL003229: n1MH3YFG000459: sender notify: Warning: could not send message for past 4 hours
Feb 22 09:03:34 seatechmarineproducts sendmail[459]: n1MH3YFG000459: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=32516, dsn=4.4.3, stat=queued
Feb 23 04:17:44 seatechmarineproducts sendmail[1028]: n1NCHi1k001028: from=root, size=987, class=0, nrcpts=1, msgid=<200902231217.n1NCHi1k001028@seatechmarineproducts>, relay=root@localhost
Feb 23 04:17:44 seatechmarineproducts sendmail[1041]: n1NCHi5W001041: from=<root@seatechmarineproducts>, size=1267, class=0, nrcpts=1, msgid=<200902231217.n1NCHi1k001028@seatechmarineproducts>, proto=ESMTP, daemon=MTA, relay=seatechlinux [127.0.0.1]
Feb 23 04:17:44 seatechmarineproducts sendmail[1041]: n1NCHi5W001041: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=31267, dsn=4.4.3, stat=queued
Feb 23 04:17:44 seatechmarineproducts sendmail[1028]: n1NCHi1k001028: to=root, ctladdr=root (0/0), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30987, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n1NCHi5W001041 Message accepted for delivery)
Feb 23 04:17:59 seatechmarineproducts sendmail[1065]: n1NCHiGi001065: from=root, size=549, class=0, nrcpts=1, msgid=<200902231217.n1NCHiGi001065@seatechmarineproducts>, relay=root@localhost
Feb 23 04:17:59 seatechmarineproducts sendmail[1257]: n1NCHxrD001257: from=<root@seatechmarineproducts>, size=828, class=0, nrcpts=1, msgid=<200902231217.n1NCHiGi001065@seatechmarineproducts>, proto=ESMTP, daemon=MTA, relay=seatechlinux [127.0.0.1]
Feb 23 04:17:59 seatechmarineproducts sendmail[1257]: n1NCHxrD001257: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=30828, dsn=4.4.3, stat=queued
Feb 23 04:17:59 seatechmarineproducts sendmail[1065]: n1NCHiGi001065: to=root, ctladdr=root (0/0), delay=00:00:15, xdelay=00:00:00, mailer=relay, pri=30549, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n1NCHxrD001257 Message accepted for delivery)
Feb 23 09:03:34 seatechmarineproducts sendmail[1299]: n1NCHxrD001257: n1NH3YrE001299: sender notify: Warning: could not send message for past 4 hours
Feb 23 09:03:34 seatechmarineproducts sendmail[1299]: n1NH3YrE001299: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=32072, dsn=4.4.3, stat=queued
Feb 23 09:03:34 seatechmarineproducts sendmail[1299]: n1NCHi5W001041: n1NH3YrF001299: sender notify: Warning: could not send message for past 4 hours
Feb 23 09:03:34 seatechmarineproducts sendmail[1299]: n1NH3YrF001299: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=32516, dsn=4.4.3, stat=queued
Feb 23 11:03:34 seatechmarineproducts sendmail[1320]: n1IIOdHC002829: n1NJ3YrE001320: sender notify: Cannot send message for 5 days
Feb 23 11:03:34 seatechmarineproducts sendmail[1320]: n1NJ3YrE001320: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=31877, dsn=4.4.3, stat=queued
Feb 23 11:03:34 seatechmarineproducts sendmail[1320]: n1IIOHbd002601: n1NJ3YrF001320: sender notify: Cannot send message for 5 days
Feb 23 11:03:34 seatechmarineproducts sendmail[1320]: n1NJ3YrF001320: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=32516, dsn=4.4.3, stat=queued
Feb 23 15:03:34 seatechmarineproducts sendmail[1360]: n1IN3XHD032478: n1NN3YrE001360: return to sender: Cannot send message for 5 days
Feb 23 15:03:34 seatechmarineproducts sendmail[1360]: n1NN3YrE001360: to=root, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=33716, dsn=2.0.0, stat=Sent
Feb 23 15:03:34 seatechmarineproducts sendmail[1360]: n1IN3XHE032478: n1NN3YrF001360: return to sender: Cannot send message for 5 days
Feb 23 15:03:34 seatechmarineproducts sendmail[1360]: n1NN3YrF001360: to=root, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=34357, dsn=2.0.0, stat=Sent
Feb 24 04:17:44 seatechmarineproducts sendmail[2066]: n1OCHiHO002066: from=root, size=987, class=0, nrcpts=1, msgid=<200902241217.n1OCHiHO002066@seatechmarineproducts>, relay=root@localhost
Feb 24 04:17:44 seatechmarineproducts sendmail[2082]: n1OCHi50002082: from=<root@seatechmarineproducts>, size=1267, class=0, nrcpts=1, msgid=<200902241217.n1OCHiHO002066@seatechmarineproducts>, proto=ESMTP, daemon=MTA, relay=seatechlinux [127.0.0.1]
Feb 24 04:17:44 seatechmarineproducts sendmail[2082]: n1OCHi50002082: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=31267, dsn=4.4.3, stat=queued
Feb 24 04:17:44 seatechmarineproducts sendmail[2066]: n1OCHiHO002066: to=root, ctladdr=root (0/0), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30987, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n1OCHi50002082 Message accepted for delivery)
Feb 24 04:18:13 seatechmarineproducts sendmail[2108]: n1OCHigu002108: from=root, size=549, class=0, nrcpts=1, msgid=<200902241217.n1OCHigu002108@seatechmarineproducts>, relay=root@localhost
Feb 24 04:18:13 seatechmarineproducts sendmail[5136]: n1OCID7i005136: from=<root@seatechmarineproducts>, size=828, class=0, nrcpts=1, msgid=<200902241217.n1OCHigu002108@seatechmarineproducts>, proto=ESMTP, daemon=MTA, relay=seatechlinux [127.0.0.1]
Feb 24 04:18:13 seatechmarineproducts sendmail[5136]: n1OCID7i005136: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=30828, dsn=4.4.3, stat=queued
Feb 24 04:18:13 seatechmarineproducts sendmail[2108]: n1OCHigu002108: to=root, ctladdr=root (0/0), delay=00:00:29, xdelay=00:00:00, mailer=relay, pri=30549, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n1OCID7i005136 Message accepted for delivery)
Feb 24 05:03:34 seatechmarineproducts sendmail[5141]: n1JCHnap000759: n1OD3Y7j005141: sender notify: Cannot send message for 5 days
Feb 24 05:03:34 seatechmarineproducts sendmail[5141]: n1OD3Y7j005141: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=32072, dsn=4.4.3, stat=queued
Feb 24 05:03:34 seatechmarineproducts sendmail[5141]: n1JCHjI6000567: n1OD3Y7k005141: sender notify: Cannot send message for 5 days
Feb 24 05:03:34 seatechmarineproducts sendmail[5141]: n1OD3Y7k005141: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=34724, dsn=4.4.3, stat=queued
Feb 24 05:38:26 seatechmarineproducts sendmail[1917]: alias database /etc/aliases rebuilt by root
Feb 24 05:38:26 seatechmarineproducts sendmail[1917]: /etc/aliases: 76 aliases, longest 10 bytes, 765 bytes total
Feb 24 05:38:26 seatechmarineproducts sendmail[1922]: starting daemon (8.14.2): SMTP+queueing@01:00:00
Feb 24 05:38:26 seatechmarineproducts sm-msp-queue[1931]: starting daemon (8.14.2): queueing@01:00:00
Feb 24 06:22:45 seatechmarineproducts sendmail[1923]: alias database /etc/aliases rebuilt by root
Feb 24 06:22:45 seatechmarineproducts sendmail[1923]: /etc/aliases: 76 aliases, longest 10 bytes, 765 bytes total
Feb 24 06:22:45 seatechmarineproducts sendmail[1928]: starting daemon (8.14.2): SMTP+queueing@01:00:00
Feb 24 06:22:45 seatechmarineproducts sm-msp-queue[1937]: starting daemon (8.14.2): queueing@01:00:00
Feb 24 07:01:44 seatechmarineproducts sendmail[1923]: alias database /etc/aliases rebuilt by root
Feb 24 07:01:44 seatechmarineproducts sendmail[1923]: /etc/aliases: 76 aliases, longest 10 bytes, 765 bytes total
Feb 24 07:01:44 seatechmarineproducts sendmail[1928]: starting daemon (8.14.2): SMTP+queueing@01:00:00
Feb 24 07:01:45 seatechmarineproducts sm-msp-queue[1937]: starting daemon (8.14.2): queueing@01:00:00
Feb 24 07:30:22 seatechmarineproducts sendmail[1917]: alias database /etc/aliases rebuilt by root
Feb 24 07:30:22 seatechmarineproducts sendmail[1917]: /etc/aliases: 76 aliases, longest 10 bytes, 765 bytes total
Feb 24 07:30:22 seatechmarineproducts sendmail[1922]: starting daemon (8.14.2): SMTP+queueing@01:00:00
Feb 24 07:30:23 seatechmarineproducts sm-msp-queue[1931]: starting daemon (8.14.2): queueing@01:00:00
Feb 24 07:33:42 seatechmarineproducts sendmail[1928]: alias database /etc/aliases rebuilt by root
Feb 24 07:33:42 seatechmarineproducts sendmail[1928]: /etc/aliases: 76 aliases, longest 10 bytes, 765 bytes total
Feb 24 07:33:42 seatechmarineproducts sendmail[1933]: starting daemon (8.14.2): SMTP+queueing@01:00:00
Feb 24 07:33:42 seatechmarineproducts sm-msp-queue[1942]: starting daemon (8.14.2): queueing@01:00:00
Feb 24 08:33:42 seatechmarineproducts sendmail[7777]: n1OCID7i005136: n1OGXgH3007777: sender notify: Warning: could not send message for past 4 hours
Feb 24 08:33:42 seatechmarineproducts sendmail[7777]: n1OGXgH3007777: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=32072, dsn=4.4.3, stat=queued
Feb 24 08:33:42 seatechmarineproducts sendmail[7777]: n1OCHi50002082: n1OGXgH4007777: sender notify: Warning: could not send message for past 4 hours
Feb 24 08:33:42 seatechmarineproducts sendmail[7777]: n1OGXgH4007777: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=local, pri=32516, dsn=4.4.3, stat=queued
Feb 24 08:51:13 seatechmarineproducts sendmail[1926]: alias database /etc/aliases rebuilt by root
Feb 24 08:51:13 seatechmarineproducts sendmail[1926]: /etc/aliases: 76 aliases, longest 10 bytes, 765 bytes total
Feb 24 08:51:13 seatechmarineproducts sendmail[1931]: starting daemon (8.14.2): SMTP+queueing@01:00:00
Feb 24 08:51:13 seatechmarineproducts sm-msp-queue[1940]: starting daemon (8.14.2): queueing@01:00:00
Feb 24 09:51:13 seatechmarineproducts sendmail[5968]: n1JH3Yaq000860: n1OHpDNE005968: return to sender: Cannot send message for 5 days
Feb 24 09:51:13 seatechmarineproducts sendmail[5968]: n1OHpDNE005968: to=root, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=33918, dsn=2.0.0, stat=Sent
Feb 24 09:51:13 seatechmarineproducts sendmail[5968]: n1JH3Yar000860: n1OHpDNF005968: return to sender: Cannot send message for 5 days
Feb 24 09:51:13 seatechmarineproducts sendmail[5968]: n1OHpDNF005968: to=root, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=36565, dsn=2.0.0, stat=Sent
Feb 25 02:13:24 seatechproducts sendmail[1937]: alias database /etc/aliases rebuilt by root
Feb 25 02:13:24 seatechproducts sendmail[1937]: /etc/aliases: 76 aliases, longest 10 bytes, 765 bytes total
Feb 25 02:13:24 seatechproducts sendmail[1942]: starting daemon (8.14.2): SMTP+queueing@01:00:00
Feb 25 02:13:24 seatechproducts sm-msp-queue[1951]: starting daemon (8.14.2): queueing@01:00:00
Feb 25 02:43:25 seatechproducts postfix/postfix-script[6226]: starting the Postfix mail system
Feb 25 02:43:25 seatechproducts postfix/master[6228]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 03:06:46 seatechproducts sendmail[1935]: alias database /etc/aliases rebuilt by root
Feb 25 03:06:46 seatechproducts sendmail[1935]: /etc/aliases: 76 aliases, longest 10 bytes, 765 bytes total
Feb 25 03:06:46 seatechproducts sendmail[1940]: starting daemon (8.14.2): SMTP+queueing@01:00:00
Feb 25 03:06:47 seatechproducts sm-msp-queue[1949]: starting daemon (8.14.2): queueing@01:00:00
Feb 25 03:51:16 seatechproducts postfix/postfix-script[3877]: starting the Postfix mail system
Feb 25 03:51:16 seatechproducts postfix/master[3879]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 03:51:20 seatechproducts dovecot: Dovecot v1.0.13 starting up
Feb 25 03:51:20 seatechproducts dovecot: Generating Diffie-Hellman parameters for the first time. This may take a while…
Feb 25 03:51:30 seatechproducts postfix/postfix-script[4117]: starting the Postfix mail system
Feb 25 03:51:30 seatechproducts postfix/master[4118]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 03:51:37 seatechproducts dovecot: ssl-build-param: SSL parameters regeneration completed
Feb 25 04:06:15 seatechproducts sendmail[4520]: n1PC6DQi004520: from=root, size=8562, class=0, nrcpts=1, msgid=<200902251206.n1PC6DQi004520@seatechproducts.net>, relay=root@localhost
Feb 25 04:06:15 seatechproducts sendmail[4810]: n1PC6F6M004810: from=<root@seatechproducts.net>, size=8834, class=0, nrcpts=1, msgid=<200902251206.n1PC6DQi004520@seatechproducts.net>, proto=ESMTP, daemon=MTA, relay=seatechlinux [127.0.0.1]
Feb 25 04:06:15 seatechproducts sendmail[4810]: n1PC6F6M004810: to=<root@seatechproducts.net>, delay=00:00:00, mailer=local, pri=38834, dsn=4.4.3, stat=queued
Feb 25 04:06:15 seatechproducts sendmail[4520]: n1PC6DQi004520: to=root, ctladdr=root (0/0), delay=00:00:02, xdelay=00:00:00, mailer=relay, pri=38562, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n1PC6F6M004810 Message accepted for delivery)
Feb 25 04:07:04 seatechproducts sendmail[4389]: n1PC6B1J004389: from=root, size=424, class=0, nrcpts=1, msgid=<200902251206.n1PC6B1J004389@seatechproducts.net>, relay=root@localhost
Feb 25 04:07:04 seatechproducts sendmail[10783]: n1PC7410010783: from=<root@seatechproducts.net>, size=695, class=0, nrcpts=1, msgid=<200902251206.n1PC6B1J004389@seatechproducts.net>, proto=ESMTP, daemon=MTA, relay=seatechlinux [127.0.0.1]
Feb 25 04:07:04 seatechproducts sendmail[10783]: n1PC7410010783: to=<root@seatechproducts.net>, delay=00:00:00, mailer=local, pri=30695, dsn=4.4.3, stat=queued
Feb 25 04:07:04 seatechproducts sendmail[4389]: n1PC6B1J004389: to=root, ctladdr=root (0/0), delay=00:00:53, xdelay=00:00:00, mailer=relay, pri=30424, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n1PC7410010783 Message accepted for delivery)
Feb 25 04:12:13 seatechproducts dovecot: Killed with signal 15
Feb 25 04:13:06 seatechproducts sendmail[1935]: alias database /etc/aliases rebuilt by root
Feb 25 04:13:06 seatechproducts sendmail[1935]: /etc/aliases: 76 aliases, longest 10 bytes, 765 bytes total
Feb 25 04:13:06 seatechproducts sendmail[1940]: starting daemon (8.14.2): SMTP+queueing@01:00:00
Feb 25 04:13:06 seatechproducts sm-msp-queue[1949]: starting daemon (8.14.2): queueing@01:00:00
Feb 25 04:41:26 seatechproducts postfix/postfix-script[3419]: starting the Postfix mail system
Feb 25 04:41:26 seatechproducts postfix/master[3421]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 04:41:32 seatechproducts dovecot: Dovecot v1.0.13 starting up
Feb 25 04:41:51 seatechproducts postfix/postfix-script[3623]: starting the Postfix mail system
Feb 25 04:41:51 seatechproducts postfix/master[3624]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 04:57:19 seatechproducts sendmail[4958]: n1PCvCdX004958: from=root, size=414, class=0, nrcpts=1, msgid=<200902251257.n1PCvCdX004958@seatechproducts.net>, relay=root@localhost
Feb 25 04:57:19 seatechproducts sendmail[4995]: n1PCvJbA004995: from=<root@seatechproducts.net>, size=685, class=0, nrcpts=1, msgid=<200902251257.n1PCvCdX004958@seatechproducts.net>, proto=ESMTP, daemon=MTA, relay=seatechlinux [127.0.0.1]
Feb 25 04:57:19 seatechproducts sendmail[4995]: n1PCvJbA004995: to=<root@seatechproducts.net>, delay=00:00:00, mailer=local, pri=30685, dsn=4.4.3, stat=queued
Feb 25 04:57:19 seatechproducts sendmail[4958]: n1PCvCdX004958: to=root, ctladdr=root (0/0), delay=00:00:07, xdelay=00:00:00, mailer=relay, pri=30414, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n1PCvJbA004995 Message accepted for delivery)
Feb 25 05:13:06 seatechproducts sendmail[5806]: n1KCHmlC001648: n1PDD6bB005806: sender notify: Cannot send message for 5 days
Feb 25 05:13:06 seatechproducts sendmail[5806]: n1PDD6bB005806: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=esmtp, pri=32072, dsn=4.4.3, stat=queued
Feb 25 05:13:06 seatechproducts sendmail[5806]: n1KCHiUU001443: n1PDD6bC005806: sender notify: Cannot send message for 5 days
Feb 25 05:13:06 seatechproducts sendmail[5806]: n1PDD6bC005806: to=<root@seatechmarineproducts>, delay=00:00:00, mailer=esmtp, pri=32516, dsn=4.4.3, stat=queued
Feb 25 05:15:44 seatechproducts postfix/postfix-script[6114]: starting the Postfix mail system
Feb 25 05:15:44 seatechproducts postfix/master[6115]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 05:27:59 seatechproducts postfix/postfix-script[6860]: starting the Postfix mail system
Feb 25 05:27:59 seatechproducts postfix/master[6861]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 05:32:08 seatechproducts postfix/postfix-script[7111]: starting the Postfix mail system
Feb 25 05:32:08 seatechproducts postfix/master[7112]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 05:32:22 seatechproducts postfix/postfix-script[7188]: starting the Postfix mail system
Feb 25 05:32:22 seatechproducts postfix/master[7189]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 05:33:05 seatechproducts postfix/postfix-script[7337]: starting the Postfix mail system
Feb 25 05:33:05 seatechproducts postfix/master[7338]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 05:50:52 seatechproducts dovecot: Killed with signal 15
Feb 25 05:50:57 seatechproducts postfix/postfix-script[8720]: starting the Postfix mail system
Feb 25 05:50:57 seatechproducts postfix/master[8721]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 05:59:11 seatechproducts postfix/postfix-script[9010]: starting the Postfix mail system
Feb 25 05:59:11 seatechproducts postfix/master[9012]: fatal: bind 127.0.0.1 port 25: Address already in use
Feb 25 06:02:23 seatechproducts sendmail[9100]: n1PE2GqR009100: from=root, size=414, class=0, nrcpts=1, msgid=<200902251402.n1PE2GqR009100@seatechproducts.net>, relay=root@localhost
Feb 25 06:02:23 seatechproducts sendmail[9146]: n1PE2NOs009146: from=<root@seatechproducts.net>, size=685, class=0, nrcpts=1, msgid=<200902251402.n1PE2GqR009100@seatechproducts.net>, proto=ESMTP, daemon=MTA, relay=seatechlinux [127.0.0.1]
Feb 25 06:02:23 seatechproducts sendmail[9146]: n1PE2NOs009146: to=<root@seatechproducts.net>, delay=00:00:00, mailer=local, pri=30685, dsn=4.4.3, stat=queued
Feb 25 06:02:23 seatechproducts sendmail[9100]: n1PE2GqR009100: to=root, ctladdr=root (0/0), delay=00:00:07, xdelay=00:00:00, mailer=relay, pri=30414, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n1PE2NOs009146 Message accepted for delivery)
Feb 25 06:18:32 seatechproducts postfix/postfix-script[9613]: starting the Postfix mail system
Feb 25 06:18:32 seatechproducts postfix/master[9614]: fatal: bind 127.0.0.1 port 25: Address already in use
